SALOMEDS_Attributes_wrap.hxx
23#ifndef __SALOMEDS_Attributes_wrap_HXX__
24#define __SALOMEDS_Attributes_wrap_HXX__
26// Define wrapper classes for SALOMEDS interfaces to replace
27// e.g. SALOMEDS::SObject_var by SALOMEDS::SObject_wrap etc.
28// Use of these wrappers is needed to avoid memory leaks, since
29// for example all methods returning SALOMEDS::SObject_ptr create
30// a new instance of SALOMEDSImpl_SObject_i which will be lost if
31// UnRegister() is not called. The defined wrappers call UnRegister()
32// at destruction thus preventing memory leaks.
33//
34// NOTES
35// - To pass XXX_wrap object to an XXX_out corba variable, call XXX_wrap::inout()
36// - Do not pass the same CORBA Attribute to two AttributeXXX_wrap's. Example of bad code:
37// SALOMEDS::GenericAttribute_wrap anAttr = /// it will UnRegister() the found object
38// aStudyBuilder->FindOrCreateAttribute(aSO, "AttributePythonObject");
39// SALOMEDS::AttributePythonObject_wrap pyAttr = /// IT MUST BE _var, not _wrap !!!!!!!
40// SALOMEDS::AttributePythonObject::_narrow(anAttr);
41
43namespace SALOMEDS
44{
75}
76
77#endif
Definition: SALOME_GenericObj_wrap.hxx:69
This package contains the interfaces used for creation, management and modification of the Study.
Definition: SALOMEDS.hxx:37
SALOME::GenericObj_wrap< AttributeTableOfString > AttributeTableOfString_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:66
SALOME::GenericObj_wrap< AttributePythonObject > AttributePythonObject_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:68
SALOME::GenericObj_wrap< AttributeSequenceOfReal > AttributeSequenceOfReal_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:51
SALOME::GenericObj_wrap< AttributeTextColor > AttributeTextColor_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:59
SALOME::GenericObj_wrap< AttributeString > AttributeString_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:74
SALOME::GenericObj_wrap< AttributeExternalFileDef > AttributeExternalFileDef_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:69
SALOME::GenericObj_wrap< AttributeTextHighlightColor > AttributeTextHighlightColor_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:60
SALOME::GenericObj_wrap< AttributeDrawable > AttributeDrawable_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:55
SALOME::GenericObj_wrap< AttributeStudyProperties > AttributeStudyProperties_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:67
SALOME::GenericObj_wrap< AttributeSelectable > AttributeSelectable_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:56
SALOME::GenericObj_wrap< AttributeReal > AttributeReal_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:48
SALOME::GenericObj_wrap< AttributeInteger > AttributeInteger_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:47
SALOME::GenericObj_wrap< AttributeFileType > AttributeFileType_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:70
SALOME::GenericObj_wrap< AttributeTarget > AttributeTarget_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:63
SALOME::GenericObj_wrap< AttributeTreeNode > AttributeTreeNode_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:49
SALOME::GenericObj_wrap< AttributePixMap > AttributePixMap_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:61
SALOME::GenericObj_wrap< AttributeComment > AttributeComment_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:46
SALOME::GenericObj_wrap< AttributeOpened > AttributeOpened_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:58
SALOME::GenericObj_wrap< AttributeParameter > AttributeParameter_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:73
SALOME::GenericObj_wrap< AttributeUserID > AttributeUserID_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:50
SALOME::GenericObj_wrap< AttributeGraphic > AttributeGraphic_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:72
SALOME::GenericObj_wrap< AttributePersistentRef > AttributePersistentRef_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:54
SALOME::GenericObj_wrap< AttributeIOR > AttributeIOR_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:53
SALOME::GenericObj_wrap< AttributeFlags > AttributeFlags_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:71
SALOME::GenericObj_wrap< AttributeSequenceOfInteger > AttributeSequenceOfInteger_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:52
SALOME::GenericObj_wrap< AttributeExpandable > AttributeExpandable_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:57
SALOME::GenericObj_wrap< AttributeTableOfInteger > AttributeTableOfInteger_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:64
SALOME::GenericObj_wrap< AttributeTableOfReal > AttributeTableOfReal_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:65
SALOME::GenericObj_wrap< AttributeLocalID > AttributeLocalID_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:62
SALOME::GenericObj_wrap< AttributeName > AttributeName_wrap
Definition: SALOMEDS_Attributes_wrap.hxx:45
