DF_Label.hxx
20#ifndef DFLABEL_HXX
21#define DFLABEL_HXX
23#include "DF_definitions.hxx"
24#include "DF_Attribute.hxx"
26#include <string>
27#include <vector>
28#include <map>
30class DF_Document;
31
32
34{
35public:
38 void Reset();
39private:
40 int _tag;
41 int _depth;
48 std::map< std::string, DF_Attribute* > _attributes;
49
50 friend class DF_Document;
51 friend class DF_Label;
52 friend class DF_ChildIterator;
53 friend class DF_Attribute;
54};
55
56//Class DF_Label defines a persistence reference in DF_Document that contains a tree of Labels.
57//This reference is named "entry" and is a sequence of tags divided by ":". The root entry is "0:".
58//For example "0:1:1" corresponds the following structure
59// 0_
60// |
61// |_1_
62// |
63// |_ 1
64
65class DF_Label {
66public:
67
68 //Returns a Label by its entry, if isCreated true the Label will be created if not exists
69 Standard_EXPORT static DF_Label Label(const DF_Label& theLabel, const std::string& theEntry, bool isCreated = true);
70
71 //Constructors: creates a root label
73
74 //Copy constructor
75 Standard_EXPORT DF_Label(const DF_Label& theLabel);
76
77 //Creates a Label from the LabelNode
79
80 //Operator =
82
83 //Destructor
85
86 //Returns a smart pointer to Document which contains this Label
88
89 //Returns true if theLabel equals to this label
90 Standard_EXPORT bool operator==(const DF_Label& theLabel);
91
92 //Returns true if theLabel doesn't equals to this label
93 Standard_EXPORT bool operator!=(const DF_Label& theLabel);
94
95 //Returns a tag of this Label
96 Standard_EXPORT int Tag() const;
97
98 //Returns true if this Label is attached to the tree in the Document.
100
101 //Searches an Attribute with given ID located on this Label.
102 //Returns true if the Attribute is found.
103 Standard_EXPORT DF_Attribute* FindAttribute(const std::string& theID) const;
104
105 //Returns true if there is an Attribute with given ID on this Label.
106 Standard_EXPORT bool IsAttribute(const std::string& theID) const;
107
108 //Adds theAttribute to the Label where this Attribute is located.
109 //Returns true if theAttribute was added.
110 Standard_EXPORT bool AddAttribute(DF_Attribute* theAttribute) const;
111
112 //Forgets an Attribute with given ID located on the this Label.
113 Standard_EXPORT bool ForgetAttribute(const std::string& theID) const;
114
115 //Forgets all Attributes located on this Label.
116 Standard_EXPORT bool ForgetAllAttributes(bool clearChildren = true) const;
117
118 //Returns Father of this Label.
120
121 //Return true if the label is not initialized
122 Standard_EXPORT bool IsNull() const;
123
124 //Return true if the label is a Root label
125 Standard_EXPORT bool IsRoot() const;
126
127 //Returns true if this Label has Attributes.
128 Standard_EXPORT bool HasAttributes() const;
129
130 //Returns a list of Attributes of this Label.
131 Standard_EXPORT std::vector<DF_Attribute*> GetAttributes() const;
132
133 //Returns true if this Label has a child Label.
134 Standard_EXPORT bool HasChild() const;
135
136 //Returns a number of child Labels.
137 Standard_EXPORT int NbChildren() const;
138
139 //Returns the depth (a number of fathers required to identify the Label) of this Label in the tree.
140 Standard_EXPORT int Depth() const;
141
142 //Returns true if this Label is a descendant of theLabel.
143 Standard_EXPORT bool IsDescendant(const DF_Label& theLabel);
144
145 //Returns the root Label of a Label tree to which this Label belongs.
147
148 //Finds a child Label of this Label with a given tag. If isCreate = true and there is no child
149 //Label with the given tag, the child Label is created.
150 Standard_EXPORT DF_Label FindChild(int theTag, bool isCreate = true);
151
152 //Creates a new child Label of this Label.
154
155 //Returns a tag of the last child
156 Standard_EXPORT int LastChildTag() const;
157
158 //Returns a string presentation of the entry
159 Standard_EXPORT std::string Entry() const;
160
161 //Returns true if theLabel is the same as me
162 Standard_EXPORT bool IsEqual(const DF_Label& theLabel);
163
164 Standard_EXPORT void dump();
165
166private:
167 //Nullifies the content of the label
168 void Nullify();
169
170friend class DF_Document;
171friend class DF_ChildIterator;
172
173private:
175};
176
177#endif
#define Standard_EXPORT
Definition: DF_definitions.hxx:53
Definition: DF_Attribute.hxx:30
Definition: DF_ChildIterator.hxx:29
Definition: DF_Document.hxx:32
Definition: DF_Label.hxx:34
void Reset()
Definition: DF_Label.cxx:494
std::map< std::string, DF_Attribute * > _attributes
Definition: DF_Label.hxx:48
~DF_LabelNode()
Definition: DF_Label.cxx:480
DF_LabelNode * _father
Definition: DF_Label.hxx:42
DF_LabelNode * _lastChild
Definition: DF_Label.hxx:46
DF_LabelNode * _previous
Definition: DF_Label.hxx:43
int _depth
Definition: DF_Label.hxx:41
DF_LabelNode * _next
Definition: DF_Label.hxx:44
int _tag
Definition: DF_Label.hxx:40
DF_Document * _document
Definition: DF_Label.hxx:47
DF_LabelNode * _firstChild
Definition: DF_Label.hxx:45
DF_LabelNode()
Definition: DF_Label.cxx:467
Definition: DF_Label.hxx:65
Definition: DF_Label.cxx:230
DF_Label NewChild()
Definition: DF_Label.cxx:378
Definition: DF_Label.cxx:395
void Nullify()
Definition: DF_Label.cxx:432
Definition: DF_Label.cxx:265
int Depth() const
Definition: DF_Label.cxx:281
DF_LabelNode * _node
Definition: DF_Label.hxx:174
bool operator!=(const DF_Label &theLabel)
Definition: DF_Label.cxx:116
int Tag() const
Definition: DF_Label.cxx:124
DF_Attribute * FindAttribute(const std::string &theID) const
Definition: DF_Label.cxx:139
DF_Label Root() const
Definition: DF_Label.cxx:305
DF_Label & operator=(const DF_Label &theLabel)
Definition: DF_Label.cxx:89
DF_Document * GetDocument() const
Definition: DF_Label.cxx:102
Definition: DF_Label.cxx:389
bool IsAttached()
Definition: DF_Label.cxx:131
void dump()
Definition: DF_Label.cxx:438
bool ForgetAttribute(const std::string &theID) const
Definition: DF_Label.cxx:172
Definition: DF_Label.cxx:257
bool IsEqual(const DF_Label &theLabel)
Definition: DF_Label.cxx:424
bool IsNull() const
Definition: DF_Label.cxx:216
static DF_Label Label(const DF_Label &theLabel, const std::string &theEntry, bool isCreated=true)
bool AddAttribute(DF_Attribute *theAttribute) const
Definition: DF_Label.cxx:159
bool IsDescendant(const DF_Label &theLabel)
Definition: DF_Label.cxx:289
DF_Label Father() const
Definition: DF_Label.cxx:208
DF_Label()
Definition: DF_Label.cxx:78
bool IsAttribute(const std::string &theID) const
Definition: DF_Label.cxx:150
~DF_Label()
Definition: DF_Label.cxx:96
DF_Label FindChild(int theTag, bool isCreate=true)
Definition: DF_Label.cxx:314
bool operator==(const DF_Label &theLabel)
Definition: DF_Label.cxx:109
std::vector< DF_Attribute * > GetAttributes() const
Definition: DF_Label.cxx:238
bool IsRoot() const
Definition: DF_Label.cxx:222
bool ForgetAllAttributes(bool clearChildren=true) const
Definition: DF_Label.cxx:186
