GeomAPI_XYZ.h
20#ifndef GeomAPI_XYZ_H_
21#define GeomAPI_XYZ_H_
23#include <GeomAPI_Interface.h>
24#include <memory>
32{
33 public:
35 GEOMAPI_EXPORT
36 GeomAPI_XYZ(const double theX, const double theY, const double theZ);
37
39 GEOMAPI_EXPORT
40 double x() const;
42 GEOMAPI_EXPORT
43 double y() const;
45 GEOMAPI_EXPORT
46 double z() const;
47
49 GEOMAPI_EXPORT
50 void setX(const double theX);
52 GEOMAPI_EXPORT
53 void setY(const double theY);
55 GEOMAPI_EXPORT
56 void setZ(const double theZ);
57
59 GEOMAPI_EXPORT
60 const std::shared_ptr<GeomAPI_XYZ> added(const std::shared_ptr<GeomAPI_XYZ>& theArg);
62 GEOMAPI_EXPORT
63 const std::shared_ptr<GeomAPI_XYZ> decreased(const std::shared_ptr<GeomAPI_XYZ>& theArg);
65 GEOMAPI_EXPORT
66 const std::shared_ptr<GeomAPI_XYZ> multiplied(const double theArg);
67
69 GEOMAPI_EXPORT
70 double dot(const std::shared_ptr<GeomAPI_XYZ>& theArg) const;
72 GEOMAPI_EXPORT
73 const std::shared_ptr<GeomAPI_XYZ> cross(const std::shared_ptr<GeomAPI_XYZ>& theArg) const;
74
76 GEOMAPI_EXPORT
77 double distance(const std::shared_ptr<GeomAPI_XYZ>& theOther) const;
78
80 GEOMAPI_EXPORT double squareModulus() const;
81};
82
84typedef std::shared_ptr<GeomAPI_XYZ> GeomXYZPtr;
85
86#endif
87
3 coordinates: they may represent vector or point or something else
Definition: GeomAPI_XYZ.h:32
GEOMAPI_EXPORT GeomAPI_XYZ(const double theX, const double theY, const double theZ)
Creation by coordinates.
Definition: GeomAPI_XYZ.cpp:26
GEOMAPI_EXPORT double z() const
returns Z coordinate
Definition: GeomAPI_XYZ.cpp:41
Square length of triplet from the origin.
Definition: GeomAPI_XYZ.cpp:102
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > added(const std::shared_ptr< GeomAPI_XYZ > &theArg)
result is sum of coordinates of this and the given argument
Definition: GeomAPI_XYZ.cpp:61
GEOMAPI_EXPORT void setY(const double theY)
sets Y coordinate
Definition: GeomAPI_XYZ.cpp:51
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > multiplied(const double theArg)
result is coordinates multiplied by the argument
Definition: GeomAPI_XYZ.cpp:77
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > decreased(const std::shared_ptr< GeomAPI_XYZ > &theArg)
result is difference between coordinates of this and the given argument
Definition: GeomAPI_XYZ.cpp:69
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > cross(const std::shared_ptr< GeomAPI_XYZ > &theArg) const
result is a cross product of two triplets
Definition: GeomAPI_XYZ.cpp:89
GEOMAPI_EXPORT double dot(const std::shared_ptr< GeomAPI_XYZ > &theArg) const
result is a scalar product of two triplets
Definition: GeomAPI_XYZ.cpp:84
GEOMAPI_EXPORT double y() const
returns Y coordinate
Definition: GeomAPI_XYZ.cpp:36
GEOMAPI_EXPORT void setZ(const double theZ)
sets Z coordinate
Definition: GeomAPI_XYZ.cpp:56
GEOMAPI_EXPORT void setX(const double theX)
sets X coordinate
Definition: GeomAPI_XYZ.cpp:46
GEOMAPI_EXPORT double x() const
returns X coordinate
Definition: GeomAPI_XYZ.cpp:31
GEOMAPI_EXPORT double distance(const std::shared_ptr< GeomAPI_XYZ > &theOther) const
Distance between two triplets.
Definition: GeomAPI_XYZ.cpp:96
