MED fichier
usecases/c/UsesCase_MEDfield_7.c
/* This file is part of MED.
* Field use case 7 : write a field with computing steps and profiles
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid;
const char fieldname[MED_NAME_SIZE+1] = "TEMPERATURE_FIELD";
const med_int ncomponent = 1;
const char componentname[MED_SNAME_SIZE+1] = "TEMPERATURE";
const char componentunit[MED_SNAME_SIZE+1] = "C";
const med_float tria3values_step1_profile1[3] = {1000., 4000., 8000.};
const med_float tria3values_step2_profile1[8] = {1500., 0., 0., 4500., 0., 0., 0., 8500.};
const med_float tria3values_step2_profile2[8] = { 0., 2500., 3500., 0., 5500., 6500., 7500., 0.};
const med_float quad4values_step1[4] = {10000., 20000., 30000., 40000.};
const med_float quad4values_step2[4] = {15000., 25000., 35000., 45000.};
const char profile1name[MED_NAME_SIZE+1] = "MED_TRIA3_PROFILE1";
const med_int profile1[3] = {1, 4, 8};
const med_int profile1size = 3;
const char profile2name[MED_NAME_SIZE+1] = "MED_TRIA3_PROFILE2";
const med_int profile2[5] = {2, 3, 5, 6, 7};
const med_int profile2size = 5;
const med_int ntria3 = 8;
const med_int nquad4 = 4;
int ret=-1;
/* file creation */
fid = MEDfileOpen("UsesCase_MEDfield_7.med",MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
/* create mesh link */
if (MEDlinkWr(fid,meshname,"./UsesCase_MEDmesh_1.med") < 0) {
MESSAGE("ERROR : create mesh link ...");
goto ERROR;
/* create the profiles in the file */
if (MEDprofileWr(fid, profile1name, profile1size, profile1 ) < 0) {
MESSAGE("ERROR : create profile ...");
goto ERROR;
if (MEDprofileWr(fid, profile2name, profile2size, profile2 ) < 0) {
goto ERROR;
/* field creation : temperature field : 1 component in celsius degree
* the mesh is the 2D unstructured mesh of UsecaseMEDmesh_1.c
* use case.
* Computation step unit in 'ms'
if (MEDfieldCr(fid, fieldname, MED_FLOAT64, ncomponent,
componentname, componentunit,"ms", meshname) < 0) {
MESSAGE("ERROR : create field");
goto ERROR;
/* two computation steps */
/* write values at cell centers : 8 MED_TRIA3 and 4 MED_QUAD4 */
/* STEP 1 : dt1 = 5.5, it = 1*/
/* MED_TRIA3 : with a profile of 3 values in compact memory storage mode */
if (MEDfieldValueWithProfileWr(fid, fieldname, 1, 1, 5.5, MED_CELL,MED_TRIA3,
(unsigned char*) tria3values_step1_profile1) < 0) {
MESSAGE("ERROR : write field values on MED_TRIA3");
goto ERROR;
/* MED_QUAD4 : with no profile */
if (MEDfieldValueWithProfileWr(fid, fieldname, 1, 1, 5.5, MED_CELL, MED_QUAD4,
(unsigned char*) quad4values_step1) < 0) {
MESSAGE("ERROR : write field values on MED_QUAD4 ");
goto ERROR;
/* STEP 2 : dt2 = 8.9, it = 1*/
/* MED_TRIA3 : with a profile of 3 values then a profile of 5 values in global memory storage mode */
if (MEDfieldValueWithProfileWr(fid, fieldname, 2 , 1 , 8.9 , MED_CELL, MED_TRIA3,
(unsigned char*) tria3values_step2_profile1) < 0) {
MESSAGE("ERROR : write field values on MED_TRIA3 ...");
goto ERROR;
(unsigned char*) tria3values_step2_profile2) < 0) {
goto ERROR;
if (MEDfieldValueWithProfileWr(fid, fieldname, 2, 1, 8.9, MED_CELL, MED_QUAD4,
(unsigned char*) quad4values_step2) < 0) {
MESSAGE("ERROR : write field values on MED_QUAD4 ... ");
goto ERROR;
ret=0;
ERROR:
/* close file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
main
Definition: 3.0.8/test10.c:50
MED_QUAD4
#define MED_QUAD4
Definition: med.h:208
MED_TRIA3
#define MED_TRIA3
Definition: med.h:207
MED_COMPACT_STMODE
Definition: med.h:113
MEDprofileWr
MEDC_EXPORT med_err MEDprofileWr(const med_idt fid, const char *const profilename, const med_int profilesize, const med_int *const profilearray)
Cette routine permet d'écrire un profil dans un fichier MED.
Definition: MEDprofileWr.c:40
MED_FLOAT64
Definition: med.h:169
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_idt
hid_t med_idt
Definition: med.h:335
MEDlinkWr
MEDC_EXPORT med_err MEDlinkWr(const med_idt fid, const char *const meshname, const char *const link)
Cette routine permet d'écrire un lien dans un fichier MED.
Definition: MEDlinkWr.c:36
MED_GLOBAL_STMODE
Definition: med.h:112
MED_NO_LOCALIZATION
#define MED_NO_LOCALIZATION
Definition: med.h:279
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MEDfieldCr
MEDC_EXPORT med_err MEDfieldCr(const med_idt fid, const char *const fieldname, const med_field_type fieldtype, const med_int ncomponent, const char *const componentname, const char *const componentunit, const char *const dtunit, const char *const meshname)
Cette fonction crée un champ dans un fichier.
Definition: MEDfieldCr.c:44
MEDC_EXPORT med_err MEDfieldValueWithProfileWr(const med_idt fid, const char *const fieldname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_geometry_type geotype, const med_storage_mode storagemode, const char *const profilename, const char *const localizationname, const med_switch_mode switchmode, const med_int componentselect, const med_int nentity, const unsigned char *const value)
Cette fonction permet d'écrire les valeurs d'un champ définies sur des entités d'un maillage pour une...
Definition: MEDfieldValueWithProfileWr.c:48
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_ACC_CREAT
Definition: med.h:126
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_ALL_CONSTITUENT
#define MED_ALL_CONSTITUENT
Definition: med.h:303
MED_NO_PROFILE
#define MED_NO_PROFILE
Definition: med.h:285
