FeaturesPlugin_Thickness.h
20#ifndef FeaturesPlugin_Thickness_H_
21#define FeaturesPlugin_Thickness_H_
23#include "FeaturesPlugin.h"
24
26
31{
32public:
35
37 inline static const std::string& ID()
38 {
39 static const std::string MY_ID("Thickness");
40 return MY_ID;
41 }
42
44 inline static const std::string& CREATION_METHOD_ID()
45 {
46 static const std::string MY_CREATION_METHOD_ID("creation_method");
47 return MY_CREATION_METHOD_ID;
48 }
49
51 inline static const std::string& CREATION_METHOD_THICK()
52 {
53 static const std::string MY_CREATION_METHOD_THICK("thickness");
54 return MY_CREATION_METHOD_THICK;
55 }
56
58 inline static const std::string& CREATION_METHOD_HOLLOWED()
59 {
60 static const std::string MY_CREATION_METHOD_HOLLOWED("hollowed_solid");
61 return MY_CREATION_METHOD_HOLLOWED;
62 }
63
65 inline static const std::string& BASE_SHAPE_ID()
66 {
67 static const std::string MY_BASE_SHAPE_ID("base_shape");
68 return MY_BASE_SHAPE_ID;
69 }
70
72 inline static const std::string& FACES_ID()
73 {
74 static const std::string MY_FACES_ID("faces_to_remove");
75 return MY_FACES_ID;
76 }
77
79 inline static const std::string& THICKNESS_VALUE_ID()
80 {
81 static const std::string MY_THICKNESS_VALUE_ID("thickness_value");
82 return MY_THICKNESS_VALUE_ID;
83 }
84
86 inline static const std::string& INSIDE_ID()
87 {
88 static const std::string MY_INSIDE_ID("is_inside");
89 return MY_INSIDE_ID;
90 }
91
92
94 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
95 {
96 static std::string MY_KIND = FeaturesPlugin_Thickness::ID();
97 return MY_KIND;
98 }
99
101 FEATURESPLUGIN_EXPORT virtual void initAttributes();
102
104 FEATURESPLUGIN_EXPORT virtual void execute();
105
108 FEATURESPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
109};
110
111#endif
Feature for thickness.
Definition: FeaturesPlugin_Thickness.h:31
Definition: FeaturesPlugin_Thickness.h:94
static const std::string & CREATION_METHOD_THICK()
Definition: FeaturesPlugin_Thickness.h:51
Definition: FeaturesPlugin_Thickness.cpp:41
Definition: FeaturesPlugin_Thickness.cpp:53
static const std::string & THICKNESS_VALUE_ID()
Attribute name of thickness value.
Definition: FeaturesPlugin_Thickness.h:79
static const std::string & CREATION_METHOD_HOLLOWED()
Definition: FeaturesPlugin_Thickness.h:58
virtual void attributeChanged(const std::string &theID)
Definition: FeaturesPlugin_Thickness.cpp:127
static const std::string & CREATION_METHOD_ID()
Definition: FeaturesPlugin_Thickness.h:44
static const std::string & BASE_SHAPE_ID()
Attribute name of base shape.
Definition: FeaturesPlugin_Thickness.h:65
FeaturesPlugin_Thickness()
Definition: FeaturesPlugin_Thickness.cpp:36
static const std::string & FACES_ID()
Attribute name of sub-faces to remove (for hollowed solid mode).
Definition: FeaturesPlugin_Thickness.h:72
Feature kind.
Definition: FeaturesPlugin_Thickness.h:37
static const std::string & INSIDE_ID()
Attribute name of pipe/intersection joint bool flag.
Definition: FeaturesPlugin_Thickness.h:86
