20#ifndef FeaturesPlugin_BoundingBox_H_
21#define FeaturesPlugin_BoundingBox_H_
23#include <FeaturesPlugin_BoundingBoxBase.h>
33 inline static const std::string&
ID()
35 static const std::string MY_ID(
"BoundingBox");
42 static const std::string MY_OBJECT_ID(
"main_object");
49 static const std::string MY_X_MIN_COORD_ID(
"xmincoordinate");
50 return MY_X_MIN_COORD_ID;
56 static const std::string MY_Y_MIN_COORD_ID(
"ymincoordinate");
57 return MY_Y_MIN_COORD_ID;
63 static const std::string MY_Z_MIN_COORD_ID(
"zmincoordinate");
64 return MY_Z_MIN_COORD_ID;
70 static const std::string MY_X_MAX_COORD_ID(
"xmaxcoordinate");
71 return MY_X_MAX_COORD_ID;
77 static const std::string MY_Y_MAX_COORD_ID(
"ymaxcoordinate");
78 return MY_Y_MAX_COORD_ID;
84 static const std::string MY_Z_MAX_COORD_ID(
"zmaxcoordinate");
85 return MY_Z_MAX_COORD_ID;
91 static const std::string MY_RESULT_VALUES_ID(
"result_values");
92 return MY_RESULT_VALUES_ID;
98 static const std::string MY_COMPUTE_ID(
"compute");
109 FEATURESPLUGIN_EXPORT
virtual void execute();
116 FEATURESPLUGIN_EXPORT
virtual void attributeChanged(
const std::string& theID);
Base feature to inspect properties of bounding box and create that box for the selected shape.
Definition: FeaturesPlugin_BoundingBoxBase.h:38
Persistence feature to create the bounding box.
Definition: FeaturesPlugin_BoundingBox.h:30
FeaturesPlugin_BoundingBox()
Definition: FeaturesPlugin_BoundingBox.cpp:40
Definition: FeaturesPlugin_BoundingBox.h:103
virtual FEATURESPLUGIN_EXPORT void execute()
Definition: FeaturesPlugin_BoundingBox.cpp:74
static const std::string & Y_MIN_COORD_ID()
Attribute name for y coordinate.
Definition: FeaturesPlugin_BoundingBox.h:54
static const std::string & Z_MAX_COORD_ID()
Attribute name for z max coordinate.
Definition: FeaturesPlugin_BoundingBox.h:82
virtual FEATURESPLUGIN_EXPORT void attributeChanged(const std::string &theID)
Definition: FeaturesPlugin_BoundingBox.cpp:83
virtual FEATURESPLUGIN_EXPORT void initAttributes()
Definition: FeaturesPlugin_BoundingBox.cpp:45
static const std::string & Y_MAX_COORD_ID()
Attribute name for y max coordinate.
Definition: FeaturesPlugin_BoundingBox.h:75
static const std::string & RESULT_VALUES_ID()
Attribute name for values of result.
Definition: FeaturesPlugin_BoundingBox.h:89
static const std::string & Z_MIN_COORD_ID()
Attribute name for z coordinate.
Definition: FeaturesPlugin_BoundingBox.h:61
Bounding box kind.
Definition: FeaturesPlugin_BoundingBox.h:33
static const std::string & OBJECT_ID()
Attribute name for object selected.
Definition: FeaturesPlugin_BoundingBox.h:40
virtual FEATURESPLUGIN_EXPORT AttributePtr attributResultValues()
Return Attribute values of result.
Definition: FeaturesPlugin_BoundingBox.cpp:159
static const std::string & X_MAX_COORD_ID()
Attribute name for x max coordinate.
Definition: FeaturesPlugin_BoundingBox.h:68
static const std::string & COMPUTE_ID()
Attribute name for indicate to compute the bounding box.
Definition: FeaturesPlugin_BoundingBox.h:96
static const std::string & X_MIN_COORD_ID()
Attribute name for x coordinate.
Definition: FeaturesPlugin_BoundingBox.h:47
