example20
SALOMEDS methods : FindOrCreateAttribute, SaveAs, FindComponent, FindAttribute, NewCommand, GetProperties, Open, CommitCommand, NewBuilder
Attribute methods : SetLocked, IsLocked, GetCreationMode, SetCreationDate, IsModified, GetUserName, Value, SetUserName, SetValue, GetCreationDate.
batchmode_geompy.myBuilder._set_UndoLimit(20)
# create AttributeReal
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(batchmode_geompy.father, "AttributeReal")
if A == None :
raise RuntimeError, "Can't create AttributeReal attribute"
A = A._narrow(SALOMEDS.AttributeReal)
A.SetValue(0.0001)
if A.Value() != 0.0001:
raise RuntimeError, "Error : wrong value of AttributeReal"
# create AttributeStudyProperties
A = batchmode_geompy.myStudy.GetProperties()
if A == None :
raise RuntimeError, "Can't create AttributeStudyProperties attribute"
A = A._narrow(SALOMEDS.AttributeStudyProperties)
batchmode_geompy.myBuilder.NewCommand();
print("A.GetUserName()= ", A.GetUserName())
res,mm,hh,dd,mnth,yy=A.GetCreationDate()
print("A.GetCreationDate() = ", mm,hh,dd,mnth,yy)
print("A.GetCreationMode() = ", A.GetCreationMode())
print("A.IsModified() = ", A.IsModified())
print("A.IsLocked() = ", A.IsLocked())
if A.IsLocked() == 0 :
A.SetUserName("tester"); print('A.SetUserName("tester"), A.GetUserName() = ', A.GetUserName())
A.SetCreationDate(11,11,11,11,2002); print('A.SetCreationDate(11,11,11,11,2002), A.GetCreationDate() =', A.GetCreationDate())
A.SetLocked(1)
#check the transaction result
batchmode_geompy.myBuilder.CommitCommand()
if A.GetUserName() != "tester":
print('Control after transaction close : A.GetUserName() = ', A.GetUserName())
raise RuntimeError, "Field 'UserName' was not modified but had to!"
# try to make some changes wrapped by transaction
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(batchmode_geompy.father, "AttributeInteger")
if A == None :
raise RuntimeError, "Can't create AttributeInteger attribute"
A = A._narrow(SALOMEDS.AttributeInteger)
A.SetValue(1000000)
exception_was = None
try : batchmode_geompy.myBuilder.CommitCommand()
except Exception: exception_was = 1
if exception_was is None:
raise RuntimeError, "Study was locked for changes but CommitCommand did not generate an exception !"
# save / restore study
str= os.getenv("TmpDir")
if str == None:
str = "/tmp"
file = str+"/test.hdf"
print(" ------- We will save to", file, "-----------")
batchmode_geompy.myStudy.SaveAs(file)
#--------------------------- Open file ------------------------------------#
print" -------------- Open " + file + "-------------- "
openedStudy = batchmode_geompy.myStudy.Open(file)
if openedStudy == None:
raise RuntimeError, "Can't open saved study!"
father = openedStudy.FindComponent("GEOM")
if father is None:
raise RuntimeError, "Geom component is not found! Wrong study is opened."
#1. find AttributeReal
res,A=father.FindAttribute("AttributeReal")
if res == 0 or A == None:
raise RuntimeError, "Error: not found AttributeReal"
#2. find AttributeStudyProperties
A=openedStudy.GetProperties()
raise RuntimeError, "Error: not found AttributeStudyProperties"
raise RuntimeError, "Error : AttributeStudyProperties must have Locked flag but have no!"
#get the builder
myBuilder = openedStudy.NewBuilder()
#3. try to make some changes wrapped by transaction
try :
A = myBuilder.FindOrCreateAttribute(father, "AttributeInteger")
if A == None :
A.SetValue(1000000)
A.SetLocked(0)
#4.
A.SetLocked(0);
print("A.GetCreationDate() = ", A.GetCreationDate())
#5.
A.SetUserName("tester1")
#remove the document file
os.remove(file)
