example17
SALOMEDS methods : RemoveAttribute, FindOrCreateAttribute, NewStudy, GetAllAttributes, NewCommand, CommitCommand, AbortCommand, NewComponent.
batchmode_geompy.myBuilder._set_UndoLimit(20)
batchmode_geompy.myBuilder.NewCommand()
child = batchmode_geompy.myBuilder.NewObject(batchmode_geompy.father)
batchmode_geompy.myBuilder.CommitCommand()
# create AttributeSequenceOfReal
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeSequenceOfReal")
if A == None :
raise RuntimeError, "Can't create AttributeSequenceOfReal attribute"
A = A._narrow(SALOMEDS.AttributeSequenceOfReal)
if A == None :
raise RuntimeError, "_narrow returns None instead of AttributeSequenceOfReal pointer"
A.Add(0.0293)
A.Add(522)
A.Add(98234)
A.Add(83.287)
# create AttributeInteger
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeInteger")
if A == None :
raise RuntimeError, "Can't create AttributeInteger attribute"
A = A._narrow(SALOMEDS.AttributeInteger)
A.SetValue(1000000)
if A.Value() != 1000000:
raise RuntimeError, "Error : wrong value of AttributeInteger"
batchmode_geompy.myBuilder.NewCommand() #===================
# create AttributeName
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeName")
if A == None :
raise RuntimeError, "Can't create AttributeName attribute"
A = A._narrow(SALOMEDS.AttributeName)
if A == None :
A.SetValue("AttributesTesting")
if A.Value() != "AttributesTesting":
print("Wrong value of AttributeName")
# create AttributeComment
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeComment")
if A == None :
raise RuntimeError, "Can't create AttributeComment attribute"
A = A._narrow(SALOMEDS.AttributeComment)
if A == None :
A.SetValue("GEOM")
batchmode_geompy.myBuilder.AbortCommand()
# create AttributePersistentRef
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributePersistentRef")
if A == None :
raise RuntimeError, "Can't create AttributePersistentRef attribute"
A = A._narrow(SALOMEDS.AttributePersistentRef)
if A == None :
A.SetValue("/tmp/test;1")
batchmode_geompy.myBuilder.NewCommand() #===================================
# create AttributeDrawable
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeDrawable")
if A == None :
raise RuntimeError, "Can't create AttributeDrawable attribute"
A = A._narrow(SALOMEDS.AttributeDrawable)
if A == None :
A.SetDrawable(1)
if A.IsDrawable() == 0:
"Error: wrong value of AttributeDrawable"
# create AttributeSelectable
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(child, "AttributeSelectable")
if A == None :
raise RuntimeError, "Can't create AttributeSelectable attribute"
A = A._narrow(SALOMEDS.AttributeSelectable)
if A == None :
A.SetSelectable(1)
if A.IsSelectable() == 0:
"Error: wrong value of AttributeSelectable"
batchmode_geompy.myBuilder.RemoveAttribute(child,"AttributeSelectable")
# Control the attributes
res, A = batchmode_geompy.myBuilder.FindAttribute(child, "AttributeComment")
print("res = ", res)
if A != None :
print(" AttributeComment was found")
else:
print(" AttributeComment is not found. It's correct")
attributes=[]
attributes = child.GetAllAttributes()
length = len(attributes)
print("Attributes number = ", length)
print(attributes)
for i in range(0, length) :
attr = attributes[i]
if attr is None :
print(i,"None item of object attributes list")
if length != 5 :
raise RuntimeError, "Wrong number of attributes"
