MED fichier
usecases/c/UsesCase_MEDfield_15b.c
/* This file is part of MED.
* Field use case 15 : write a field in a MED file with
* values defined on struct elements
#include <med.h>
#include "med_hdfi.h"
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid2=0,oid=0;
med_idt fid=0,mfid=0;
const char meshname[MED_NAME_SIZE+1] = "COMPUT_MESH";
const char fieldname[MED_NAME_SIZE+1] = "SPEED";
const med_int ncomponent = 3;
/* 123456789012345612345678901234561234567890123456 */
const char componentname[3*MED_SNAME_SIZE+1] = "Vx Vy Vz";
const char componentunit[3*MED_SNAME_SIZE+1] = "m/s m/s m/s";
const med_int npart = 3;
char structelementname[MED_NAME_SIZE+1]="";
const med_float part_speed1[3*3] = { 1.1, 2.2, 3.3,
4.4, 5.5, 6.6,
7.7, 8.8, 9.9 };
int ret=-1;
/* File creation to write the field */
fid = MEDfileOpen("UsesCase_MEDfield_15b.med",MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
/* Create mesh link */
if (MEDlinkWr(fid,meshname,"./UsesCase_MEDstructElement_1.med") < 0) {
MESSAGE("ERROR : create mesh link ...");
goto ERROR;
* Read struct element geometric type
* UsesCase_MEDstructElement_1_byid.med
fid2 = MEDfileOpen(argv[1],MED_ACC_RDONLY);
if (fid2 < 0) {
MESSAGE("Erreur � l'ouverture du fichier UsesCase_MEDstructElement_1_byid.med");
goto ERROR;
if (( mfid=MEDfileObjectsMountById(fid,fid2,"/byid",MED_ELSTRUCT)) < 0 ) {
MESSAGE("ERROR : file mounting ...");
goto ERROR;
strcpy(structelementname,MED_PARTICLE_NAME);
geotype = MEDstructElementGeotype(fid,structelementname);
* Speed field creation for particles :
* - 3 component
* - component unit : m/s
* - mesh is the 3D computation mesh of UsesCase_MEDstructElement_1 use case.
* - computation step unit in 'ms'
if (MEDfieldCr(fid, fieldname, MED_FLOAT64,
ncomponent, componentname, componentunit,
"ms", meshname) < 0) {
MESSAGE("ERROR : create field");
goto ERROR;
npart, (unsigned char*) part_speed1) < 0) {
MESSAGE("ERROR : write field values on MED_PARTICLE ");
goto ERROR;
if ( MEDfileObjectsUnmount(fid, mfid, MED_ELSTRUCT) < 0 ) {
MESSAGE("ERROR : file unmounting ...");
goto ERROR;
ret=0;
ERROR:
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
main
Definition: 3.0.8/test10.c:50
MED_PARTICLE_NAME
#define MED_PARTICLE_NAME
Definition: med.h:474
MED_COMPACT_STMODE
Definition: med.h:113
MED_FLOAT64
Definition: med.h:169
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_hdfi.h
MED_ACC_RDONLY
Definition: med.h:123
med_idt
hid_t med_idt
Definition: med.h:335
MEDC_EXPORT med_err MEDfileObjectsUnmount(const med_idt fid, const med_idt mid, const med_class medclass)
Une fois le démontage effectué, les données précédemment montées ne sont plus accessibles.
Definition: MEDfileObjectsUnmount.c:33
MEDlinkWr
MEDC_EXPORT med_err MEDlinkWr(const med_idt fid, const char *const meshname, const char *const link)
Cette routine permet d'écrire un lien dans un fichier MED.
Definition: MEDlinkWr.c:36
MEDC_EXPORT med_idt MEDfileObjectsMountById(const med_idt fid, const med_idt chfid, const char *const chpath, const med_class medclass)
Cette routine permet le montage d'une collection d'objets de type medclass dans le fichier associé à ...
Definition: MEDfileObjectsMountById.c:43
MED_NO_LOCALIZATION
#define MED_NO_LOCALIZATION
Definition: med.h:279
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
med_int
int med_int
Definition: med.h:346
MEDC_EXPORT med_geometry_type MEDstructElementGeotype(const med_idt fid, const char *const modelname)
Cette routine renvoie le type géométrique mgeotype associé au modèle d'éléments de structure de nom m...
Definition: MEDstructElementGeotype.c:38
MEDfieldCr
MEDC_EXPORT med_err MEDfieldCr(const med_idt fid, const char *const fieldname, const med_field_type fieldtype, const med_int ncomponent, const char *const componentname, const char *const componentunit, const char *const dtunit, const char *const meshname)
Cette fonction crée un champ dans un fichier.
Definition: MEDfieldCr.c:44
MEDfieldValueWithProfileWr
MEDC_EXPORT med_err MEDfieldValueWithProfileWr(const med_idt fid, const char *const fieldname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_geometry_type geotype, const med_storage_mode storagemode, const char *const profilename, const char *const localizationname, const med_switch_mode switchmode, const med_int componentselect, const med_int nentity, const unsigned char *const value)
Cette fonction permet d'écrire les valeurs d'un champ définies sur des entités d'un maillage pour une...
Definition: MEDfieldValueWithProfileWr.c:48
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_NONE
#define MED_NONE
Definition: med.h:235
MED_UNDEF_DT
#define MED_UNDEF_DT
Definition: med.h:326
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_ACC_CREAT
Definition: med.h:126
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_ALL_CONSTITUENT
#define MED_ALL_CONSTITUENT
Definition: med.h:303
MED_NO_PROFILE
#define MED_NO_PROFILE
Definition: med.h:285
MED_STRUCT_ELEMENT
Definition: med.h:147
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_ELSTRUCT
Definition: med.h:192
med_geometry_type
int med_geometry_type
Definition: med.h:198
