MED fichier
c/test29.c
/* This file is part of MED.
* - Nom du fichier : test29.c
* - Description : ecriture d'un joint dans un maillage MED
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#ifdef DEF_LECT_ECR
#elif DEF_LECT_AJOUT
#else
#endif
med_idt fid;
char maa[MED_NAME_SIZE+1]= "maa1";
char jnt[MED_NAME_SIZE+1] = "joint";
char des_jnt[MED_COMMENT_SIZE+1] = "joint avec le sous-domaine 2";
char maa_distant[MED_NAME_SIZE+1]= "maa1";
med_int dom_dist = 2;
med_int mdim = 3;
med_int ncor = 3;
med_int cor[6] = {1,2,3,4,5,6};
med_int cor2[6] = {10,20,30,40,50,60};
char nomcoo[3*MED_SNAME_SIZE+1] = "x y z ";
char unicoo[3*MED_SNAME_SIZE+1] = "cm cm cm ";
/* Creation du fichier "test29.med" */
if ((fid = MEDfileOpen("test29.med",MODE_ACCES)) < 0) {
MESSAGE("Erreur a la creation du fichier test29.med");
return -1;
if (MEDmeshCr( fid, maa, mdim, mdim, MED_UNSTRUCTURED_MESH,
"un maillage pour test29","s", MED_SORT_DTIT,
MED_CARTESIAN, nomcoo, unicoo) < 0) {
MESSAGE("Erreur a la creation du maillage : "); SSCRUTE(maa);
return -1;
/* Creation du joint */
if (MEDsubdomainJointCr(fid,maa,jnt,des_jnt,dom_dist,maa_distant) < 0) {
MESSAGE("Erreur a la creation du joint");
return -1;
/* Ecriture de la correspondance Noeud, Noeud */
MESSAGE("Erreur a l'ecriture du tableau des correspondances (noeud,noeud)");
return -1;
/* Ecriture de la correspondance Noeud Maille */
MED_NODE,MED_NONE,MED_CELL,MED_TRIA3,ncor,cor2) < 0) {
MESSAGE("Erreur a l'ecriture du tableau des correspondances (noeud,maille TRIA3)");
return -1;
/* Fermeture du fichier */
if (MEDfileClose(fid) < 0) {
return -1;
return 0;
main
Definition: 3.0.8/test10.c:50
MED_TRIA3
#define MED_TRIA3
Definition: med.h:207
MED_COMMENT_SIZE
#define MED_COMMENT_SIZE
Definition: med.h:80
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
MEDsubdomainJointCr
MEDC_EXPORT med_err MEDsubdomainJointCr(const med_idt fid, const char *const localmeshname, const char *const jointname, const char *const description, const med_int domainnumber, const char *const remotemeshname)
Cette routine permet de créer un joint dans un maillage.
Definition: MEDsubdomainJointCr.c:43
med_idt
hid_t med_idt
Definition: med.h:335
MEDsubdomainCorrespondenceWr
MEDC_EXPORT med_err MEDsubdomainCorrespondenceWr(const med_idt fid, const char *const meshname, const char *const jointname, const med_int numdt, const med_int numit, const med_entity_type localentitytype, const med_geometry_type localgeotype, const med_entity_type remoteentitytype, const med_geometry_type remotegeotype, const med_int nentity, const med_int *const correspondence)
Cette routine permet l'écriture d'une correspondance dans un joint pour un type de couple d'entité en...
Definition: MEDsubdomainCorrespondenceWr.c:47
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MED_NODE
MODE_ACCES
#define MODE_ACCES
Definition: 3.0.8/test10.c:34
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_NONE
#define MED_NONE
Definition: med.h:235
Definition: med.h:134
SSCRUTE
#define SSCRUTE(chaine)
Definition: med_utils.h:323
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MEDmeshCr
Definition: MEDmeshCr.c:45
MED_CARTESIAN
Definition: med.h:262
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_SORT_DTIT
Definition: med.h:313
