SALOMESDS_AutoRefCountPtr.hxx
19// Author : Anthony Geay (EDF R&D)
20
21#ifndef __SALOMESDS_AUTOREFCOUNTPTR_HXX__
22#define __SALOMESDS_AUTOREFCOUNTPTR_HXX__
23
26#include "omniORB4/CORBA.h"
27
28namespace SALOMESDS
29{
30 class POAHolder : public virtual PortableServer::ServantBase
31 {
32 public:
33 virtual PortableServer::POA_var getPOA() const = 0;
34 CORBA::Object_var activate()
35 {
36 PortableServer::POA_var poa(getPOA());
37 PortableServer::ObjectId_var id;
38 try
39 {
40 id=poa->activate_object(this);
41 }
42 catch(PortableServer::POA::ServantAlreadyActive& /*e*/)
43 {
44 id=poa->servant_to_id(this);
45 }
46 CORBA::Object_var ret(poa->id_to_reference(id));
47 return ret;
48 }
49
51 {
52 PortableServer::POA_var poa(getPOA());
53 PortableServer::ObjectId_var oid(poa->servant_to_id(this));
54 poa->deactivate_object(oid);
55 _remove_ref();
56 }
57 };
58
59 template<class T>
61 {
62 public:
63 AutoRefCountPtr(const AutoRefCountPtr& other):_ptr(0) { referPtr(other._ptr); }
64 AutoRefCountPtr(T *ptr=0):_ptr(ptr) { }
66 bool operator==(const AutoRefCountPtr& other) const { return _ptr==other._ptr; }
67 bool operator==(const T *other) const { return _ptr==other; }
68 AutoRefCountPtr &operator=(const AutoRefCountPtr& other) { if(_ptr!=other._ptr) { destroyPtr(); referPtr(other._ptr); } return *this; }
69 AutoRefCountPtr &operator=(T *ptr) { if(_ptr!=ptr) { destroyPtr(); _ptr=ptr; } return *this; }
70 T *operator->() { return _ptr ; }
71 const T *operator->() const { return _ptr; }
72 T& operator*() { return *_ptr; }
73 const T& operator*() const { return *_ptr; }
74 operator T *() { return _ptr; }
75 operator const T *() const { return _ptr; }
76 T *retn() { if(_ptr) _ptr->incrRef(); return _ptr; }
77 private:
78 void referPtr(T *ptr) { _ptr=ptr; if(_ptr) _ptr->incrRef(); }
79 void destroyPtr() { if(_ptr) _ptr->decrRef(); }
80 private:
81 T *_ptr;
82 };
83
84 template<class T, class U>
86 {
87 T *subPtr(autoSubPtr);
88 U *ptr(dynamic_cast<U *>(subPtr));
90 if(ptr)
91 ptr->incrRef();
92 return ret;
93 }
94
95 template<class T, class U>
97 {
98 T *subPtr(autoSubPtr);
99 U *ptr(dynamic_cast<U *>(subPtr));
100 if(subPtr && !ptr)
101 throw Exception("DynamicCastSafe : U is not a subtype of T !");
103 if(ptr)
104 ptr->incrRef();
105 return ret;
106 }
107
108 template<class T>// T is expected to be a POAHolder subclass
110 {
111 public:
112 AutoServantPtr(T *ptr=0):_ptr(ptr) { }
114 bool operator==(const AutoServantPtr& other) const { return _ptr==other._ptr; }
115 bool operator==(const T *other) const { return _ptr==other; }
116 AutoServantPtr &operator=(T *ptr) { if(_ptr!=ptr) { destroyPtr(); _ptr=ptr; } return *this; }
117 T *operator->() { return _ptr ; }
118 const T *operator->() const { return _ptr; }
119 T& operator*() { return *_ptr; }
120 const T& operator*() const { return *_ptr; }
121 operator T *() { return _ptr; }
122 operator const T *() const { return _ptr; }
123 bool isNull() const { return _ptr==NULL; }
124 private:
126 {
127 if(!_ptr)
128 return;
129 _ptr->enforcedRelease();
130 }
131 private:
133 };
134}
135
136#endif
Definition: SALOMESDS_AutoRefCountPtr.hxx:61
void destroyPtr()
Definition: SALOMESDS_AutoRefCountPtr.hxx:79
Definition: SALOMESDS_AutoRefCountPtr.hxx:64
T * operator->()
Definition: SALOMESDS_AutoRefCountPtr.hxx:70
AutoRefCountPtr & operator=(T *ptr)
Definition: SALOMESDS_AutoRefCountPtr.hxx:69
~AutoRefCountPtr()
Definition: SALOMESDS_AutoRefCountPtr.hxx:65
const T * operator->() const
Definition: SALOMESDS_AutoRefCountPtr.hxx:71
AutoRefCountPtr(const AutoRefCountPtr &other)
Definition: SALOMESDS_AutoRefCountPtr.hxx:63
AutoRefCountPtr & operator=(const AutoRefCountPtr &other)
Definition: SALOMESDS_AutoRefCountPtr.hxx:68
T & operator*()
Definition: SALOMESDS_AutoRefCountPtr.hxx:72
Definition: SALOMESDS_AutoRefCountPtr.hxx:78
Definition: SALOMESDS_AutoRefCountPtr.hxx:67
const T & operator*() const
Definition: SALOMESDS_AutoRefCountPtr.hxx:73
bool operator==(const AutoRefCountPtr &other) const
Definition: SALOMESDS_AutoRefCountPtr.hxx:66
T * retn()
Definition: SALOMESDS_AutoRefCountPtr.hxx:76
T * _ptr
Definition: SALOMESDS_AutoRefCountPtr.hxx:81
Definition: SALOMESDS_AutoRefCountPtr.hxx:110
T * operator->()
Definition: SALOMESDS_AutoRefCountPtr.hxx:117
AutoServantPtr & operator=(T *ptr)
Definition: SALOMESDS_AutoRefCountPtr.hxx:116
Definition: SALOMESDS_AutoRefCountPtr.hxx:115
T & operator*()
Definition: SALOMESDS_AutoRefCountPtr.hxx:119
Definition: SALOMESDS_AutoRefCountPtr.hxx:118
Definition: SALOMESDS_AutoRefCountPtr.hxx:112
~AutoServantPtr()
Definition: SALOMESDS_AutoRefCountPtr.hxx:113
void destroyPtr()
Definition: SALOMESDS_AutoRefCountPtr.hxx:125
bool operator==(const AutoServantPtr &other) const
Definition: SALOMESDS_AutoRefCountPtr.hxx:114
bool isNull() const
Definition: SALOMESDS_AutoRefCountPtr.hxx:123
Definition: SALOMESDS_AutoRefCountPtr.hxx:120
T * _ptr
Definition: SALOMESDS_AutoRefCountPtr.hxx:132
Definition: SALOMESDS_Exception.hxx:34
Definition: SALOMESDS_AutoRefCountPtr.hxx:31
Definition: SALOMESDS_AutoRefCountPtr.hxx:34
void enforcedRelease()
Definition: SALOMESDS_AutoRefCountPtr.hxx:50
virtual PortableServer::POA_var getPOA() const =0
Definition: SALOMESDS_AutoRefCountPtr.hxx:29
SALOMESDS::AutoRefCountPtr< U > DynamicCastSafe(typename SALOMESDS::AutoRefCountPtr< T > &autoSubPtr)
Definition: SALOMESDS_AutoRefCountPtr.hxx:96
SALOMESDS::AutoRefCountPtr< U > DynamicCast(typename SALOMESDS::AutoRefCountPtr< T > &autoSubPtr)
Definition: SALOMESDS_AutoRefCountPtr.hxx:85
poa
Definition: SALOME_ContainerPy.py:377
ret
Definition: TestKernelHelpers.py:49
