SALOMEDSClient_definitions.hxx
1
// Copyright (C) 2007-2026 CEA, EDF, OPEN CASCADE
2
3
// Copyright (C) 2003-2007 OPEN CASCADE, EADS/CCR, LIP6, CEA/DEN,
4
// CEDRAT, EDF R&D, LEG, PRINCIPIA R&D, BUREAU VERITAS
5
6
// This library is free software; you can redistribute it and/or
7
// modify it under the terms of the GNU Lesser General Public
8
// License as published by the Free Software Foundation; either
9
// version 2.1 of the License, or (at your option) any later version.
10
11
// This library is distributed in the hope that it will be useful,
12
// but WITHOUT ANY WARRANTY; without even the implied warranty of
13
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
14
// Lesser General Public License for more details.
15
16
// You should have received a copy of the GNU Lesser General Public
17
// License along with this library; if not, write to the Free Software
18
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
20
// See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
21
23
#ifndef SALOMEDSCLIENT_DEF_HXX
24
#define SALOMEDSCLIENT_DEF_HXX
26
#ifdef WIN32
27
# if defined SALOMEDSCLIENT_EXPORTS || defined SalomeDSClient_EXPORTS
28
# define SALOMEDSCLIENT_EXPORT __declspec( dllexport )
# else
30
# define SALOMEDSCLIENT_EXPORT __declspec( dllimport )
31
# endif
32
#else
33
34
#endif
35
36
#include <boost/shared_ptr.hpp>
37
38
template
T>
clt_shared_ptr
public
boost::shared_ptr<T>
39
40
public
41
clt_shared_ptr
42
43
template
Y>
44
explicit
clt_shared_ptr
(Y * p)
45
46
boost::shared_ptr<T>::reset(p);
47
48
49
template
Y>
50
clt_shared_ptr
clt_shared_ptr<Y>
const
& r):
51
boost::shared_ptr<T>(boost::dynamic_pointer_cast<T,Y>(r))
52
53
54
template
Y>
55
clt_shared_ptr
operator=
clt_shared_ptr<Y>
const
& r)
56
57
clt_shared_ptr<T>
(r).swap(*
this
58
return
this
59
60
61
template
Y>
clt_shared_ptr
operator()
(Y * p)
// Y must be complete
62
63
if
(T* pt =
dynamic_cast<
T*
(p))
64
boost::shared_ptr<T>::reset(pt);
65
else
66
boost::throw_exception(std::bad_cast());
67
return
this
68
69
70
71
72
#define _PTR(Class) clt_shared_ptr<SALOMEDSClient_##Class>
73
#define _CAST(Class, shared_ptr_Obj) dynamic_cast<SALOMEDS_##Class*>(shared_ptr_Obj.get())
74
75
struct
STextColor
76
77
double
R
78
double
G
79
double
B
80
81
82
#endif
clt_shared_ptr
Definition:
SALOMEDSClient_definitions.hxx:39
clt_shared_ptr::clt_shared_ptr
clt_shared_ptr()
Definition:
SALOMEDSClient_definitions.hxx:41
clt_shared_ptr::operator=
clt_shared_ptr & operator=(clt_shared_ptr< Y > const &r)
Definition:
SALOMEDSClient_definitions.hxx:55
clt_shared_ptr(clt_shared_ptr< Y > const &r)
Definition:
SALOMEDSClient_definitions.hxx:50
clt_shared_ptr(Y *p)
Definition:
SALOMEDSClient_definitions.hxx:44
clt_shared_ptr::operator()
clt_shared_ptr & operator()(Y *p)
Definition:
SALOMEDSClient_definitions.hxx:61
STextColor
Definition:
SALOMEDSClient_definitions.hxx:76
STextColor::G
double G
Definition:
SALOMEDSClient_definitions.hxx:78
STextColor::B
double B
Definition:
SALOMEDSClient_definitions.hxx:79
STextColor::R
double R
Definition:
SALOMEDSClient_definitions.hxx:77
SALOMEDSClient
