MED fichier
usecases/c/UsesCase_MEDmesh_10.c
/* This file is part of MED.
* How to create an unstructured mesh
* Use case 10 : a 2D unstructured mesh with 15 nodes, 8 triangular cells, 4 triangular cells
* and families
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid;
const med_int spacedim = 2;
const med_int meshdim = 2;
const char axisname[2*MED_SNAME_SIZE+1] = "x y ";
const char unitname[2*MED_SNAME_SIZE+1] = "cm cm ";
const med_float coordinates[30] = { 2.,1., 7.,1., 12.,1., 17.,1., 22.,1.,
2.,6., 7.,6., 12.,6., 17.,6., 22.,6.,
2.,11., 7.,11., 12.,11., 17.,11., 22.,11.};
const med_int nnodes = 15;
const med_int triaconnectivity[24] = { 1,7,6, 2,7,1, 3,7,2, 8,7,3,
13,7,8, 12,7,13, 11,7,12, 6,7,11 };
const med_int ntria3 = 8;
const med_int quadconnectivity[16] = {3,4,9,8, 4,5,10,9,
15,14,9,10, 13,8,9,14};
const med_int nquad4 = 4;
const char familyname[MED_NAME_SIZE+1] = "BOUNDARY_VERTICES";
const char groupname[MED_LNAME_SIZE+1] = "MESH_BOUNDARY_VERTICES";
const med_int familynumbers[15] = { 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1 };
int ret=-1;
/* open MED file */
fid = MEDfileOpen("UsesCase_MEDmesh_10.med",MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
/* write a comment in the file */
if (MEDfileCommentWr(fid,"A 2D unstructured mesh : 15 nodes, 12 cells") < 0) {
MESSAGE("ERROR : write file description ...");
goto ERROR;
/* mesh creation : a 2D unstructured mesh */
if (MEDmeshCr(fid, meshname, spacedim, meshdim, MED_UNSTRUCTURED_MESH,
"A 2D unstructured mesh","",MED_SORT_DTIT,MED_CARTESIAN, axisname, unitname) < 0) {
MESSAGE("ERROR : mesh creation ...");
goto ERROR;
/* nodes coordinates in a cartesian axis in full interlace mode
(X1,Y1, X2,Y2, X3,Y3, ...) with no iteration and computation step
if (MEDmeshNodeCoordinateWr(fid, meshname, MED_NO_DT, MED_NO_IT, 0.0,
MED_FULL_INTERLACE, nnodes, coordinates) < 0) {
MESSAGE("ERROR : nodes coordinates ...");
goto ERROR;
/* cells connectiviy is defined in nodal mode */
MED_NODAL, MED_FULL_INTERLACE, ntria3, triaconnectivity) < 0) {
MESSAGE("ERROR : triangular cells connectivity ...");
goto ERROR;
MED_NODAL, MED_FULL_INTERLACE, nquad4, quadconnectivity) < 0) {
MESSAGE("ERROR : quadrangular cells connectivity ...");
goto ERROR;
/* create family 0 : by default, all mesh entities family number is 0 */
if (MEDfamilyCr(fid, meshname,MED_NO_NAME, 0, 0, MED_NO_GROUP) < 0) {
MESSAGE("ERROR : family creation ...");
goto ERROR;
/* create a family for boundary vertices : by convention a nodes family number is > 0,
and an element family number is < 0 */
if (MEDfamilyCr(fid, meshname,familyname, 1, 1, groupname) < 0) {
goto ERROR;
/* write family number for nodes */
MED_NODE, MED_NONE, nnodes, familynumbers) < 0) {
MESSAGE("ERROR : nodes family numbers ...");
goto ERROR;
ret=0;
ERROR:
/* close MED file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
MEDfamilyCr
MEDC_EXPORT med_err MEDfamilyCr(const med_idt fid, const char *const meshname, const char *const familyname, const med_int familynumber, const med_int ngroup, const char *const groupname)
Cette routine permet la création d'une famille portant sur les entités d'un maillage.
Definition: MEDfamilyCr.c:40
MEDC_EXPORT med_err MEDmeshNodeCoordinateWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_switch_mode switchmode, const med_int nentity, const med_float *const coordinates)
Definition: MEDmeshNodeCoordinateWr.c:45
MED_NODAL
Definition: med.h:259
main
Definition: 3.0.8/test10.c:50
MED_NO_NAME
#define MED_NO_NAME
Definition: med.h:272
MED_QUAD4
#define MED_QUAD4
Definition: med.h:208
MED_TRIA3
#define MED_TRIA3
Definition: med.h:207
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_idt
hid_t med_idt
Definition: med.h:335
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
MEDmeshEntityFamilyNumberWr
MEDC_EXPORT med_err MEDmeshEntityFamilyNumberWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_int nentity, const med_int *const number)
Cette routine permet l'écriture des numéros de famille d'un type d'entité d'un maillage.
Definition: MEDmeshEntityFamilyNumberWr.c:39
med_int
int med_int
Definition: med.h:346
MEDfileCommentWr
med_err MEDfileCommentWr(const med_idt fid, const char *const description)
\MEDfileCommentWrBrief
Definition: MEDfileCommentWr.c:37
MED_NODE
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_NONE
#define MED_NONE
Definition: med.h:235
Definition: med.h:134
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MEDmeshElementConnectivityWr
MEDC_EXPORT med_err MEDmeshElementConnectivityWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_geometry_type geotype, const med_connectivity_mode cmode, const med_switch_mode switchmode, const med_int nentity, const med_int *const connectivity)
Cette routine permet d'écrire dans un maillage le tableau des connectivités pour un type géométrique ...
Definition: MEDmeshElementConnectivityWr.c:42
MED_ACC_CREAT
Definition: med.h:126
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MEDmeshCr
Definition: MEDmeshCr.c:45
MED_LNAME_SIZE
#define MED_LNAME_SIZE
Definition: med.h:84
MED_NO_GROUP
#define MED_NO_GROUP
Definition: med.h:293
MED_CARTESIAN
Definition: med.h:262
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_SORT_DTIT
Definition: med.h:313
