FeaturesPlugin_Partition.h
20#ifndef FeaturesPlugin_Partition_H_
21#define FeaturesPlugin_Partition_H_
23#include "FeaturesPlugin_VersionedBoolean.h"
24#include <ModelAPI_Feature.h>
26#include <GeomAlgoAPI_Partition.h>
27
33{
34public:
36 inline static const std::string& ID()
37 {
38 static const std::string MY_ID("Partition");
39 return MY_ID;
40 }
41
43 inline static const std::string& BASE_OBJECTS_ID()
44 {
45 static const std::string MY_BASE_OBJECTS_ID("base_objects");
46 return MY_BASE_OBJECTS_ID;
47 }
48
50 inline static const std::string& USE_FUZZY_ID()
51 {
52 static const std::string MY_USE_FUZZY_ID("use_fuzzy");
53 return MY_USE_FUZZY_ID;
54 }
55
57 inline static const std::string& FUZZY_PARAM_ID()
58 {
59 static const std::string MY_FUZZY_PARAM_ID("fuzzy_param");
60 return MY_FUZZY_PARAM_ID;
61 }
62
64 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
65 {
66 static std::string MY_KIND = FeaturesPlugin_Partition::ID();
67 return MY_KIND;
68 }
69
71 FEATURESPLUGIN_EXPORT virtual void execute();
72
74 FEATURESPLUGIN_EXPORT virtual void initAttributes();
75
78
79private:
81 void storeResult(ListOfShape& theObjects,
82 ListOfShape& thePlanes,
83 const GeomShapePtr theResultShape,
84 const std::shared_ptr<GeomAlgoAPI_MakeShape> theMakeShape,
85 const int theIndex = 0);
86
90 bool cutSubs(GeomAPI_ShapeHierarchy& theHierarchy,
91 ListOfShape& theUsed,
92 ListOfShape& theNotUsed,
93 const double theFuzzy,
94 std::shared_ptr<GeomAlgoAPI_MakeShapeList>& theMakeShapeList,
95 std::string& theError);
96};
97
98#endif
Feature for applying of Partition operations on Shapes.
Definition: FeaturesPlugin_Partition.h:33
Definition: FeaturesPlugin_Partition.cpp:75
FeaturesPlugin_Partition()
Definition: FeaturesPlugin_Partition.cpp:57
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Partition.h:57
Definition: FeaturesPlugin_Partition.h:43
Feature kind.
Definition: FeaturesPlugin_Partition.h:36
Definition: FeaturesPlugin_Partition.cpp:62
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Partition.h:50
Definition: FeaturesPlugin_Partition.h:64
Feature controls a version of Boolean operations.
Definition: FeaturesPlugin_VersionedBoolean.h:40
Storage for the hierarchy of shapes and their parents (compounds or compsolids)
Definition: GeomAPI_ShapeHierarchy.h:34
