UNV2420_Structure.hxx
23#ifndef UNV2420_Structure_HeaderFile
24#define UNV2420_Structure_HeaderFile
26// Name: Coordinate Systems
27// -----------------------------------------------------------------------
28
29// Record 1: FORMAT (1I10)
30// Field 1 -- Part UID
31
32// Record 2: FORMAT (40A2)
33// Field 1 -- Part Name
34
35// Record 3: FORMAT (3I10)
36// Field 1 -- Coordinate System Label
37// Field 2 -- Coordinate System Type
38// = 0, Cartesian
39// = 1, Cylindrical
40// = 2, Spherical
41// Field 3 -- Coordinate System Color
42
43// Record 4: FORMAT (40A2)
44// Field 1 -- Coordinate System Name
45
46// Record 5: FORMAT (1P3D25.16)
47// Field 1-3 -- Transformation Matrix Row 1
48
49// Record 6: FORMAT (1P3D25.16)
50// Field 1-3 -- Transformation Matrix Row 2
51
52// Record 7: FORMAT (1P3D25.16)
53// Field 1-3 -- Transformation Matrix Row 3
54
55// Record 8: FORMAT (1P3D25.16)
56// Field 1-3 -- Transformation Matrix Row 4
57
58// Records 3 thru 8 are repeated for each Coordinate System in the Part.
59
60// Example:
61// -1
62// 2420
63// 100
64// Untitled
65// 6 1 15
66// FEMAP Global Cylindrical (6)
67// 1.0000000000000000E+0 0.0000000000000000E+0 0.0000000000000000E+0
68// 0.0000000000000000E+0 1.0000000000000000E+0 0.0000000000000000E+0
69// 0.0000000000000000E+0 0.0000000000000000E+0 1.0000000000000000E+0
70// 0.0000000000000000E+0 0.0000000000000000E+0 0.0000000000000000E+0
71// 7 2 15
72// Coordinate System 4
73// 1.0000000000000000E+0 0.0000000000000000E+0 0.0000000000000000E+0
74// 0.0000000000000000E+0 1.0000000000000000E+0 0.0000000000000000E+0
75// 0.0000000000000000E+0 0.0000000000000000E+0 1.0000000000000000E+0
76// 0.0000000000000000E+0 0.0000000000000000E+0 0.0000000000000000E+0
77// -1
78
79#include "SMESH_DriverUNV.hxx"
80
81#include <string>
82#include <vector>
83
84namespace UNV2420
85{
87
88 typedef int TCSLabel; // type of coord system label
89
91 {
93 int coord_sys_type; // { Cartesian=0, Cylindrical, Spherical }
95 std::string coord_sys_name;
96 double matrix[4][3];
97
98 bool isIdentityMatrix() const;
99 void ApplyMatrix ( double* coords ) const;
100 static void FromCylindricalCS( double* coords );
101 static void FromSphericalCS ( double* coords );
102 };
103
104 typedef std::vector<TRecord> TDataSet;
105
107 Read(std::ifstream& in_stream,
108 std::string& part_name, // can re-store a mesh name
109 TDataSet& theDataSet);
110
112 Write(std::ofstream& out_stream,
113 const std::string& part_name); // can store a mesh name
114 // const TDataSet& theDataSet);
115
116}
117
118
119#endif
#define MESHDRIVERUNV_EXPORT
Definition: SMESH_DriverUNV.hxx:37
Definition: UNV2420_Structure.hxx:85
@ Spherical
Definition: UNV2420_Structure.hxx:86
@ Cartesian
@ Cylindrical
void Read(std::ifstream &in_stream, std::string &part_name, TDataSet &theDataSet)
Definition: UNV2420_Structure.cxx:36
std::vector< TRecord > TDataSet
Definition: UNV2420_Structure.hxx:104
void Write(std::ofstream &out_stream, const std::string &part_name)
Definition: UNV2420_Structure.cxx:83
int TCSLabel
Definition: UNV2420_Structure.hxx:88
Definition: UNV2420_Structure.hxx:91
TCSLabel coord_sys_label
Definition: UNV2420_Structure.hxx:92
int coord_sys_type
Definition: UNV2420_Structure.hxx:93
int coord_sys_color
Definition: UNV2420_Structure.hxx:94
Definition: UNV2420_Structure.hxx:95
