20#ifndef SketchPlugin_Circle_H_
21#define SketchPlugin_Circle_H_
23#include "SketchPlugin.h"
24#include <SketchPlugin_SketchEntity.h>
25#include <SketchPlugin_Sketch.h>
35 inline static const std::string&
ID()
37 static const std::string
ID(
"SketchCircle");
44 static const std::string
ID(
"circle_center");
51 static const std::string
ID(
"add_construction_point");
58 static const std::string
ID(
"circle_construction_point_ref");
65 static const std::string
ID(
"circle_radius");
72 static const std::string
ID(
"circle_angle");
77 SKETCHPLUGIN_EXPORT
virtual const std::string&
getKind()
84 SKETCHPLUGIN_EXPORT
virtual bool isFixed();
90 SKETCHPLUGIN_EXPORT
virtual void execute();
101 void setConstructionPoint();
102 void removeConstructionPoint();
103 std::shared_ptr<GeomAPI_Edge> getCircleShape();
Feature for creation of the new circle in Sketch.
Definition: SketchPlugin_Circle.h:32
virtual void initDerivedClassAttributes()
Initializes attributes of derived class.
Definition: SketchPlugin_Circle.cpp:64
Definition: SketchPlugin_Circle.h:77
Returns true is sketch element is under the rigid constraint.
Definition: SketchPlugin_Circle.cpp:254
static const std::string & CENTER_ID()
2D point - center of the circle
Definition: SketchPlugin_Circle.h:42
Radius of the circle.
Definition: SketchPlugin_Circle.h:63
Definition: SketchPlugin_Circle.cpp:95
Circle feature kind.
Definition: SketchPlugin_Circle.h:35
static const std::string & ANGLE_ID()
Angle of rotation sewing point of the circle.
Definition: SketchPlugin_Circle.h:70
static const std::string & ADD_CONSTRUCTION_POINT_ID()
Is to create construction point or not.
Definition: SketchPlugin_Circle.h:49
SketchPlugin_Circle()
Definition: SketchPlugin_Circle.cpp:58
virtual void attributeChanged(const std::string &theID)
Definition: SketchPlugin_Circle.cpp:259
static const std::string & CONSTRUCTION_POINT_REF_ID()
Contain created point as feature.
Definition: SketchPlugin_Circle.h:56
Sketch Entity for creation of the new feature in PartSet.
Definition: SketchPlugin_SketchEntity.h:45
