example16
Methods : GetAvailableUndos, ChangeValue, FindOrCreateAttribute, SaveAs, GetAvailableRedos, Undo, FindComponent, Redo, FindAttribute, Open, CommitCommand, NewCommand.
dir= os.getenv("TmpDir")
if dir == None:
dir = "/tmp"
batchmode_geompy.myBuilder._set_UndoLimit(20)
# 1st transaction -----------------------------------------
batchmode_geompy.myBuilder.NewCommand()
# create AttributeSequenceOfInteger
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(batchmode_geompy.father, "AttributeSequenceOfInteger")
if A == None :
raise RuntimeError, "Can't create AttributeSequenceOfInteger attribute"
A = A._narrow(SALOMEDS.AttributeSequenceOfInteger)
if A == None :
A.Add(100)
A.Add(300)
A.Add(500)
A.Add(400)
A.Add(700)
print("First transaction goes on : HasOpenCommand() = ", batchmode_geompy.myBuilder.HasOpenCommand())
batchmode_geompy.myBuilder.CommitCommand() #--------------
# 2nd transaction ------------------------------------------
A.Remove(3)
A.ChangeValue(4,500)
if batchmode_geompy.myBuilder.GetAvailableUndos() == 0:
raise RuntimeError, "GetAvailableUndos() = 0 but must not !"
if A.Length() != 4:
print("Wrong length of SequenceOfInteger")
if A.Value(1) != 100 or A.Value(2) != 300 or A.Value(3) != 400 or A.Value(4) != 500:
raise RuntimeError, "Wrong value of AttributeSequenceOfInteger"
file1 = dir + "/test1.hdf"
batchmode_geompy.myStudy.SaveAs(file1)
# 1st Undo ---------------------------------------
batchmode_geompy.myBuilder.Undo()
res, A = batchmode_geompy.myBuilder.FindAttribute(batchmode_geompy.father, "AttributeSequenceOfInteger")
if A is None:
raise RuntimeError, "After first 'undo' can't find AttributeSequenceOfInteger"
if A.Length() != 5:
if A.Value(1) != 100 or A.Value(2) != 300 or A.Value(3) != 500 or A.Value(4) != 400 or A.Value(5) != 700:
print( A.Value(1), A.Value(2), A.Value(3), A.Value(4), A.Value(5))
raise RuntimeError, "Wrong value of AttributeSequenceOfInteger after the first 'undo'!"
# save
file2 = dir + "/test2.hdf"
batchmode_geompy.myStudy.SaveAs(file2)
# 2nd Undo ---------------------------------------
res, attr = batchmode_geompy.myBuilder.FindAttribute(batchmode_geompy.father, "AttributeSequenceOfInteger")
if res !=0 or attr != None :
raise RuntimeError, "After the second 'undo' AttributeSequenceOfInteger exists but must not!"
file3 = dir + "/test3.hdf"
batchmode_geompy.myStudy.SaveAs(file3)
#make redo twice ---------------------------------
if batchmode_geompy.myBuilder.GetAvailableRedos() == 0:
raise RuntimeError, "GetAvailableRedos() = 0 but must not !"
batchmode_geompy.myBuilder.Redo()
if res ==0 or A== None :
raise RuntimeError, "AttributeSequenceOfInteger is not found but must be!"
if A.Length() != 4:
openedStudy=batchmode_geompy.myStudy.Open(file1);
if openedStudy == None:
raise RuntimeError, "Can't open saved study!"
father = openedStudy.FindComponent("GEOM")
if father is None:
raise RuntimeError, "Geom component is not found! Wrong study is opened."
# find AttributeSequenceOfInteger
res,A=father.FindAttribute("AttributeSequenceOfInteger")
if res == 0 or A == None:
raise RuntimeError, "Error: not found AttributeSequenceOfInteger"
if A.Length() != 4:
print("Wrong value of AttributeSequenceOfInteger")
openedStudy=batchmode_geompy.myStudy.Open(file2);
if father is None:
if A.Length() != 5:
openedStudy=batchmode_geompy.myStudy.Open(file3);
if father is None:
if res!=0 or A != None:
raise RuntimeError, " AttributeSequenceOfInteger is found but must not!"
