GeomAPI_Trsf.h
20#ifndef GeomAPI_Trsf_H_
21#define GeomAPI_Trsf_H_
23#include <GeomAPI_Interface.h>
24#include <memory>
26class GeomAPI_Ax1;
27class GeomAPI_Ax2;
28class GeomAPI_Pnt;
36{
37 public:
39 GEOMAPI_EXPORT GeomAPI_Trsf();
41 GEOMAPI_EXPORT GeomAPI_Trsf(void* theTrsf);
42
47 GEOMAPI_EXPORT void setTranslation(const std::shared_ptr<GeomAPI_Ax1> theAxis,
48 const double theDistance);
49
55 GEOMAPI_EXPORT void setTranslation(const double theDx,
56 const double theDy,
57 const double theDz);
58
63 GEOMAPI_EXPORT void setTranslation(const std::shared_ptr<GeomAPI_Pnt> theStartPoint,
64 const std::shared_ptr<GeomAPI_Pnt> theEndPoint);
65
70 GEOMAPI_EXPORT void setRotation(const std::shared_ptr<GeomAPI_Ax1> theAxis,
71 const double theAngle);
72
78 GEOMAPI_EXPORT void setRotation(const std::shared_ptr<GeomAPI_Pnt> theCenterPoint,
79 const std::shared_ptr<GeomAPI_Pnt> theStartPoint,
80 const std::shared_ptr<GeomAPI_Pnt> theEndPoint);
81
85 GEOMAPI_EXPORT void setSymmetry(const std::shared_ptr<GeomAPI_Pnt> thePoint);
86
90 GEOMAPI_EXPORT void setSymmetry(const std::shared_ptr<GeomAPI_Ax1> theAxis);
91
95 GEOMAPI_EXPORT void setSymmetry(const std::shared_ptr<GeomAPI_Ax2> thePlane);
96
101 GEOMAPI_EXPORT void setScale(const std::shared_ptr<GeomAPI_Pnt>& theCenter,
102 const double theScale);
103};
104
106typedef std::shared_ptr<GeomAPI_Trsf> GeomTrsfPtr;
107
108#endif
109
The class represents an axis in 3D space.
Definition: GeomAPI_Ax1.h:31
Definition: GeomAPI_Ax2.h:31
Definition: GeomAPI_Pnt.h:38
Keep the transformation matrix coefficients.
Definition: GeomAPI_Trsf.h:36
Keeps no transformation, it may be set by setImpl.
Definition: GeomAPI_Trsf.cpp:35
GEOMAPI_EXPORT void setTranslation(const std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theDistance)
Sets a translation transformation.
Definition: GeomAPI_Trsf.cpp:47
GEOMAPI_EXPORT void setScale(const std::shared_ptr< GeomAPI_Pnt > &theCenter, const double theScale)
Sets the scaling transformation.
Definition: GeomAPI_Trsf.cpp:111
GEOMAPI_EXPORT void setRotation(const std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theAngle)
Sets a rotation transformation.
Definition: GeomAPI_Trsf.cpp:67
GEOMAPI_EXPORT void setSymmetry(const std::shared_ptr< GeomAPI_Pnt > thePoint)
Sets a point symmetry transformation.
Definition: GeomAPI_Trsf.cpp:93
