MED fichier
usecases/c/UsesCase_MEDmesh_16.c
/* This file is part of MED.
* How to create an unstructured mesh with polyhedrons
* Use case 16 : read a 3D unstructured mesh with 2 polyhedrons
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid;
const char meshname[MED_NAME_SIZE+1] = "3D Unstructured Mesh With 2 polyhedrons";
char meshdescription[MED_COMMENT_SIZE+1];
med_int meshdim;
med_int spacedim;
med_sorting_type sortingtype;
med_int nstep;
med_mesh_type meshtype;
med_axis_type axistype;
char axisname[3*MED_SNAME_SIZE+1];
char unitname[3*MED_SNAME_SIZE+1];
char dtunit[MED_SNAME_SIZE+1];
med_float *coordinates = NULL;
med_int nnodes = 0;
med_int npoly = 0;
med_int faceindexsize;
med_int nodeindexsize;
med_int *faceindex = NULL;
med_int *nodeindex = NULL;
med_int *connectivity = NULL;
med_int connectivitysize;
med_bool coordinatechangement;
med_bool geotransformation;
int i;
int k,ind1,ind2;
int j, jind1,jind2;
/* open MED file with READ ONLY access mode */
fid = MEDfileOpen("./UsesCase_MEDmesh_15.med",MED_ACC_RDONLY);
if (fid < 0) {
MESSAGE("ERROR : open file in READ ONLY ACCESS mode ...");
return -1;
* ... we know that the MED file has only one mesh,
* a real code would check ...
/* read mesh informations : mesh dimension, space dimension ... */
if (MEDmeshInfoByName(fid, meshname, &spacedim, &meshdim, &meshtype, meshdescription,
dtunit, &sortingtype, &nstep, &axistype, axisname, unitname) < 0) {
MESSAGE("ERROR : mesh info ...");
return -1;
/* read how many nodes are in the mesh */
if ((nnodes = MEDmeshnEntity(fid, meshname, MED_NO_DT, MED_NO_IT, MED_NODE, MED_POINT1,
MED_COORDINATE, MED_NO_CMODE,&coordinatechangement, &geotransformation)) < 0)
{ MESSAGE("ERROR : number of nodes ...");
return -1;
* ... we know that we only have MED_POLYHEDRON cells in the mesh,
* a real code would check for MED geometry cell types ...
/* We read how many polyhedrons are in the mesh (using nodal connectivity mode) */
/* We get the size of the polyhedrons/face index array.
* As an index of the face index array give the location of the first face and so the
* number of polyhedrons
if ((faceindexsize = MEDmeshnEntity(fid,meshname,MED_NO_DT,MED_NO_IT,
{ MESSAGE("ERROR : read number of polyhedrons ...");
return -1;
npoly = faceindexsize-1;
ISCRUTE(npoly);
if ((nodeindexsize = MEDmeshnEntity(fid,meshname,MED_NO_DT,MED_NO_IT,
return -1;
ISCRUTE(nodeindexsize);
/* how many nodes for the polyhedron connectivity ? */
if ((connectivitysize = MEDmeshnEntity(fid,meshname,MED_NO_DT,MED_NO_IT,
{ MESSAGE("ERROR : read connectivity size ...");
return -1;
ISCRUTE(connectivitysize);
/* read mesh nodes coordinates */
if ((coordinates = (med_float*) malloc(sizeof(med_float)*nnodes*spacedim)) == NULL) {
MESSAGE("ERROR : memory allocation ...");
return -1;
coordinates) < 0) {
MESSAGE("ERROR : nodes coordinates ...");
return -1;
for (i=0;i<nnodes*spacedim;i++)
printf("%f - ",*(coordinates+i));
printf("\n");
/* read polyhedron connectivity */
faceindex = (med_int *) malloc(sizeof(med_int)*faceindexsize);
nodeindex = (med_int *) malloc(sizeof(med_int)*nodeindexsize);
connectivity = (med_int *) malloc(sizeof(med_int)*connectivitysize);
faceindex,nodeindex,connectivity) < 0)
{ MESSAGE("ERROR : read polyhedron connectivity ...");
return -1;
for (i=0;i<npoly;i++)
printf(">> MED_POLYHEDRON %d : \n",i+1);
printf("---- Face Index ----- : [\n");
ind1 = *(faceindex+i)-1;
ind2 = *(faceindex+i+1)-1;
for (k=ind1;k<ind2;k++)
printf(IFORMAT" ",*(nodeindex+k));
printf(" ] \n");
printf("---- Connectivity ----- : [\n");
jind1 = *(nodeindex+k)-1;
jind2 = *(nodeindex+k+1)-1;
for (j=jind1;j<jind2;j++)
printf(IFORMAT" ",*(connectivity+j));
printf(" \n");
printf(" ] \n");
* ... we know that the family number of nodes and elements is 0, a real code would check ...
/* close MED file */
if (MEDfileClose(fid) < 0) {
MESSAGE("ERROR : close file");
return -1;
/* memory deallocation */
if (coordinates)
free(coordinates);
if (faceindex)
free(faceindex);
if (nodeindex)
free(nodeindex);
if (connectivity)
free(connectivity);
return 0;
MED_NODAL
Definition: med.h:259
main
Definition: 3.0.8/test10.c:50
MED_INDEX_NODE
Definition: med.h:154
MED_COMMENT_SIZE
#define MED_COMMENT_SIZE
Definition: med.h:80
med_sorting_type
med_sorting_type
Definition: med.h:313
MEDmeshnEntity
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
MED_ACC_RDONLY
Definition: med.h:123
med_idt
hid_t med_idt
Definition: med.h:335
MEDmeshInfoByName
MEDC_EXPORT med_err MEDmeshInfoByName(const med_idt fid, const char *const meshname, med_int *const spacedim, med_int *const meshdim, med_mesh_type *const meshtype, char *const description, char *const dtunit, med_sorting_type *const sortingtype, med_int *const nstep, med_axis_type *const axistype, char *const axisname, char *const axisunit)
Cette routine permet de lire les informations relatives à un maillage en précisant son nom.
Definition: MEDmeshInfoByName.c:42
MED_FULL_INTERLACE
Definition: med.h:99
ISCRUTE
#define ISCRUTE(entier)
Definition: med_utils.h:313
med_float
double med_float
Definition: med.h:340
med_bool
med_bool
Definition: med.h:264
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MED_POINT1
#define MED_POINT1
Definition: med.h:202
MEDmeshPolyhedronRd
MEDC_EXPORT med_err MEDmeshPolyhedronRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_connectivity_mode cmode, med_int *const faceindex, med_int *const nodeindex, med_int *const connectivity)
Cette routine permet la lecture dans un maillage des connectivités de polyèdres.
Definition: MEDmeshPolyhedronRd.c:45
MED_INDEX_FACE
MED_NODE
med_mesh_type
med_mesh_type
Definition: med.h:134
MEDmeshNodeCoordinateRd
MEDC_EXPORT med_err MEDmeshNodeCoordinateRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_switch_mode switchmode, med_float *const coordinates)
Cette routine permet de lire dans un maillage le tableau des coordonnées des noeuds,...
Definition: MEDmeshNodeCoordinateRd.c:37
IFORMAT
#define IFORMAT
Definition: med_utils.h:145
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_CONNECTIVITY
Definition: med.h:152
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
med_axis_type
med_axis_type
Definition: med.h:262
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_COORDINATE
MED_POLYHEDRON
#define MED_POLYHEDRON
Definition: med.h:229
MED_NO_CMODE
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
