Config_WidgetAPI.h
20#ifndef CONFIG_WIDGETAPI_H_
21#define CONFIG_WIDGETAPI_H_
23#include <Config_def.h>
24
25#include <cstdarg>
26#include <string>
27
28//>> Forward declaration of xmlNodePtr.
29typedef struct _xmlNode xmlNode;
30typedef xmlNode *xmlNodePtr;
31struct _xmlNode;
32//<<
33
34//>> Forward declaration of xmlDocPtr.
35typedef struct _xmlDoc xmlDoc;
36typedef xmlDoc *xmlDocPtr;
37struct _xmlDoc;
38//<<
39
46{
47 public:
48 CONFIG_EXPORT virtual ~Config_WidgetAPI();
49
51 CONFIG_EXPORT std::string widgetType() const;
53 CONFIG_EXPORT bool isGroupBoxWidget() const;
56 CONFIG_EXPORT bool isPagedWidget() const;
57
59 CONFIG_EXPORT std::string featureId() const;
61 CONFIG_EXPORT std::string widgetId() const;
63 CONFIG_EXPORT std::string widgetIcon() const;
65 CONFIG_EXPORT std::string widgetLabel() const;
67 CONFIG_EXPORT std::string widgetTooltip() const;
69 CONFIG_EXPORT std::string getProperty(const char* thePropName) const;
70
78 CONFIG_EXPORT bool getBooleanAttribute(const char* theAttributeName, bool theDefault) const;
79
81 CONFIG_EXPORT Config_WidgetAPI(std::string theRawXml, const std::string theAttributePrefix = "");
83 CONFIG_EXPORT bool toNextWidget();
85 CONFIG_EXPORT bool toChildWidget();
87 CONFIG_EXPORT bool toParentWidget();
88
89 private:
90 xmlDocPtr myDoc;
91 xmlNodePtr myCurrentNode;
92 std::string myFeatureId;
93 std::string myAttributePrefix;
94
95 friend class ModuleBase_WidgetFactory;
96};
97
98#endif /* CONFIG_WIDGETAPI_H_ */
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Pass into the child node of widget's xml definition. If impossible, returns false.
Definition: Config_WidgetAPI.cpp:58
Returns text for label of current widget.
Definition: Config_WidgetAPI.cpp:131
CONFIG_EXPORT bool getBooleanAttribute(const char *theAttributeName, bool theDefault) const
Definition: Config_WidgetAPI.cpp:111
Returns id of current feature.
Definition: Config_WidgetAPI.cpp:116
Pass to the next (sibling) node of widget's xml definition. If impossible, returns false.
Definition: Config_WidgetAPI.cpp:42
Pass into the parent node of widget's xml definition. If impossible, returns false.
Definition: Config_WidgetAPI.cpp:77
CONFIG_EXPORT Config_WidgetAPI(std::string theRawXml, const std::string theAttributePrefix="")
These fields are accessible for ModuleBase_WidgetFactory only.
Definition: Config_WidgetAPI.cpp:29
Returns id of current widget.
Definition: Config_WidgetAPI.cpp:121
Returns name of widget's node (attribute)
Definition: Config_WidgetAPI.cpp:85
Returns true if widget has page type; Page is container widget with combo box control to switch betwe...
Definition: Config_WidgetAPI.cpp:100
Returns true if widget has container type, which means it able to contain other widgets.
Definition: Config_WidgetAPI.cpp:94
Returns text for tooltip of current widget.
Definition: Config_WidgetAPI.cpp:136
CONFIG_EXPORT std::string getProperty(const char *thePropName) const
Returns a custom property of current widget.
Definition: Config_WidgetAPI.cpp:106
Returns icon of current widget.
Definition: Config_WidgetAPI.cpp:126
A class for creation of widgets instances in for property panel using XML deskription of a feature.
Definition: ModuleBase_WidgetFactory.h:41
