TransformationGUI_TranslationDlg.h
24// File : TransformationGUI_TranslationDlg.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef TRANSFORMATIONGUI_TRANSLATIONDLG_H
28#define TRANSFORMATIONGUI_TRANSLATIONDLG_H
30#include "GEOMBase_Skeleton.h"
31#include "GEOM_GenericObjPtr.h"
32
34
35//=================================================================================
36// class : TransformationGUI_TranslationDlg
37// purpose :
38//=================================================================================
40{
41 Q_OBJECT
42
43public:
45 bool = false, Qt::WindowFlags = 0 );
47
48protected:
49 // redefined from GEOMBase_Helper
50 virtual GEOM::GEOM_IOperations_ptr createOperation();
51 virtual bool isValid( QString& );
52 virtual bool execute( ObjectList& );
53 virtual void addSubshapesToStudy();
54 virtual void restoreSubShapes( SALOMEDS::SObject_ptr );
55 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
56
57private:
58 void Init();
59 void enterEvent( QEvent* );
60 void createPathPreview( GEOM::GEOM_Object_ptr );
61
62private:
63 QList<GEOM::GeomObjPtr> myObjects;
66
67 // to initialize the first selection field with a selected object on the dialog creation
69
71
72private slots:
73 void ClickOnOk();
74 bool ClickOnApply();
75 void ActivateThisDialog();
78 void ConstructorsClicked( int );
81 void SetDoubleSpinBoxStep( double );
83};
84
85#endif // TRANSFORMATIONGUI_TRANSLATIONDLG_H
Definition: DlgRef.h:787
Definition: GeometryGUI.h:74
Definition: TransformationGUI_TranslationDlg.h:40
bool myInitial
Definition: TransformationGUI_TranslationDlg.h:68
void ValueChangedInSpinBox()
Definition: TransformationGUI_TranslationDlg.cxx:442
void ConstructorsClicked(int)
Definition: TransformationGUI_TranslationDlg.cxx:196
void SetDoubleSpinBoxStep(double)
Definition: TransformationGUI_TranslationDlg.cxx:185
void ActivateDistanceChanged()
Definition: TransformationGUI_TranslationDlg.cxx:636
void createPathPreview(GEOM::GEOM_Object_ptr)
Definition: TransformationGUI_TranslationDlg.cxx:668
bool ClickOnApply()
Definition: TransformationGUI_TranslationDlg.cxx:283
~TransformationGUI_TranslationDlg()
Definition: TransformationGUI_TranslationDlg.cxx:117
Definition: TransformationGUI_TranslationDlg.cxx:451
GEOM::GeomObjPtr myPoint1
Definition: TransformationGUI_TranslationDlg.h:65
GEOM::GeomObjPtr myPoint2
virtual void restoreSubShapes(SALOMEDS::SObject_ptr)
Definition: TransformationGUI_TranslationDlg.cxx:607
QList< GEOM::GeomObjPtr > myObjects
Definition: TransformationGUI_TranslationDlg.h:63
GEOM::GeomObjPtr myCurrObject
Definition: TransformationGUI_TranslationDlg.h:64
void CreateCopyModeChanged()
Definition: TransformationGUI_TranslationDlg.cxx:627
void enterEvent(QEvent *)
Definition: TransformationGUI_TranslationDlg.cxx:432
TransformationGUI_TranslationDlg(GeometryGUI *, QWidget *=0, bool=false, Qt::WindowFlags=0)
Definition: TransformationGUI_TranslationDlg.cxx:67
void SelectionIntoArgument()
Definition: TransformationGUI_TranslationDlg.cxx:301
void ClickOnOk()
Definition: TransformationGUI_TranslationDlg.cxx:272
Definition: TransformationGUI_TranslationDlg.cxx:487
Definition: TransformationGUI_TranslationDlg.cxx:646
Definition: TransformationGUI_TranslationDlg.cxx:694
Definition: TransformationGUI_TranslationDlg.cxx:460
Definition: TransformationGUI_TranslationDlg.cxx:419
void Init()
Definition: TransformationGUI_TranslationDlg.cxx:126
GEOM::GeomObjPtr myVector
DlgRef_3Sel3Spin2Check * GroupPoints
Definition: TransformationGUI_TranslationDlg.h:70
void SetEditCurrentArgument()
Definition: TransformationGUI_TranslationDlg.cxx:364
GenericObjPtr< GEOM::GEOM_Object > GeomObjPtr
Definition: GEOM_GenericObjPtr.h:218
