SketchPlugin_Constraint.h
20#ifndef SketchPlugin_Constraint_H_
21#define SketchPlugin_Constraint_H_
23#include <SketchPlugin_Feature.h>
24#include <ModelAPI_AttributeDouble.h>
26#include <string>
27#include <limits>
28
30const int CONSTRAINT_ATTR_SIZE = 4;
31
37{
38 public:
40 inline static const std::string& VALUE()
41 {
42 static const std::string MY_CONSTRAINT_VALUE("ConstraintValue");
43 return MY_CONSTRAINT_VALUE;
44 }
46 inline static const std::string& FLYOUT_VALUE_PNT()
47 {
48 static const std::string MY_FLYOUT_VALUE_PNT("ConstraintFlyoutValuePnt");
49 return MY_FLYOUT_VALUE_PNT;
50 }
52 inline static const std::string& CONSTRAINT_ACTIVE()
53 {
54 static const std::string MY_STATE("ConstraintState");
55 return MY_STATE;
56 }
58 inline static const std::string& ENTITY_A()
59 {
60 static const std::string MY_ENTITY_A("ConstraintEntityA");
61 return MY_ENTITY_A;
62 }
64 inline static const std::string& ENTITY_B()
65 {
66 static const std::string MY_ENTITY_B("ConstraintEntityB");
67 return MY_ENTITY_B;
68 }
70 inline static const std::string& ENTITY_C()
71 {
72 static const std::string MY_ENTITY_C("ConstraintEntityC");
73 return MY_ENTITY_C;
74 }
76 inline static const std::string& ENTITY_D()
77 {
78 static const std::string MY_ENTITY_D("ConstraintEntityD");
79 return MY_ENTITY_D;
80 }
81
83 inline static const std::string& ATTRIBUTE(const int theNumber)
84 {
85 switch (theNumber) {
86 case 0:
87 return ENTITY_A();
88 case 1:
89 return ENTITY_B();
90 case 2:
91 return ENTITY_C();
92 case 3:
93 return ENTITY_D();
94 default:
95 break;
96 }
97 static const std::string EMPTY_STRING("");
98 return EMPTY_STRING;
99 }
100
102 virtual inline bool isZeroValueAllowed()
103 {
104 return true;
105 }
106
109 virtual inline void setNumericValue(const double theValue)
110 {
111 real(VALUE())->setValue(theValue);
112 }
113
115 virtual inline double getNumericValue()
116 {
117 return real(VALUE())? real(VALUE())->value(): std::numeric_limits<double>::lowest();
118 }
119
120 protected:
123};
124
125typedef std::shared_ptr<SketchPlugin_Constraint> ConstraintPtr;
126
127#endif
std::shared_ptr< ModelAPI_AttributeDouble > real(const std::string &theID)
Definition: ModelAPI_Feature.h:211
Abstract interface to the SketchPlugin_ConstraintBase For more info see: SketchPlugin_ConstraintBase....
Definition: SketchPlugin_Constraint.h:37
static const std::string & ENTITY_D()
Fourth entity for the constraint.
Definition: SketchPlugin_Constraint.h:76
virtual double getNumericValue()
Get numeric value of attribute VALUE()
Definition: SketchPlugin_Constraint.h:115
SketchPlugin_Constraint()
Definition: SketchPlugin_Constraint.cpp:22
virtual bool isZeroValueAllowed()
Get if a constraint is able to have a zero numeric value.
Definition: SketchPlugin_Constraint.h:102
static const std::string & ENTITY_A()
First entity for the constraint.
Definition: SketchPlugin_Constraint.h:58
virtual void setNumericValue(const double theValue)
Set numeric value to attribute VALUE()
Definition: SketchPlugin_Constraint.h:109
static const std::string & FLYOUT_VALUE_PNT()
The 2D value parameter for the constraint.
Definition: SketchPlugin_Constraint.h:46
static const std::string & ENTITY_C()
Third entity for the constraint.
Definition: SketchPlugin_Constraint.h:70
static const std::string & ATTRIBUTE(const int theNumber)
List of constraint attributes.
Definition: SketchPlugin_Constraint.h:83
static const std::string & VALUE()
The value parameter for the constraint.
Definition: SketchPlugin_Constraint.h:40
static const std::string & CONSTRAINT_ACTIVE()
State of constraint - Active - true, Suppressed - false.
Definition: SketchPlugin_Constraint.h:52
static const std::string & ENTITY_B()
Second entity for the constraint.
Definition: SketchPlugin_Constraint.h:64
Feature for creation of the new feature in PartSet.
Definition: SketchPlugin_Feature.h:40
