MED fichier
c/test12.c
/* This file is part of MED.
* - Nom du fichier : test12.c
* - Description : ecriture d'une equivalence dans un maillage MED
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#ifdef DEF_LECT_ECR
#elif DEF_LECT_AJOUT
#else
#endif
med_idt fid;
char maa[MED_NAME_SIZE+1]= "maa1";
char equ[MED_NAME_SIZE+1] = "equivalence";
char des[MED_COMMENT_SIZE+1] = "equivalence sur les mailles MED_TRIA3";
med_int mdim = 3;
med_int ncor = 3;
med_int cor[6] = {1,2,3,4,5,6};
char nomcoo[3*MED_SNAME_SIZE+1] = "x y z ";
char unicoo[3*MED_SNAME_SIZE+1] = "cm cm cm ";
/* Creation du fichier "test12.med" */
if ((fid = MEDfileOpen("test12.med",MODE_ACCES)) < 0) {
MESSAGE("Erreur a la creation du fichier test12.med");
return -1;
if (MEDmeshCr( fid, maa, 3, 3, MED_UNSTRUCTURED_MESH,
"un maillage pour test12","s", MED_SORT_DTIT,
MED_CARTESIAN, nomcoo, unicoo) < 0) {
MESSAGE("Erreur a la creation du maillage : "); SSCRUTE(maa);
return -1;
/* Creation de l'equivalence */
if (MEDequivalenceCr(fid,maa,equ,des) < 0)
MESSAGE("Erreur a la creation de l'equivalence");
return -1;
/* Ecriture des sur les mailles MED_TRIA3 */
MED_CELL,MED_TRIA3,ncor,cor) < 0)
MESSAGE("Erreur a l'ecriture du tableau des correspondances");
return -1;
/* Fermeture du fichier */
if (MEDfileClose(fid) < 0) {
return -1;
return 0;
main
Definition: 3.0.8/test10.c:50
MED_TRIA3
#define MED_TRIA3
Definition: med.h:207
MED_COMMENT_SIZE
#define MED_COMMENT_SIZE
Definition: med.h:80
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_idt
hid_t med_idt
Definition: med.h:335
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MEDequivalenceCorrespondenceWr
MEDC_EXPORT med_err MEDequivalenceCorrespondenceWr(const med_idt fid, const char *const meshname, const char *const equivname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_int nentity, const med_int *const correspondence)
Cette routine permet d'écrire un tableau de correspondances entre les entités d'un maillage dans une ...
Definition: MEDequivalenceCorrespondenceWr.c:43
MEDequivalenceCr
MEDC_EXPORT med_err MEDequivalenceCr(const med_idt fid, const char *const meshname, const char *const equivname, const char *const description)
Cette routine permet la création d'une équivalence portant sur les entités d'un maillage.
Definition: MEDequivalenceCr.c:37
MODE_ACCES
#define MODE_ACCES
Definition: 3.0.8/test10.c:34
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
Definition: med.h:134
SSCRUTE
#define SSCRUTE(chaine)
Definition: med_utils.h:323
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MEDmeshCr
Definition: MEDmeshCr.c:45
MED_CARTESIAN
Definition: med.h:262
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_SORT_DTIT
Definition: med.h:313
