example3
AttributeSequenceOfReal interface(creations/saving/restoring)
AttributeSequenceOfReal : ChangeValue, Add, Value, Remove, Length
SALOMEDS methods : FindOrCreateAttribute, SaveAs, FindComponent, FindAttribute, Open.
# create AttributeSequenceOfReal
A = batchmode_geompy.myBuilder.FindOrCreateAttribute(batchmode_geompy.father, "AttributeSequenceOfReal")
if A == None :
raise RuntimeError, "Can't create AttributeSequenceOfReal attribute"
A = A._narrow(SALOMEDS.AttributeSequenceOfReal)
if A == None :
raise RuntimeError, "_narrow returns None instead of AttributeSequenceOfReal pointer"
A.Add(0.0293)
A.Add(625.1e+2)
A.Add(0.928e+100)
A.Add(83.287)
print("initial values ",A.Value(1), A.Value(2), A.Value(3), A.Value(4))
A.Remove(3)
print("after remove ", A.Value(1), A.Value(2), A.Value(3))
A.ChangeValue(2,76.265)
print("after second item change", A.Value(1), A.Value(2), A.Value(3))
if A.Length() != 3:
print("Error : wrong length of SequenceOfReal")
if A.Value(1) != 0.0293 or A.Value(2) != 76.265 or A.Value(3) != 83.287:
print("Error : wrong value of AttributeSequenceOfReal")
# save / restore study
str= os.getenv("TmpDir")
if str == None:
str = "/tmp"
file = str+"/test.hdf"
batchmode_geompy.myStudy.SaveAs(file)
openedStudy=batchmode_geompy.myStudy.Open(file);
if openedStudy == None:
raise RuntimeError, "Can't open saved study!"
father = openedStudy.FindComponent("GEOM")
if father is None:
raise RuntimeError, "Geom component is not found! Wrong study is opened."
# find AttributeSequenceOfReal
res,A=father.FindAttribute("AttributeSequenceOfReal")
if res == 0 or A == None:
raise RuntimeError, "Error: not found AttributeSequenceOfReal"
if A.Length() != 3:
print("after restoring ", A.Value(1), A.Value(2), A.Value(3))
