SALOME_ParallelGlobalProcessVar_i.hxx
23// SALOME_ParallelContainer : implementation of container and engine for Parallel Kernel
24// File : SALOME_ParallelContainer_i.hxx
25// Author : André RIBES, EDF
26//
27#ifndef _SALOME_PARALLEL_GLOBALPROCESSVAR_I_HXX_
28#define _SALOME_PARALLEL_GLOBALPROCESSVAR_I_HXX_
30#ifdef WIN32
31# ifdef CONTAINER_EXPORTS
32# define CONTAINER_EXPORT __declspec( dllexport )
33# else
34# define CONTAINER_EXPORT __declspec( dllimport )
35# endif
36#else
37# define CONTAINER_EXPORT
38#endif
39
40#include <SALOMEconfig.h>
41#include <omnithread.h>
42#include <map>
43#include <string>
44
46{
47public:
50
51protected:
52 // Voir commentaire dans le fichier .cxx
53 static std::map<std::string, int> _cntInstances_map;
54 static std::map<std::string, void *> _library_map; // library names, loaded
55 static std::map<std::string, void *> _toRemove_map;// library names to remove
56 static omni_mutex _numInstanceMutex ; // lib and instance protection
57};
58
59#endif
60
#define CONTAINER_EXPORT
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:37
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:46
static std::map< std::string, int > _cntInstances_map
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:53
static std::map< std::string, void * > _toRemove_map
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:55
static std::map< std::string, void * > _library_map
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:54
Definition: SALOME_ParallelGlobalProcessVar_i.hxx:56
