SALOMEDSImpl_AttributeString.hxx
23// File : SALOMEDSImpl_AttributeIOR.hxx
24// Author : Sergey RUIN
25// Module : SALOME
26//
27#ifndef _SALOMEDSImpl_AttributeString_HeaderFile
28#define _SALOMEDSImpl_AttributeString_HeaderFile
30#include "DF_Attribute.hxx"
31#include <string>
32#include "DF_Label.hxx"
34
35
37{
38private:
39
40 std::string myString;
41
42public:
43
44Standard_EXPORT static const std::string& GetID() ;
45
47
48Standard_EXPORT static SALOMEDSImpl_AttributeString* Set(const DF_Label& L, const std::string& Val);
49Standard_EXPORT void SetValue (const std::string& S);
50Standard_EXPORT std::string Value() const { return myString; }
51
52Standard_EXPORT virtual std::string Save() { return myString; }
53Standard_EXPORT virtual void Load(const std::string& theValue) { myString = theValue; }
54
55Standard_EXPORT const std::string& ID() const;
60
61};
62
63#endif
#define Standard_EXPORT
Definition: DF_definitions.hxx:53
Definition: DF_Attribute.hxx:30
Definition: DF_Label.hxx:65
Definition: SALOMEDSImpl_AttributeString.hxx:37
Standard_EXPORT void Restore(DF_Attribute *with)
Definition: SALOMEDSImpl_AttributeString.cxx:90
static Standard_EXPORT SALOMEDSImpl_AttributeString * Set(const DF_Label &L, const std::string &Val)
Definition: SALOMEDSImpl_AttributeString.cxx:39
static Standard_EXPORT const std::string & GetID()
Definition: SALOMEDSImpl_AttributeString.cxx:33
Standard_EXPORT void SetValue(const std::string &S)
Definition: SALOMEDSImpl_AttributeString.cxx:57
Standard_EXPORT DF_Attribute * NewEmpty() const
Definition: SALOMEDSImpl_AttributeString.cxx:81
Standard_EXPORT ~SALOMEDSImpl_AttributeString()
Definition: SALOMEDSImpl_AttributeString.hxx:59
Standard_EXPORT void Paste(DF_Attribute *into)
Definition: SALOMEDSImpl_AttributeString.cxx:100
virtual Standard_EXPORT std::string Save()
Definition: SALOMEDSImpl_AttributeString.hxx:52
Definition: SALOMEDSImpl_AttributeString.hxx:50
Standard_EXPORT SALOMEDSImpl_AttributeString()
Definition: SALOMEDSImpl_AttributeString.hxx:46
Definition: SALOMEDSImpl_AttributeString.hxx:40
Standard_EXPORT const std::string & ID() const
Definition: SALOMEDSImpl_AttributeString.cxx:75
virtual Standard_EXPORT void Load(const std::string &theValue)
Definition: SALOMEDSImpl_AttributeString.hxx:53
Definition: SALOMEDSImpl_GenericAttribute.hxx:39
