SALOME_Logger_Server.hxx
23// SALOME Logger : CORBA server managing trace output
24// File : SALOME_Logger_Server.hxx
25// Author : Vasily Rusyaev
26// Module : SALOME
27//
28#if !defined SALOME_Logger_Server_include
29#define SALOME_Logger_Server_include
30
31#include <SALOMEconfig.h>
32#include <fstream>
33
34#ifdef WIN32
35#include <iosfwd>
36#endif
37#include <omnithread.h>
38#include "Logger.hh"
39
40#ifdef WIN32
41# if defined LOGGER_EXPORTS || defined SalomeLoggerServer_EXPORTS
42# define LOGGER_EXPORT __declspec( dllexport )
43# else
44# define LOGGER_EXPORT __declspec( dllimport )
45# endif
46#else
47# define LOGGER_EXPORT
48#endif
49
50#ifdef WIN32
51#pragma warning(disable:4275) // Disable warning interface non dll
52#endif
53
54namespace KERNEL
55{
56 LOGGER_EXPORT SALOME_Logger::Logger_ptr getLoggerServantSA();
57}
58
60 public POA_SALOME_Logger::Logger
61{
62public:
63 //constructor w/o parameters
64 //all messages will be put into terminal via cout
65 Logger();
66 //constructor with parameter, filename is output file
67 //all messages will be put into special file passed as parameter
68 Logger(const char *filename);
69 virtual ~Logger();
70 //put message into one special place for all servers
71 void putMessage(const char* message);
72 void ping();
73 void SetOrb( CORBA::ORB_ptr orb ) { _orb = CORBA::ORB::_duplicate(orb); return; }
74 void shutdown() { if(!CORBA::is_nil(_orb)) _orb->shutdown(0); };
75private:
76 //if m_putIntoFile is true all messages will be put into special
77 //otherwise all messages will be put into terminal via cout
79 //ofstream class specialized for disk file output
80 std::ofstream m_outputFile;
81 //synchronisation object
83
84 CORBA::ORB_ptr _orb;
85};
86
87#endif // !defined(SALOME_Logger_Server_include)
#define LOGGER_EXPORT
Definition: SALOME_Logger_Server.hxx:47
Definition: SALOME_Logger_Server.hxx:61
static omni_mutex myLock
Definition: SALOME_Logger_Server.hxx:82
Definition: SALOME_Logger_Server.hxx:80
bool m_putIntoFile
Definition: SALOME_Logger_Server.hxx:78
void SetOrb(CORBA::ORB_ptr orb)
Definition: SALOME_Logger_Server.hxx:73
void shutdown()
Definition: SALOME_Logger_Server.hxx:74
CORBA::ORB_ptr _orb
Definition: SALOME_Logger_Server.hxx:84
Methods to be used in SSL mode to skip NS.
Definition: SALOME_Container_i.hxx:335
Definition: SALOME_Logger_Server.cxx:39
filename
Definition: pythfilter.py:558
orb
Definition: salome.py:122
