MED fichier
usecases/c/UsesCase_MEDfield_17.c
/* This file is part of MED.
* Field use case 17 : write a field in a MED file with
* values defined on integration points
* on struct elements
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid=0,mfid=0,sfid=0;
const med_int spacedim = 3;
const char meshname[MED_NAME_SIZE+1] = "COMPUT_MESH";
const char fieldname[MED_NAME_SIZE+1] = "TEMPERATURE";
const med_int ncomponent = 1;
/* 1234567890123456123456*/
const char componentname[MED_SNAME_SIZE+1] = "TEMP ";
const char componentunit[MED_SNAME_SIZE+1] = "CELSIUS ";
const med_int nbeam = 1;
char structelementname[MED_NAME_SIZE+1];
const med_float tempvalue[3*1*4] = { 1.1, 2.2, 3.3, 4.4,
5.5, 6.6, 7.7, 8.8,
9.9, 10.1,11.11, 12.12};
const char localization[MED_NAME_SIZE+1] = "BEAM_INTEGRATION_POINTS";
const char localization2[MED_NAME_SIZE+1] = "BEAM_INTEGRATION_TRANSF";
const med_float elementcoordinate[3*3] = { 0.0,0.0,0.0,
0.0,0.0,0.0,
0.0,0.0,0.0,};
const med_float ipointcoordinate[3*3] = { 0.0,0.0,2.5,
0.0,0.0,3.5,
0.0,0.0,4.5};
const med_float weight[4] = {1.0/4, 1.0/4, 1.0/4, 1.0/4};
const char beamsectionname[MED_NAME_SIZE+1]="BEAM_SECTION_MESH";
const med_int nipoint = 3;
char interpname[MED_NAME_SIZE+1] = "geometrical transformation";
const med_int nvariable =2;
const med_int maxdegree =1;
const med_int nmaxcoefficient =3;
const med_int ncoefficient1_1 = 3;
const med_int power1_1[] = {0,0,1,0,0,1};
const med_float coefficient1_1[] = {1,-1,-1};
const med_int ncoefficient1_2 = 1;
const med_int power1_2[] = {1,0};
const med_float coefficient1_2[] = {1};
const med_int ncoefficient1_3 = 1;
const med_int power1_3[] = {0,1};
const med_float coefficient1_3[] = {1};
int ret=-1;
/* Open file to write the field */
fid = MEDfileOpen("UsesCase_MEDfield_17.med",MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
if (( mfid=MEDfileObjectsMount(fid, "UsesCase_MEDstructElement_1.med",MED_MESH_SUPPORT)) < 0 ) {
MESSAGE("ERROR : file mounting ...");
goto ERROR;
if (( sfid=MEDfileObjectsMount(fid, "UsesCase_MEDstructElement_1.med",MED_ELSTRUCT)) < 0 ) {
goto ERROR;
/* Create mesh link */
if (MEDlinkWr(fid,meshname,"./UsesCase_MEDstructElement_1.med") < 0) {
MESSAGE("ERROR : create mesh link ...");
goto ERROR;
* Read struct element geometric type
strcpy(structelementname,MED_BEAM_NAME);
geotype = MEDstructElementGeotype(fid,structelementname);
/* create a geometrical transformation fonction */
if (MEDinterpCr(fid, interpname, geotype, MED_FALSE, nvariable, maxdegree, nmaxcoefficient) < 0) {
MESSAGE("ERROR : interpolation family creation ...");
goto ERROR;
/* Basis functions creation */
if (MEDinterpBaseFunctionWr(fid,interpname,1,ncoefficient1_1,power1_1,coefficient1_1) < 0) {
MESSAGE("ERROR : first base function creation ...");
goto ERROR;
if (MEDinterpBaseFunctionWr(fid,interpname,2,ncoefficient1_2,power1_2,coefficient1_2) < 0) {
MESSAGE("ERROR : second base function creation ...");
goto ERROR;
if (MEDinterpBaseFunctionWr(fid,interpname,3,ncoefficient1_3,power1_3,coefficient1_3) < 0) {
MESSAGE("ERROR : third base function creation ...");
goto ERROR;
/* create the families of integration points
for the struct element */
if (MEDlocalizationWr(fid, localization, geotype, spacedim,
elementcoordinate, MED_FULL_INTERLACE,
nipoint, ipointcoordinate, weight,
MED_NO_INTERPOLATION, beamsectionname) < 0) {
MESSAGE("ERROR : create famlily of integration points ...");
goto ERROR;
if (MEDlocalizationWr(fid, localization2, geotype, spacedim,
interpname, beamsectionname) < 0) {
goto ERROR;
* Temperature field creation for beam struct element :
* - 1 component, 3 integration points, 4 cells in the support mesh for each
* the section of each integration point
* - mesh is the 3D computation mesh of UsesCase_MEDstructElement_1 use case.
if (MEDfieldCr(fid, fieldname, MED_FLOAT64,
ncomponent, componentname, componentunit,
"ms", meshname) < 0) {
MESSAGE("ERROR : create field");
goto ERROR;
MED_STRUCT_ELEMENT, geotype,
nbeam, (unsigned char*) tempvalue) < 0) {
MESSAGE("ERROR : write field values on MED_BEAM ");
goto ERROR;
goto ERROR;
/* unmount file objects */
if ( MEDfileObjectsUnmount(fid, mfid, MED_MESH_SUPPORT) < 0 ) {
MESSAGE("ERROR : file unmounting ...");
goto ERROR;
if ( MEDfileObjectsUnmount(fid, sfid, MED_ELSTRUCT) < 0 ) {
goto ERROR;
ret=0;
ERROR:
/* close file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
main
Definition: 3.0.8/test10.c:50
MED_COMPACT_STMODE
Definition: med.h:113
MEDfileObjectsMount
MEDC_EXPORT med_idt MEDfileObjectsMount(const med_idt fid, const char *const filename, const med_class medclass)
Cette routine permet de monter dans le fichier courant un type de données (exemples les maillages,...
Definition: MEDfileObjectsMount.c:40
MED_MESH_SUPPORT
Definition: med.h:192
MED_FLOAT64
Definition: med.h:169
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
MEDC_EXPORT med_err MEDinterpBaseFunctionWr(const med_idt fid, const char *const interpname, const med_int basisfuncit, const med_int ncoef, const med_int *const power, const med_float *const coefficient)
Cette routine permet l'écriture d'une fonction de base/forme de l'interpolation interpname.
Definition: MEDinterpBaseFunctionWr.c:41
MEDinterpCr
MEDC_EXPORT med_err MEDinterpCr(const med_idt fid, const char *const interpname, const med_geometry_type geotype, const med_bool cellnodes, const med_int nvariable, const med_int maxdegree, const med_int nmaxcoef)
Cette routine permet de créer une nouvelle fonction d'interpolation polynômiale nommée interpname.
Definition: MEDinterpCr.c:43
med_idt
hid_t med_idt
Definition: med.h:335
MEDC_EXPORT med_err MEDfileObjectsUnmount(const med_idt fid, const med_idt mid, const med_class medclass)
Une fois le démontage effectué, les données précédemment montées ne sont plus accessibles.
Definition: MEDfileObjectsUnmount.c:33
MEDlinkWr
MEDC_EXPORT med_err MEDlinkWr(const med_idt fid, const char *const meshname, const char *const link)
Cette routine permet d'écrire un lien dans un fichier MED.
Definition: MEDlinkWr.c:36
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
med_int
int med_int
Definition: med.h:346
MEDC_EXPORT med_geometry_type MEDstructElementGeotype(const med_idt fid, const char *const modelname)
Cette routine renvoie le type géométrique mgeotype associé au modèle d'éléments de structure de nom m...
Definition: MEDstructElementGeotype.c:38
MEDfieldCr
MEDC_EXPORT med_err MEDfieldCr(const med_idt fid, const char *const fieldname, const med_field_type fieldtype, const med_int ncomponent, const char *const componentname, const char *const componentunit, const char *const dtunit, const char *const meshname)
Cette fonction crée un champ dans un fichier.
Definition: MEDfieldCr.c:44
MEDfieldValueWithProfileWr
MEDC_EXPORT med_err MEDfieldValueWithProfileWr(const med_idt fid, const char *const fieldname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_geometry_type geotype, const med_storage_mode storagemode, const char *const profilename, const char *const localizationname, const med_switch_mode switchmode, const med_int componentselect, const med_int nentity, const unsigned char *const value)
Cette fonction permet d'écrire les valeurs d'un champ définies sur des entités d'un maillage pour une...
Definition: MEDfieldValueWithProfileWr.c:48
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_NONE
#define MED_NONE
Definition: med.h:235
MED_UNDEF_DT
#define MED_UNDEF_DT
Definition: med.h:326
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
MED_BEAM_NAME
#define MED_BEAM_NAME
Definition: med.h:476
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_ACC_CREAT
Definition: med.h:126
#define MED_NO_INTERPOLATION
Definition: med.h:281
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_ALL_CONSTITUENT
#define MED_ALL_CONSTITUENT
Definition: med.h:303
MED_NO_PROFILE
#define MED_NO_PROFILE
Definition: med.h:285
MED_STRUCT_ELEMENT
Definition: med.h:147
MEDlocalizationWr
MEDC_EXPORT med_err MEDlocalizationWr(const med_idt fid, const char *const localizationname, const med_geometry_type geotype, const med_int spacedimension, const med_float *const elementcoordinate, const med_switch_mode switchmode, const med_int nipoint, const med_float *const ipointcoordinate, const med_float *const weight, const char *const geointerpname, const char *const ipointstructmeshname)
Cette routine permet l'écriture d'une localisation localizationname de points d'intégration dans/auto...
Definition: MEDlocalizationWr.c:49
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_FALSE
Definition: med.h:264
MED_ELSTRUCT
med_geometry_type
int med_geometry_type
Definition: med.h:198
