GeomAPI_Curve.h
20#ifndef GeomAPI_Curve_H_
21#define GeomAPI_Curve_H_
23#include <GeomAPI_Shape.h>
24#include <memory>
26class GeomAPI_Pnt;
27
34{
35 public:
37 GEOMAPI_EXPORT
39
41 GEOMAPI_EXPORT
42 GeomAPI_Curve(const std::shared_ptr<GeomAPI_Shape>& theShape);
43
45 GEOMAPI_EXPORT
46 bool isNull() const;
47
49 GEOMAPI_EXPORT
50 bool isEqual(const std::shared_ptr<GeomAPI_Curve>& theOther) const;
51
53 GEOMAPI_EXPORT
54 virtual bool isLine() const;
55
57 GEOMAPI_EXPORT
58 virtual bool isCircle() const;
59
61 GEOMAPI_EXPORT
62 virtual bool isEllipse() const;
63
65 GEOMAPI_EXPORT
66 double startParam();
67
69 GEOMAPI_EXPORT
70 double endParam();
71
73 GEOMAPI_EXPORT
74 virtual bool isTrimmed() const;
75
77 GEOMAPI_EXPORT
78 virtual std::shared_ptr<GeomAPI_Curve> basisCurve() const;
79
82 GEOMAPI_EXPORT
83 std::shared_ptr<GeomAPI_Pnt> getPoint(double theParam);
84
86 GEOMAPI_EXPORT const std::shared_ptr<GeomAPI_Pnt> project(
87 const std::shared_ptr<GeomAPI_Pnt>& thePoint) const;
88
89public:
92 {
93 public:
95 GEOMAPI_EXPORT
96 bool operator ()(const std::shared_ptr<GeomAPI_Curve>& theCurve1,
97 const std::shared_ptr<GeomAPI_Curve>& theCurve2) const;
98 };
99
100private:
101 double myStart;
102 double myEnd;
103};
104
106typedef std::shared_ptr<GeomAPI_Curve> GeomCurvePtr;
107
108#endif
Compare addresses of curves.
Definition: GeomAPI_Curve.h:92
GEOMAPI_EXPORT bool operator()(const std::shared_ptr< GeomAPI_Curve > &theCurve1, const std::shared_ptr< GeomAPI_Curve > &theCurve2) const
Return true if the address of the first curve is less than the address of the second.
Definition: GeomAPI_Curve.cpp:160
Interface to the generic curve object.
Definition: GeomAPI_Curve.h:34
GEOMAPI_EXPORT double endParam()
Returns end parameter of the curve.
Definition: GeomAPI_Curve.cpp:99
virtual GEOMAPI_EXPORT bool isTrimmed() const
Returns true if the curve is trimmed.
Definition: GeomAPI_Curve.cpp:123
GEOMAPI_EXPORT double startParam()
Returns start parameter of the curve.
Definition: GeomAPI_Curve.cpp:87
virtual GEOMAPI_EXPORT bool isCircle() const
Returns whether the curve is circular.
Definition: GeomAPI_Curve.cpp:77
GEOMAPI_EXPORT bool isNull() const
Returns true if curve is not initialized.
Definition: GeomAPI_Curve.cpp:57
virtual GEOMAPI_EXPORT bool isLine() const
Returns whether the curve is linear.
Definition: GeomAPI_Curve.cpp:72
GEOMAPI_EXPORT bool isEqual(const std::shared_ptr< GeomAPI_Curve > &theOther) const
Returns true if curves are equal.
Definition: GeomAPI_Curve.cpp:118
GEOMAPI_EXPORT GeomAPI_Curve()
Creation of empty (null) shape.
Definition: GeomAPI_Curve.cpp:37
virtual GEOMAPI_EXPORT bool isEllipse() const
Returns whether the curve is elliptic.
Definition: GeomAPI_Curve.cpp:82
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > project(const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
Project point on curve.
Definition: GeomAPI_Curve.cpp:140
virtual GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Curve > basisCurve() const
Returns basis for the trimmed curve.
Definition: GeomAPI_Curve.cpp:128
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > getPoint(double theParam)
Returns point on the curve by parameter.
Definition: GeomAPI_Curve.cpp:111
Definition: GeomAPI_Pnt.h:38
