SHAPER  9.12.0
GEOMAlgo_BuilderShape Class Referenceabstract
Root class for algorithms that has shape as result
More...
Inheritance diagram for GEOMAlgo_BuilderShape:
GEOMALGOIMPL_EXPORT const TopoDS_Shape & Shape () const
 Returns the result of algorithm
More...
virtual GEOMALGOIMPL_EXPORT const TopTools_ListOfShape & Generated (const TopoDS_Shape &theS)
 Returns the list of shapes generated from the
shape theS. More...
virtual GEOMALGOIMPL_EXPORT const TopTools_ListOfShape & Modified (const TopoDS_Shape &theS)
 Returns the list of shapes modified from the
shape theS. More...
virtual GEOMALGOIMPL_EXPORT Standard_Boolean IsDeleted (const TopoDS_Shape &theS)
 Returns true if the shape theS has been deleted.
More...
GEOMALGOIMPL_EXPORT Standard_Boolean HasDeleted () const
 Returns true if the at least one shape(or sub-shape)
of arguments has been deleted. More...
GEOMALGOIMPL_EXPORT Standard_Boolean HasGenerated () const
of arguments has generated shapes. More...
GEOMALGOIMPL_EXPORT Standard_Boolean HasModified () const
of arguments has modified shapes. More...
GEOMALGOIMPL_EXPORT const TopTools_IndexedDataMapOfShapeListOfShape & ImagesResult () const
virtual GEOMALGOIMPL_EXPORT void Perform ()=0
GEOMALGOIMPL_EXPORT Standard_Integer ErrorStatus () const
GEOMALGOIMPL_EXPORT Standard_Integer WarningStatus () const
GEOMALGOIMPL_EXPORT void ComputeInternalShapes (const Standard_Boolean theFlag)
 Allows to omit of creation of internal shapes (manifold topology). More...
GEOMALGOIMPL_EXPORT GEOMAlgo_BuilderShape ()
 Empty constructor
More...
virtual GEOMALGOIMPL_EXPORT void PrepareHistory ()
 Prepare information for history support
More...
virtual GEOMALGOIMPL_EXPORT void CheckData ()
virtual GEOMALGOIMPL_EXPORT void CheckResult ()
TopoDS_Shape myShape
TopTools_ListOfShape myHistShapes
TopTools_MapOfShape myMapShape
Standard_Boolean myHasDeleted
Standard_Boolean myHasGenerated
Standard_Boolean myHasModified
TopTools_IndexedDataMapOfShapeListOfShape myImagesResult
Standard_Integer myErrorStatus
Standard_Integer myWarningStatus
Standard_Boolean myComputeInternalShapes
◆ GEOMAlgo_BuilderShape()
GEOMAlgo_BuilderShape::GEOMAlgo_BuilderShape ( )
Empty constructor
◆ Shape()
const TopoDS_Shape & GEOMAlgo_BuilderShape::Shape ( ) const
◆ Generated()
const TopTools_ListOfShape & GEOMAlgo_BuilderShape::Generated ( const TopoDS_Shape &  theS)
shape theS.
Reimplemented in GEOMAlgo_Gluer2.
◆ Modified()
const TopTools_ListOfShape & GEOMAlgo_BuilderShape::Modified ( const TopoDS_Shape &  theS)
shape theS.
◆ IsDeleted()
Standard_Boolean GEOMAlgo_BuilderShape::IsDeleted ( const TopoDS_Shape &  theS)
◆ HasDeleted()
Standard_Boolean GEOMAlgo_BuilderShape::HasDeleted ( ) const
◆ HasGenerated()
Standard_Boolean GEOMAlgo_BuilderShape::HasGenerated ( ) const
◆ HasModified()
Standard_Boolean GEOMAlgo_BuilderShape::HasModified ( ) const
◆ PrepareHistory()
void GEOMAlgo_BuilderShape::PrepareHistory ( )
◆ ComputeInternalShapes()
void GEOMAlgo_Algo::ComputeInternalShapes ( const Standard_Boolean  theFlag)
Needed for the SALOME/TRIPOLI module.
