SALOME_Trace.hxx
23// SALOME Logger : CORBA server managing trace output
24// File : SALOME_Trace.cxx
25// Author : Vasily Rusyaev
26// Module : SALOME
27//
28#if !defined(AFX_LOGGER_H__96F2A3AB_F6F8_11D6_BFA6_000476A0958C__INCLUDED_)
29#define AFX_LOGGER_H__96F2A3AB_F6F8_11D6_BFA6_000476A0958C__INCLUDED_
30
31#include <sstream>
32#include <SALOMEconfig.h>
33#include "Logger.hh"
34
35//these declarations for files don't using OCC includes (for example HDF)
36# ifdef WIN32
37
38# ifndef Standard_EXPORT
39# define Standard_EXPORT __declspec( dllexport )
40// For global variables :
41# define Standard_EXPORTEXTERN __declspec( dllexport ) extern
42# define Standard_EXPORTEXTERNC extern "C" __declspec( dllexport )
43# endif /* Standard_EXPORT */
44
45# ifndef Standard_IMPORT
46# define Standard_IMPORT __declspec( dllimport ) extern
47# define Standard_IMPORTC extern "C" __declspec( dllimport )
48# endif /* Standard_IMPORT */
49
50# else /* WIN32 */
51
52# ifndef Standard_EXPORT
53# define Standard_EXPORT
54// For global variables :
55# define Standard_EXPORTEXTERN extern
56# define Standard_EXPORTEXTERNC extern "C"
57# endif /* Standard_EXPORT */
58
59# ifndef Standard_IMPORT
60# define Standard_IMPORT extern
61# define Standard_IMPORTC extern "C"
62# endif /* Standard_IMPORT */
63
64# endif /* WIN32 */
65
66class SALOME_Trace : public std::ostringstream
67{
68public:
69 virtual ~SALOME_Trace();
71 // initializes Logger (if USE_LOGGER variable is set) and returns true, in case success
72 int Initialize(CORBA::ORB_ptr theOrb);
73 Standard_EXPORT void putMessage(std::ostream& msg);
74protected:
75 //disable creation of instances. It's necessary to use static SALOME_Logger& Instance()
77 SALOME_Logger::Logger_var m_pInterfaceLogger;// object reference on Logger server.
79};
80
81#define GLogger SALOME_Trace::Instance()
82
83#endif // !defined(AFX_LOGGER_H__96F2A3AB_F6F8_11D6_BFA6_000476A0958C__INCLUDED_)
#define Standard_EXPORT
Definition: SALOME_Trace.hxx:53
Definition: SALOME_Trace.hxx:77
void putMessage(std::ostream &msg)
Definition: SALOME_Trace.cxx:134
Definition: SALOME_Trace.cxx:55
int isInitialized
Definition: SALOME_Trace.hxx:78
SALOME_Trace()
Definition: SALOME_Trace.cxx:40
Definition: SALOME_Trace.cxx:45
static SALOME_Trace & Instance()
Definition: SALOME_Trace.cxx:49
Definition: SALOME_Trace.py:1
string msg
Definition: TestMinimalExample.py:168
