SALOME_Container_No_NS_Serv_Generic.hxx
1// Copyright (C) 2021-2026 CEA, EDF
23#include "Utils_SALOME_Exception.hxx"
24#include "SALOME_KernelORB.hxx"
25#include "KernelBasis.hxx"
26
27template<class CLS>
28int GenericContainerExecutable(int argc, char* argv[])
29{
30 if(argc<3)
31 THROW_SALOME_EXCEPTION( "SALOME_Container_No_NS_Serv : requires 2 input arguments <containerName> <IOR of Engines::EmbeddedNamingService>" );
32 CORBA::ORB_ptr orb(KERNEL::getORB());
33 std::string IOROfEmbeddedNamingService(argv[2]);
34 setIOROfEmbeddedNS(IOROfEmbeddedNamingService);
35 CORBA::Object_var ns_serv_obj_base = orb->string_to_object(IOROfEmbeddedNamingService.c_str());
36 if( CORBA::is_nil(ns_serv_obj_base) )
37 THROW_SALOME_EXCEPTION( "SALOME_Container_No_NS_Serv : argument 2 is NOT a valid IOR" );
38 Engines::EmbeddedNamingService_var ns_serv_obj = Engines::EmbeddedNamingService::_narrow(ns_serv_obj_base);
39 if( CORBA::is_nil(ns_serv_obj) )
40 THROW_SALOME_EXCEPTION( "SALOME_Container_No_NS_Serv : argument 2 is NOT a valid IOR of Engines::EmbeddedNamingService" );
41 std::unique_ptr<SALOME_NamingService_Container_Abstract> ns( new SALOME_Embedded_NamingService_Client(ns_serv_obj) );
42 return container_common_main<CLS>(argc,argv,std::move(ns));
43}
int GenericContainerExecutable(int argc, char *argv[])
Definition: SALOME_Container_No_NS_Serv_Generic.hxx:28
Definition: SALOME_Embedded_NamingService_Client.hxx:29
CORBA::ORB_ptr getORB()
This function returns a static reference to the orb.
Definition: SALOME_KernelORB.cxx:29
argv
Definition: envSalome.py:42
orb
Definition: salome.py:122
