RegistryService.hxx
23// SALOME Registry : Registry server implementation
24// File : RegistryService.hxx
25// Author : Pascale NOYRET - Antoine YESSAYAN, EDF
26// Module : SALOME
27// $Header$
28//
29# ifndef __RegistryService_h__
30# define __RegistryService_h__
31
32#include "SALOME_Registry.hxx"
33
34#include <SALOMEconfig.h>
35#include CORBA_SERVER_HEADER(SALOME_Registry)
36
37# include <map>
38
39#ifdef WIN32
40#pragma warning(disable:4275) // Disable warning interface non dll
41#pragma warning(disable:4251) // Warning DLL Interface ...
42#endif
43
44class REGISTRY_EXPORT RegistryService : public POA_Registry::Components //, public PortableServer::RefCountServantBase
45{
46
47public :
48 enum Status { UNDEF=-1 , TERMINATED=0 , RUNNING=1 } ;
49
51 {
52 protected :
53 const char* const _ior;
54 const char* const _name;
55 const long _pid ;
56 const char* const _machine;
57 const char* const _adip;
58 const long _uid;
59 const char* const _pwname;
60 const long _ts_start ;
61 const long _difftime;
62 const char* const _cdir ;
63 long _ts_hello ;
64 long _ts_end ;
66 public :
67 friend class RegistryService ;
68
69 client_infos( const Registry::Infos &infos );
71 };
72
73
74
75public :
76 RegistryService(void);
77 virtual ~RegistryService(void);
78
79 void ping();
80 CORBA::Long getPID();
81 virtual CORBA::ULong add (const Registry::Infos & infos);
82 virtual CORBA::ULong size ( void );
83#ifndef WIN32
84 virtual void remove( const CORBA::ULong id );
85 virtual void hello( const CORBA::ULong id );
86#else
87 virtual void remove( CORBA::ULong id );
88 virtual void hello( CORBA::ULong id );
89#endif
90 virtual void end(void);
91
92 virtual Registry::AllInfos *getall(void);
93 virtual Registry::AllInfos *history(void);
94
95 void SessionName( const char *sessionName ) ;
96
97 void SetOrb( CORBA::ORB_ptr orb ) { _orb = CORBA::ORB::_duplicate(orb); return; }
98
99 void Shutdown() { if(!CORBA::is_nil(_orb)) _orb->shutdown(0); }
100
101protected :
102
103 CORBA::ORB_var _orb;
104 const char *_SessionName ;
106 std::map<int,client_infos *> _reg ;
107 std::map<int,client_infos *> _fin ;
108
109 Registry::AllInfos* makeseq(std::map<int,client_infos *> &mymap );
110
111} ;
112
113# endif
#define REGISTRY_EXPORT
Definition: SALOME_Registry.hxx:37
Definition: RegistryService.hxx:51
const char *const _pwname
Definition: RegistryService.hxx:59
long _ts_end
Definition: RegistryService.hxx:64
long _ts_hello
Definition: RegistryService.hxx:63
const long _pid
Definition: RegistryService.hxx:55
const char *const _name
Definition: RegistryService.hxx:54
Definition: RegistryService.hxx:61
Definition: RegistryService.hxx:60
const char *const _ior
Definition: RegistryService.hxx:53
const char *const _adip
Definition: RegistryService.hxx:57
const char *const _cdir
Definition: RegistryService.hxx:62
Status _status
Definition: RegistryService.hxx:65
const long _uid
Definition: RegistryService.hxx:58
const char *const _machine
Definition: RegistryService.hxx:56
Definition: RegistryService.hxx:45
const char * _SessionName
Definition: RegistryService.hxx:104
void Shutdown()
Definition: RegistryService.hxx:99
virtual CORBA::ULong size(void)
Definition: RegistryService.cxx:82
std::map< int, client_infos * > _fin
Definition: RegistryService.hxx:107
virtual CORBA::ULong add(const Registry::Infos &infos)
Definition: RegistryService.cxx:89
Definition: RegistryService.cxx:55
virtual Registry::AllInfos * history(void)
Definition: RegistryService.cxx:156
Registry::AllInfos * makeseq(std::map< int, client_infos * > &mymap)
Definition: RegistryService.cxx:163
void SetOrb(CORBA::ORB_ptr orb)
Definition: RegistryService.hxx:97
Status
Definition: RegistryService.hxx:48
Definition: RegistryService.cxx:49
virtual void hello(const CORBA::ULong id)
Definition: RegistryService.cxx:127
Definition: RegistryService.cxx:141
virtual Registry::AllInfos * getall(void)
Definition: RegistryService.cxx:149
Definition: RegistryService.cxx:245
int _Compteur
Definition: RegistryService.hxx:105
std::map< int, client_infos * > _reg
Definition: RegistryService.hxx:106
CORBA::ORB_var _orb
Definition: RegistryService.hxx:103
void SessionName(const char *sessionName)
Definition: RegistryService.cxx:229
void ping()
Definition: RegistryService.cxx:236
sequence< Infos > AllInfos
a list of information
Definition: SALOME_Registry.idl:54
def remove(path)
Definition: pythonpath_reduction.py:25
orb
Definition: salome.py:122
a struct to collect information about servers (processes)
Definition: SALOME_Registry.idl:37
