ShHealOper_ModifStats.hxx
23// File : ShHealOper_ModifStats.hxx
24// Created : Mon Dec 1 15:29:48 2014
26#ifndef __ShHealOper_ModifStats_HXX__
27#define __ShHealOper_ModifStats_HXX__
28
29#include <string>
30#include <set>
31
35class Standard_EXPORT ShHealOper_ModifStats
36{
37 public:
38
39 struct Standard_EXPORT Datum
40 {
41 std::string myModif; // what is done
42 mutable int myCount; // how many times (in how many sub-shapes)
43
44 Datum( const std::string& txt, int cnt=0 ): myModif( txt ), myCount(cnt) {}
45 bool operator< ( const Datum& o ) const { return myModif < o.myModif; }
46 };
47
48 // record a modification
49 void AddModif( const std::string& modifText, int nb=1 )
50 {
51 std::set< Datum >::iterator d = myData.insert( Datum( modifText )).first;
52 d->myCount += nb;
53 }
54
55 // add data from another ShHealOper_ModifStats
56 void Add( const ShHealOper_ModifStats& stats )
57 {
58 if ( myData.empty() ) myData = stats.myData;
59 else {
60 std::set< Datum >::const_iterator d = stats.myData.begin();
61 for ( ; d != stats.myData.end(); ++d )
62 AddModif( d->myModif, d->myCount );
63 }
64 }
65
66 // return all recorder modifications
67 const std::set< Datum >& GetData() const { return myData; }
68
69 // clear all statistics
70 void Clear() { myData.clear(); }
71
72 protected:
73
74 std::set< Datum > myData;
75
76};
77
78#endif
bool operator<(const gp_Pnt &me, const gp_Pnt &other)
Definition: GEOMImpl_WrappingDriver.cxx:101
Structure describing modifications done in a shape.
Definition: ShHealOper_ModifStats.hxx:36
Definition: ShHealOper_ModifStats.hxx:74
void Add(const ShHealOper_ModifStats &stats)
Definition: ShHealOper_ModifStats.hxx:56
const std::set< Datum > & GetData() const
Definition: ShHealOper_ModifStats.hxx:67
void Clear()
Definition: ShHealOper_ModifStats.hxx:70
void AddModif(const std::string &modifText, int nb=1)
Definition: ShHealOper_ModifStats.hxx:49
Definition: ShHealOper_ModifStats.hxx:40
Datum(const std::string &txt, int cnt=0)
Definition: ShHealOper_ModifStats.hxx:44
std::string myModif
Definition: ShHealOper_ModifStats.hxx:41
int myCount
Definition: ShHealOper_ModifStats.hxx:42
