MED fichier
usecases/c/UsesCase_MEDmesh_13.c
/* This file is part of MED.
* Use case 13 : a 2D unstructured mesh with 10 nodes and 2 polygons
* poly1 : 1,4,7,9,6,3
* poly2 : 2,5,8,10,7,4
* 9 10
* 6 7 8
* 3 4 5
* 1 2
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid;
const med_int spacedim = 2;
const med_int meshdim = 2;
/* 12345678901234561234567890123456 */
const char axisname[2*MED_SNAME_SIZE+1] = "x y ";
const char unitname[2*MED_SNAME_SIZE+1] = "cm cm ";
/* Dix noeuds dont deux communs aux deux polygones */
const med_float coordinates[2*10] = { 0.5, 0.,
1.5, 0.,
0., 0.5,
1., 0.5,
2., 0.5,
0., 1.,
1., 1.,
2., 1.,
0.5, 2.,
1.5, 2. };
const med_int nnodes = 10;
const med_int indexsize = 3;
const med_int index[3] = {1,7,13};
/* connectivity : 2 hexagons */
const med_int connectivity[12] = {1,4,7,9,6,3,
2,5,8,10,7,4};
int ret=-1;
/* open MED file */
fid = MEDfileOpen("UsesCase_MEDmesh_13.med", MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
/* write a comment in the file */
if (MEDfileCommentWr(fid, "A 2D unstructured mesh : 12, 12 polygons") < 0)
{ MESSAGE("ERROR : write file description ...");
goto ERROR;
/* mesh creation : a 2D unstructured mesh */
if (MEDmeshCr(fid, meshname, spacedim, meshdim,
MED_UNSTRUCTURED_MESH, "A 2D mesh with 2 polygons",
"", MED_SORT_DTIT, MED_CARTESIAN, axisname, unitname) < 0)
{ MESSAGE("ERROR : mesh creation ...");
goto ERROR;
/* nodes coordinates in a cartesian axis in full interlace mode
(X1,Y1, X2,Y2, X3,Y3, ...) with no iteration and computation step
MED_FULL_INTERLACE, nnodes, coordinates) < 0)
{ MESSAGE("ERROR : nodes coordinates ...");
goto ERROR;
/* cells connectiviy is defined in nodal mode */
/* 2 polygons */
MED_CELL, MED_NODAL, indexsize, index, connectivity) < 0)
{ MESSAGE("ERROR : polygon connectivity ...");
goto ERROR;
/* create family 0 : by default, all mesh entities family number is 0 */
if (MEDfamilyCr(fid, meshname, MED_NO_NAME, 0, 0, MED_NO_GROUP) < 0)
{ MESSAGE("ERROR : family 0 creation ...");
goto ERROR;
ret=0;
ERROR:
/* close MED file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
MEDfamilyCr
MEDC_EXPORT med_err MEDfamilyCr(const med_idt fid, const char *const meshname, const char *const familyname, const med_int familynumber, const med_int ngroup, const char *const groupname)
Cette routine permet la création d'une famille portant sur les entités d'un maillage.
Definition: MEDfamilyCr.c:40
MEDmeshNodeCoordinateWr
MEDC_EXPORT med_err MEDmeshNodeCoordinateWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_switch_mode switchmode, const med_int nentity, const med_float *const coordinates)
Definition: MEDmeshNodeCoordinateWr.c:45
MED_NODAL
Definition: med.h:259
main
Definition: 3.0.8/test10.c:50
MED_NO_NAME
#define MED_NO_NAME
Definition: med.h:272
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
MEDmeshPolygonWr
MEDC_EXPORT med_err MEDmeshPolygonWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_connectivity_mode cmode, const med_int indexsize, const med_int *const polyindex, const med_int *const connectivity)
Cette routine permet l'écriture des connectivités de polygones.
Definition: MEDmeshPolygonWr.c:45
med_idt
hid_t med_idt
Definition: med.h:335
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MEDfileCommentWr
med_err MEDfileCommentWr(const med_idt fid, const char *const description)
\MEDfileCommentWrBrief
Definition: MEDfileCommentWr.c:37
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
Definition: med.h:134
MED_UNDEF_DT
#define MED_UNDEF_DT
Definition: med.h:326
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_ACC_CREAT
Definition: med.h:126
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MEDmeshCr
Definition: MEDmeshCr.c:45
MED_NO_GROUP
#define MED_NO_GROUP
Definition: med.h:293
MED_CARTESIAN
Definition: med.h:262
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_SORT_DTIT
Definition: med.h:313
