#define MESGERR 1
#include <string.h>
int main (
int argc,
char **argv) {
int i;
char *groupname=NULL;
int ret=-1;
if (fid < 0) {
MESSAGE(
"ERROR : open file in READ ONLY ACCESS mode ...");
goto ERROR;
if (
MEDmeshInfoByName(fid, meshname, &spacedim, &meshdim, &meshtype, meshdescription,
dtunit, &sortingtype, &nstep, &axistype, axisname, unitname) < 0) {
goto ERROR;
&geotransformation)) < 0) {
MESSAGE(
"ERROR : number of nodes ...");
goto ERROR;
MESSAGE(
"ERROR : number of MED_TRIA3 ...");
goto ERROR;
MESSAGE(
"ERROR : number of MED_QUAD4 ...");
goto ERROR;
MESSAGE(
"ERROR : memory allocation ...");
goto ERROR;
coordinates) < 0) {
MESSAGE(
"ERROR : nodes coordinates ...");
free(coordinates);
goto ERROR;
free(coordinates);
if ((triaconnectivity = (
med_int *) malloc(
sizeof(
med_int)*ntria3*3)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : MED_TRIA3 connectivity ...");
free(triaconnectivity);
goto ERROR;
if ((quadconnectivity = (
med_int *) malloc(
sizeof(
med_int)*nquad4*4)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : MED_QUAD4 connectivity ...");
free(quadconnectivity);
goto ERROR;
MESSAGE(
"ERROR : read number of family ...");
goto ERROR;
for (i=0; i<nfamily ; i++) {
MESSAGE(
"ERROR : read number of group in a family ...");
goto ERROR;
if (ngroup > 0) {
if ((groupname = (
char*) malloc(
sizeof(
char)*
MED_LNAME_SIZE*ngroup+1)) == NULL) {
MESSAGE(
goto ERROR;
if (
MEDfamilyInfo(fid, meshname, i+1, familyname, &familynumber, groupname) < 0) {
MESSAGE(
"ERROR : family info ...");
free(groupname);
goto ERROR;
free(groupname);
&coordinatechangement, &geotransformation)) < 0) {
MESSAGE(
"ERROR : check family numbers nodes ...");
goto ERROR;
if ((familynumbers = (
med_int *) malloc(
sizeof(
med_int)*nnodes)) == NULL) {
MESSAGE(
goto ERROR;
if (nfamilynumber > 0) {
MESSAGE(
"ERROR : read family numbers nodes ...");
goto ERROR;
} else
for (i=0; i<nnodes; i++) *(familynumbers+i) = 0;
for (i=0; i<nnodes; i++) {
printf(
IFORMAT, *(familynumbers+i));
if (i+1 != nnodes)
printf(" - ");
else
printf("\n");
if (familynumbers)
free(familynumbers);
MESSAGE(
"ERROR : check family number tria3 ...")
goto ERROR;
med_int *) malloc(
sizeof(
med_int)*ntria3)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : read family numbers tria3 ...");
} else
for (i=0; i<ntria3; i++) *(familynumbers+i) = 0;
free (familynumbers);
MESSAGE(
"ERROR : check family number quad4 ...");
goto ERROR;
med_int *) malloc(
sizeof(
med_int)*nquad4)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : read family numbers quad4 ...");
goto ERROR;
} else
for (i=0; i<nquad4; i++) *(familynumbers+i) = 0;
ret=0;
ERROR:
ret= -1;
return ret;
MEDC_EXPORT med_err MEDfamilyInfo(const med_idt fid, const char *const meshname, const int famit, char *const familyname, med_int *const familynumber, char *const groupname)
Cette routine permet de lire les informations relatives à une famille d'un maillage.
MEDC_EXPORT med_err MEDmeshEntityFamilyNumberRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, med_int *const number)
Cette routine permet la lecture des numéros de famille d'un type d'entité d'un maillage.
MEDC_EXPORT med_int MEDnFamilyGroup(const med_idt fid, const char *const meshname, const int famit)
Cette routine permet de lire le nombre de groupe dans une famille.
MEDC_EXPORT med_int MEDnFamily(const med_idt fid, const char *const meshname)
Cette routine permet de lire le nombre de famille dans un maillage.
MEDC_EXPORT med_err MEDmeshInfoByName(const med_idt fid, const char *const meshname, med_int *const spacedim, med_int *const meshdim, med_mesh_type *const meshtype, char *const description, char *const dtunit, med_sorting_type *const sortingtype, med_int *const nstep, med_axis_type *const axistype, char *const axisname, char *const axisunit)
Cette routine permet de lire les informations relatives à un maillage en précisant son nom.
MEDC_EXPORT med_err MEDmeshNodeCoordinateRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_switch_mode switchmode, med_float *const coordinates)
Cette routine permet de lire dans un maillage le tableau des coordonnées des noeuds,...
MEDC_EXPORT med_err MEDmeshElementConnectivityRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_connectivity_mode cmode, const med_switch_mode switchmode, med_int *const connectivity)
Cette routine permet de lire dans un maillage le tableau des connectivités pour un type géométrique d...
Fermeture d'un fichier MED.
Ouverture d'un fichier MED.
