QtxMap.h
20// File : QtxMap.h
21// Author : Vadim SANDLER, Open CASCADE S.A.S. (vadim.sandler@opencascade.com)
22//
23#ifndef QTXMAP_H
24#define QTXMAP_H
26template <class Key, class Value> class IMap;
27template <class Key, class Value> class IMapIterator;
28template <class Key, class Value> class IMapConstIterator;
33template <class Key, class Value> class IMap
34{
35public:
38
39public:
40 IMap() {}
41 IMap( const IMap& m ) : myKeys( m.myKeys ), myData( m.myData ) {}
42 IMap& operator=( const IMap& m ) { myKeys = m.myKeys; myData = m.myData; return *this; }
43
44 int count() const { return myData.count(); }
45 int size() const { return myData.count(); }
46 bool empty() const { return myData.empty(); }
47 bool isEmpty() const { return myData.empty(); }
48
49 void clear() { myKeys.clear(); myData.clear(); }
50
51 QList<Key> keys() const { return myKeys; }
52 QList<Value> values() const { QList<Value> l; for ( int i = 0; i < count(); i++ ) l.append( value( i ) ); return l; }
53 bool contains ( const Key& key ) const { return myData.contains( key ); }
54
55 Iterator begin() { return Iterator( this ); }
56 Iterator end() { return Iterator( this, count() ); }
57 ConstIterator begin() const { return ConstIterator( this ); }
58 ConstIterator end() const { return ConstIterator( this, count() ); }
59
60 Iterator insert( const Key& key, const Value& value, bool overwrite = true )
61 {
62 if ( myData.find( key ) == myData.end() || overwrite )
63 {
64 if ( myData.find( key ) != myData.end() && overwrite )
65 myKeys.removeAt( myKeys.indexOf( key ) );
66 myKeys.append( key );
67 myData[key] = value;
68 }
69 return Iterator( this, index( key ) );
70 }
71
72 Iterator replace( const Key& key, const Value& value )
73 {
74 if ( myData.find( key ) == myData.end() )
75 myKeys.append( key );
76 myData[ key ] = value;
77 return Iterator( this, index( key ) );
78 }
79
80 int index( const Key& key ) const { return myKeys.indexOf( key ); }
81 Iterator at( const int index ) { return Iterator( this, index ); }
82 ConstIterator at( const int index ) const { return ConstIterator( this, index ); }
83
84 Key& key( const int index )
85 {
86 if ( index < 0 || index >= (int)myKeys.count() )
87 return dummyKey;
88 return myKeys[index];
89 }
90
91 Value value( const int index )
92 {
93 if ( index < 0 || index >= (int)myKeys.count() )
94 return dummyValue;
95 return myData[ myKeys[index] ];
96 }
97
98 Value operator[]( const Key& key )
99 {
100 if ( myData.find( key ) == myData.end() )
101 insert( key, Value() );
102 return myData[ key ];
103 }
104
105 const Value operator[]( const Key& key ) const
106 {
107 if ( myData.find( key ) == myData.end() )
108 return dummyValue;
109 return myData[key];
110 }
111
112 void erase( Iterator it ) { remove( it ); }
113 void erase( const Key& key ) { remove( key ); }
114 void erase( const int index ) { remove( index ); }
115 void remove( Iterator it ) { if ( it.myMap != this ) return; remove( it.myIndex ); }
116 void remove( const Key& key ) { remove( index( key ) ); }
117 void remove( const int index )
118 {
119 if ( index >= 0 && index < (int)myKeys.count() )
120 {
121 myData.remove( myKeys[index] );
122 myKeys.removeAt( index );
123 }
124 }
125
126private:
128 QMap<Key,Value> myData;
131
132 friend class IMapIterator<Key,Value>;
133 friend class IMapConstIterator<Key,Value>;
134};
135
139template <class Key, class Value> class IMapIterator
140{
141public:
142 IMapIterator() : myMap( 0 ), myIndex( 0 ) { init(); }
143 IMapIterator( const IMap<Key,Value>* m ) : myMap( const_cast< IMap<Key,Value>* >( m ) ), myIndex( 0 ) { init(); }
144 IMapIterator( const IMapIterator& i ) : myMap( i.myMap ), myIndex( i.myIndex ) { init(); }
145
146 bool operator==( const IMapIterator& i ) { return !operator!=( i ); }
147 bool operator!=( const IMapIterator& i ) { return !myMap || myMap != i.myMap || myIndex != i.myIndex; }
148
149 operator bool() const { return myIndex >= 0; }
150
151 const Key& key() const { return myMap->key( myIndex ); }
152 Value& value() { return myMap->value( myIndex ); }
153 const Value& value() const { return myMap->value( myIndex ); }
154
155 Value& operator*() { return value(); }
156
157 IMapIterator& operator++() { myIndex++; init(); return *this; }
158 IMapIterator operator++( int ) { IMapIterator i = *this; myIndex++; init(); return i; }
159 IMapIterator& operator--() { myIndex--; init(); return *this; }
160 IMapIterator operator--( int ) { IMapIterator i = *this; myIndex--; init(); return i; }
161
162private:
163 IMapIterator( const IMap<Key,Value>* m, const int index ) : myMap( const_cast< IMap<Key,Value>* >( m ) ), myIndex( index ) { init(); }
164 void init() { if ( !myMap || myIndex >= myMap->count() ) myIndex = -1; }
165
166private:
169
170 friend class IMap<Key, Value>;
171 friend class IMapConstIterator<Key, Value>;
172};
173
177template <class Key, class Value> class IMapConstIterator
178{
179public:
180 IMapConstIterator() : myMap( 0 ), myIndex( 0 ) { init(); }
181 IMapConstIterator( const IMap<Key,Value>* m ) : myMap( const_cast< IMap<Key,Value>* >( m ) ), myIndex( 0 ) { init(); }
184
185 bool operator==( const IMapConstIterator& i ) { return !operator!=( i ); }
186 bool operator!=( const IMapConstIterator& i ) { return !myMap || myMap != i.myMap || myIndex != i.myIndex; }
187
188 operator bool() const { return myIndex >= 0; }
189
190 const Key& key() const { return myMap->key( myIndex ); }
191 const Value value() const { return myMap->value( myIndex ); }
192
193 const Value operator*() const { return value(); }
194
195 IMapConstIterator& operator++() { myIndex++; init(); return *this; }
196 IMapConstIterator operator++( int ) { IMapConstIterator i = *this; myIndex++; init(); return i; }
197 IMapConstIterator& operator--() { myIndex--; init(); return *this; }
198 IMapConstIterator operator--( int ) { IMapConstIterator i = *this; myIndex--; init(); return i; }
199
200private:
201 IMapConstIterator( const IMap<Key,Value>* m, const int index ): myMap( const_cast< IMap<Key,Value>* >( m ) ), myIndex( index ) { init(); }
202 void init() { if ( !myMap || myIndex >= myMap->count() ) myIndex = -1; }
203
204private:
207
208 friend class IMap<Key,Value>;
209};
210
211#endif // QTXMAP_H
Indexed map const iterator template class.
Definition: QtxMap.h:178
int myIndex
Definition: QtxMap.h:206
IMapConstIterator operator--(int)
Definition: QtxMap.h:198
IMapConstIterator operator++(int)
Definition: QtxMap.h:196
IMapConstIterator & operator++()
Definition: QtxMap.h:195
Definition: QtxMap.h:191
IMapConstIterator()
Definition: QtxMap.h:180
IMapConstIterator(const IMapIterator< Key, Value > &i)
Definition: QtxMap.h:183
bool operator==(const IMapConstIterator &i)
Definition: QtxMap.h:185
void init()
Definition: QtxMap.h:202
IMapConstIterator(const IMap< Key, Value > *m)
Definition: QtxMap.h:181
IMap< Key, Value > * myMap
Definition: QtxMap.h:205
bool operator!=(const IMapConstIterator &i)
Definition: QtxMap.h:186
Definition: QtxMap.h:193
IMapConstIterator(const IMapConstIterator &i)
Definition: QtxMap.h:182
const Key & key() const
Definition: QtxMap.h:190
IMapConstIterator & operator--()
Definition: QtxMap.h:197
IMapConstIterator(const IMap< Key, Value > *m, const int index)
Definition: QtxMap.h:201
Indexed map iterator template class.
Definition: QtxMap.h:140
IMapIterator(const IMapIterator &i)
Definition: QtxMap.h:144
IMapIterator(const IMap< Key, Value > *m, const int index)
Definition: QtxMap.h:163
IMapIterator operator--(int)
Definition: QtxMap.h:160
bool operator==(const IMapIterator &i)
Definition: QtxMap.h:146
IMapIterator & operator++()
Definition: QtxMap.h:157
IMapIterator & operator--()
Definition: QtxMap.h:159
IMapIterator()
Definition: QtxMap.h:142
Definition: QtxMap.h:151
IMapIterator operator++(int)
Definition: QtxMap.h:158
Value & value()
Definition: QtxMap.h:152
int myIndex
Definition: QtxMap.h:168
const Value & value() const
Definition: QtxMap.h:153
void init()
Definition: QtxMap.h:164
Value & operator*()
Definition: QtxMap.h:155
bool operator!=(const IMapIterator &i)
Definition: QtxMap.h:147
Definition: QtxMap.h:167
IMapIterator(const IMap< Key, Value > *m)
Definition: QtxMap.h:143
Indexed map template class.
Definition: QtxMap.h:34
const Value operator[](const Key &key) const
Definition: QtxMap.h:105
int size() const
Definition: QtxMap.h:45
Iterator end()
Definition: QtxMap.h:56
int index(const Key &key) const
Definition: QtxMap.h:80
IMap & operator=(const IMap &m)
Definition: QtxMap.h:42
void erase(const Key &key)
Definition: QtxMap.h:113
void erase(Iterator it)
Definition: QtxMap.h:112
Value dummyValue
Definition: QtxMap.h:130
QMap< Key, Value > myData
Definition: QtxMap.h:128
Definition: QtxMap.h:98
bool contains(const Key &key) const
Definition: QtxMap.h:53
IMapIterator< Key, Value > Iterator
Definition: QtxMap.h:36
Value value(const int index)
Definition: QtxMap.h:91
void remove(Iterator it)
Definition: QtxMap.h:115
Iterator replace(const Key &key, const Value &value)
Definition: QtxMap.h:72
void remove(const Key &key)
Definition: QtxMap.h:116
QList< Key > keys() const
Definition: QtxMap.h:51
int count() const
Definition: QtxMap.h:44
Key & key(const int index)
Definition: QtxMap.h:84
QList< Key > myKeys
Definition: QtxMap.h:127
QList< Value > values() const
Definition: QtxMap.h:52
void erase(const int index)
Definition: QtxMap.h:114
IMap()
Definition: QtxMap.h:40
bool empty() const
Definition: QtxMap.h:46
IMap(const IMap &m)
Definition: QtxMap.h:41
ConstIterator at(const int index) const
Definition: QtxMap.h:82
Definition: QtxMap.h:57
void remove(const int index)
Definition: QtxMap.h:117
Iterator insert(const Key &key, const Value &value, bool overwrite=true)
Definition: QtxMap.h:60
Key dummyKey
Definition: QtxMap.h:129
Definition: QtxMap.h:47
Definition: QtxMap.h:58
IMapConstIterator< Key, Value > ConstIterator
Definition: QtxMap.h:37
void clear()
Definition: QtxMap.h:49
Iterator begin()
Definition: QtxMap.h:55
Definition: QtxMap.h:81
