CalciumMacroCInterface.hxx
20/*
21File : CalciumInterface.hxx
22Author : Eric Fayolle (EDF)
23Module : KERNEL
24Modified by : $LastChangedBy$
25Date : $LastChangedDate: 2007-03-01 13:27:58 +0100 (jeu, 01 mar 2007) $
26Id : $Id$
27*/
28
29#ifndef _CALCIUM_MACRO_C_INTERFACE_H_
30#define _CALCIUM_MACRO_C_INTERFACE_H_
31
32
33
34/****** CALCIUM_C2CPP_INTERFACE_HXX_ : ******/
35/****** Declarations: ecp_lecture_... , ecp_ecriture_..., ecp_free_... ******/
36
37#define CALCIUM_C2CPP_INTERFACE_HXX_(_name,_porttype,_type,_qual) \
38 extern "C" CalciumTypes::InfoType ecp_lecture_##_name (void * component, int dependencyType, \
39 CalTimeType< _type _qual >::TimeType * ti, \
40 CalTimeType< _type _qual >::TimeType * tf, long * i, \
41 const char * const nomvar, size_t bufferLength, \
42 size_t * nRead, _type _qual ** data ); \
43 \
44 \
45 extern "C" void ecp_lecture_##_name##_free ( _type _qual * data); \
46 \
47 \
48 extern "C" CalciumTypes::InfoType ecp_ecriture_##_name (void * component, int dependencyType, \
49 CalTimeType< _type _qual >::TimeType *t, \
50 long i, \
51 const char * const nomvar, size_t bufferLength, \
52 _type _qual * data ); \
53
54
55
56
57
58/****** CALCIUM_C2CPP_INTERFACE_CXX_ : ******/
59/******Definitions: ecp_lecture_... , ecp_ecriture_..., ecp_free_... ******/
60#define CALCIUM_C2CPP_INTERFACE_CXX_(_name,_porttype,_type,_qual) \
61 extern "C" CalciumTypes::InfoType ecp_lecture_##_name (void * component, int dependencyType, \
62 CalTimeType< _type _qual >::TimeType * ti, \
63 CalTimeType< _type _qual >::TimeType * tf, long * i, \
64 const char * const nomvar, size_t bufferLength, \
65 size_t * nRead, _type _qual ** data ) \
66 { \
67 Superv_Component_i * _component = static_cast<Superv_Component_i *>(component); \
68 double _ti=0.; \
69 double _tf=0.; \
70 if(dependencyType == CalciumTypes::CP_TEMPS) \
71 { \
72 _ti=*ti; \
73 _tf=*tf; \
74 } \
75 size_t _nRead=0; \
76 size_t _bufferLength=bufferLength; \
77 \
78 if ( IsSameType< _porttype , cplx >::value ) _bufferLength*=2; \
79 DEBTRACE( "-------- CalciumInterface(lecture Inter Part) MARK 1 ------------------" ); \
80 try \
81 { \
82 CalciumInterface::ecp_lecture< _type,_porttype >( *_component, dependencyType, _ti, _tf, *i, nomvar, \
83 _bufferLength, _nRead, *data); \
84 } \
85 catch ( const CalciumException & ex) \
86 { \
87 DEBTRACE( ex.what() ); \
88 return ex.getInfo(); \
89 } \
90 catch ( ... ) \
91 { \
92 DEBTRACE( "Unexpected exception "); \
93 return CalciumTypes::CPATAL; \
94 } \
95 if ( IsSameType< _porttype , cplx >::value ) \
96 { \
97 *nRead=_nRead/2; \
98 DEBTRACE( "-------- CalciumInterface(lecture Inter Part) IsSameType cplx -------------" ); \
99 DEBTRACE( "-------- CalciumInterface(lecture Inter Part) _nRead : " << _nRead ); \
100 DEBTRACE( "-------- CalciumInterface(lecture Inter Part) *nRead : " << *nRead ); \
101 } \
102 else \
103 *nRead = _nRead; \
104 if (dependencyType == CalciumTypes::CP_SEQUENTIEL ) \
105 *ti=(CalTimeType< _type _qual >::TimeType)(_ti); \
106 DEBTRACE( "-------- CalciumInterface(lecture Inter Part), Data Ptr :" << *data ); \
107 return CalciumTypes::CPOK; \
108 } \
109 \
110 \
111 extern "C" void ecp_lecture_##_name##_free ( _type _qual * data) \
112 { \
113 CalciumInterface::ecp_free< _type, _porttype >(data); \
114 } \
115 \
116 \
117 extern "C" CalciumTypes::InfoType ecp_ecriture_##_name (void * component, int dependencyType, \
118 CalTimeType< _type _qual >::TimeType *t, \
119 long i, \
120 const char * const nomvar, size_t bufferLength, \
121 _type _qual * data ) \
122 { \
123 DEBTRACE( "-------- CalciumInterface(ecriture Inter Part) MARK 0 ------------------" ); \
124 Superv_Component_i * _component = static_cast<Superv_Component_i *>(component); \
125 /* Je ne sais pas pourquoi, je n'arrive pas à passer t par valeur : corruption de la pile*/ \
126 double _t=0.; \
127 if(dependencyType == CalciumTypes::CP_TEMPS) \
128 _t=*t; \
129 size_t _bufferLength=bufferLength; \
130 if ( IsSameType< _porttype , cplx >::value ) _bufferLength=_bufferLength*2; \
131 DEBTRACE( "-------- CalciumInterface(ecriture Inter Part) MARK 1 ------------------" ); \
132 try \
133 { \
134 /*printf("-------- CalciumInterface(ecriture Inter Part), cp_name : Nom de la var. de type %s : %s\n",#_type,nomvar);*/ \
135 DEBTRACE( "----------->-" << nomvar ); \
136 CalciumInterface::ecp_ecriture< _type, _porttype >( *_component, dependencyType, \
137 _t,i,nomvar,_bufferLength,*data); \
138 } \
139 catch ( const CalciumException & ex) \
140 { \
141 DEBTRACE( ex.what() ); \
142 return ex.getInfo(); \
143 } \
144 catch ( ... ) \
145 { \
146 DEBTRACE("Unexpected exception " ); \
147 return CalciumTypes::CPATAL; \
148 } \
149 DEBTRACE( "-------- CalciumInterface(ecriture Inter Part), Valeur de data :" << data ); \
150 return CalciumTypes::CPOK; \
151 } \
152
153
154#endif
