example21
SALOMEDS methods : FindOrCreateAttribute, SaveAs, FindComponent, FindAttribute, Open
Attribute methods: GetValue, GetNbColumns, AddColumn, SetRowTitles, PutValue, GetColumn, GetColumnTitles, GetTitle, SetRow, GetRowTitles, SetColumnTitles, SetColumn, GetRow, GetNbRows, SetColumnTitle, AddRow, SetTitle, SetRowTitle.
# create AttributeReal
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(batchmode_geompy.father, "AttributeTableOfInteger")
if A == None :
raise RuntimeError, "Can't create AttributeTableOfInteger attribute"
A = A._narrow(SALOMEDS.AttributeTableOfInteger)
a=[1,2]
b=[3,4]
# 2x2
# --- rows ---
A.AddRow(a)
A.AddRow(b)
a=[34,14]
A.SetRow(1,a)
# 3x3
b=[54,56]
A.AddRow(b)
# --- columns ---
a=[76,25,12]
A.AddColumn(a)
a=[836,3425,342]
A.SetColumn(3,a)
# change attribute values
print("A.GetValue(2,2) = ", A.GetValue(2,2))
print("A.PutValue(2,2,625323)")
A.PutValue(625323,2,2)
#set Titles
A.SetTitle("TEST")
A.SetRowTitle(1,"FR")
A.SetRowTitle(2,"SR")
A.SetRowTitle(3,"TR")
A.SetColumnTitle(1,"FC")
A.SetColumnTitle(2,"SC")
A.SetColumnTitle(3,"TC")
#check the table
print("Common title : ",A.GetTitle())
print("Rows titles : ", A.GetRowTitles())
rnb = A.GetNbRows()
for i in range(1, rnb):
b=A.GetRow(i)
print(b)
cnb = A.GetNbColumns()
print("Columns title : ", A.GetColumnTitles())
for i in range(1, cnb):
b=A.GetColumn(i)
print(b)
# set titles
#titles=["11","12","13"]
#A.SetRowTitles(titles)
#titles=["21","22","23"]
#A.SetRowTitles(2,titles)
#titles=["31","32","33"]
#A.SetRowTitles(3,titles)
# ----------------------- save the study ----------------------------------#
str= os.getenv("TmpDir")
if str == None:
str = "/tmp"
file = str+"/test.hdf"
print(" ------- We will save to", file, "-----------")
batchmode_geompy.myStudy.SaveAs(file)
#---------------------------- Open file -----------------------------------#
print" -------------- Open " + file + "-------------- "
openedStudy=batchmode_geompy.myStudy.Open(file)
if openedStudy == None:
raise RuntimeError, "Can't open saved study!"
father = openedStudy.FindComponent("GEOM")
if father is None:
raise RuntimeError, "Geom component is not found! Wrong study is opened."
# --- check attribute ---
res,A=father.FindAttribute("AttributeTableOfInteger")
if res == 0 or A == None:
raise RuntimeError, "Error: not found AttributeTableOfInteger"
#check the table
rnb = A.GetNbRows()
b=A.GetRow(i)
print(b)
b=A.GetColumn(i)
print(b)
titles=["ff","ss","tt"]
titles=["ww","zz","cc"]
A.SetColumnTitles(titles)
print("Column titles : ", A.GetColumnTitles())
