XAO_Group.hxx
1// Copyright (C) 2013-2026 CEA, EDF, OPEN CASCADE
19// Author : Nathalie Gore (OpenCascade), Frederic Pons (OpenCascade)
20
21#ifndef __XAO_GROUP_HXX__
22#define __XAO_GROUP_HXX__
23
24#include <string>
25#include <set>
26
27#include "XAO.hxx"
28#include "XAO_XaoUtils.hxx"
29#ifdef WIN32
30#pragma warning(disable:4251) // Warning dll-interface ...
31#endif
32namespace XAO
33{
39 {
40 public:
47 Group(XAO::Dimension dim, int nbElements, const std::string& name = std::string(""));
48
52 virtual ~Group();
53
58 const std::string getName()
59 {
60 return m_name;
61 }
66 void setName(const std::string& name)
67 {
68 m_name = name;
69 }
70
76 {
77 return m_dimension;
78 }
79
85 {
86 return m_nbElements;
87 }
88
93 int count() const
94 {
95 return m_elements.size();
96 }
97
104 int get(int index)
105 {
106 checkIndex(index);
107 std::set<int>::iterator it = m_elements.begin();
108 std::advance(it, index);
109 return (*it);
110 }
111
116 void add(int value);
117
122 void remove(int value);
123
128 std::set<int>::iterator begin() { return m_elements.begin(); }
129
134 std::set<int>::iterator end() { return m_elements.end(); }
135
136 private:
142 void checkIndex(int element);
143
144 private:
146 std::string m_name;
154 std::set<int> m_elements;
155 };
156}
157
158#endif
#define XAO_EXPORT
Definition: XAO.hxx:31
Class to represent a Geometrical Group.
Definition: XAO_Group.hxx:39
int m_count
The number of elements in the group.
Definition: XAO_Group.hxx:152
XAO::Dimension getDimension()
Gets the dimension of the group.
Definition: XAO_Group.hxx:75
int count() const
Gets the number of elements in the group.
Definition: XAO_Group.hxx:93
Sets the name of the group.
Definition: XAO_Group.hxx:66
Gets the name of the group.
Definition: XAO_Group.hxx:58
std::set< int >::iterator begin()
Gets an iterator on the first element in the group.
Definition: XAO_Group.hxx:128
int get(int index)
Gets the reference of an element.
Definition: XAO_Group.hxx:104
std::string m_name
The name of the group.
Definition: XAO_Group.hxx:146
XAO::Dimension m_dimension
The dimension of the group.
Definition: XAO_Group.hxx:150
std::set< int > m_elements
The elements of the group.
Definition: XAO_Group.hxx:154
std::set< int >::iterator end()
Gets an iterator on the last element in the group.
Definition: XAO_Group.hxx:134
int getNbElements()
Gets the numbers of elements in the geometry of the same type than the group.
Definition: XAO_Group.hxx:84
int m_nbElements
The number of elements in the associated geometry.
Definition: XAO_Group.hxx:148
Definition: BrepGeometryTest.hxx:26
Dimension
Definition: XAO_XaoUtils.hxx:50
