MED fichier
usecases/c/UsesCase_MEDstructElement_3.c
/* This file is part of MED.
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
* StructElement use case 3 : read struct element models in a file from a computation mesh
med_idt fid;
med_int nmodels, nsmesh;
int i,j;
char elementname[MED_NAME_SIZE+1]="";
char supportmeshname[MED_NAME_SIZE+1]="";
const char computmeshname[MED_NAME_SIZE+1]="COMPUT_MESH";
med_entity_type entitype;
med_int elementdim;
med_int nnode,ncell;
med_geometry_type geocelltype;
med_bool anyprofile=0;
med_int nconstatt, *nvaratt=NULL;
char attname[MED_NAME_SIZE+1]="";
char profilename[MED_NAME_SIZE+1]="";
med_int nattcomp;
med_entity_type attentitype;
med_int profilesize;
med_float *value=NULL;
med_int size=0;
med_int meshdim, spacedim;
char axisname[3*MED_SNAME_SIZE+1]="";
char axisunit[3*MED_SNAME_SIZE+1]="";
med_axis_type axistype;
med_float *coordinates=NULL;
med_bool coordinatechangement;
med_bool geotransformation;
med_int nseg2;
med_int *seg2connectivity=NULL;
med_int nentities=0;
med_sorting_type sortingtype;
med_mesh_type meshtype;
med_int nstep;
char unitname[2*MED_SNAME_SIZE+1]="";
int ret=-1;
/* open file */
fid = MEDfileOpen("UsesCase_MEDstructElement_1.med",MED_ACC_RDONLY);
if (fid < 0) {
goto ERROR;
* ... In this case, we know that the MED file has only one mesh,
* a real code would check ...
/* read mesh informations : mesh dimension, space dimension ... */
if (MEDmeshInfoByName(fid, computmeshname, &spacedim, &meshdim, &meshtype, description,
dtunit, &sortingtype, &nstep, &axistype, axisname, unitname) < 0) {
MESSAGE("ERROR : mesh info ...");
goto ERROR;
/* read how many struct element models in the mesh ? */
if ((nmodels = MEDmeshnEntity(fid, computmeshname, MED_NO_DT, MED_NO_IT, MED_STRUCT_ELEMENT, MED_GEO_ALL,
MED_UNDEF_DATATYPE, MED_NO_CMODE,&coordinatechangement,
&geotransformation)) < 0) {
MESSAGE("ERROR : number of nodes ...");
goto ERROR;
geotype = (med_geometry_type *) malloc(sizeof(med_geometry_type)*nmodels);
nvaratt = (med_int *) malloc(sizeof(med_int)*nmodels);
/* Get the name and the geotype of each struct element model used in the computation mesh.
For each struct element geotype read the connectivity and the attribute(s)
The mesh support may be read if needed.
for (i=0;i<nmodels;i++) {
/* read the geotype */
if (MEDmeshEntityInfo(fid, computmeshname, MED_NO_DT, MED_NO_IT, MED_STRUCT_ELEMENT,i+1,elementname,(geotype+i)) < 0) {
MESSAGE("ERROR : name and type of MED_STRUCT_ELEMENT ...");
goto ERROR;
/* read how many MED_STRUCT_ELEMENT of type *(geotype+i) there is in the mesh */
if ((nentities = MEDmeshnEntity(fid, computmeshname, MED_NO_DT, MED_NO_IT, MED_STRUCT_ELEMENT,*(geotype+i),
MED_CONNECTIVITY, MED_NODAL, &coordinatechangement,
MESSAGE("ERROR : number of MED_STRUCT_ELEMENT ...");
goto ERROR;
/* read informations about the model */
if (MEDstructElementInfoByName(fid, elementname, geotype+i, &elementdim,
supportmeshname, &entitype, &nnode, &ncell,
&geocelltype, &nconstatt, &anyprofile, nvaratt+i) < 0) {
MESSAGE("ERROR : struct element models information ...");
goto ERROR;
/* read support mesh */
/* TODO : Ceci est optionnel dans ce usescase */
if (strcmp(supportmeshname,"")) {
if ( MEDsupportMeshInfoByName(fid, supportmeshname, &spacedim, &meshdim, description,
&axistype, axisname, axisunit) < 0 ) {
MESSAGE("ERROR : read information about mesh support ...");
goto ERROR;
ISCRUTE(nnode);
/* read how many nodes in the support mesh */
/* Ceci est optionnel dans ce usescase */
if ((nnode = MEDmeshnEntity(fid, supportmeshname, MED_NO_DT, MED_NO_IT, MED_NODE, MED_NONE,
MED_COORDINATE, MED_NO_CMODE,&coordinatechangement,
MESSAGE("ERROR : read number of nodes ...");
goto ERROR;
ISCRUTE(nnode);
/* read support mesh nodes coordinates */
coordinates = (med_float*) malloc(sizeof(med_float)*nnode*spacedim);
coordinates) < 0) {
MESSAGE("ERROR : read nodes coordinates ...");
free(coordinates);
goto ERROR;
/* free memory */
free(coordinates);
/* read how many MED_SEG2 cells in the support mesh */
if ((nseg2 = MEDmeshnEntity(fid, supportmeshname, MED_NO_DT, MED_NO_IT, MED_CELL,geocelltype,
MESSAGE("ERROR : number of MED_SEG2 ...");
goto ERROR;
ISCRUTE(nseg2);
ISCRUTE(ncell);
/* read MED_SEG2 connectivity in the support mesh */
if (nseg2 > 0) {
seg2connectivity = (med_int *) malloc(sizeof(med_int)*nseg2*2);
geocelltype, MED_NODAL, MED_FULL_INTERLACE, seg2connectivity) < 0) {
MESSAGE("ERROR : MED_SEG2 connectivity ...");
free(seg2connectivity);
goto ERROR;
/* read constant attribute(s) */
/* Optionnel pour ce usescase (cf. usescase lecture modèle) */
for (j=0; j<nconstatt; j++) {
if ( MEDstructElementConstAttInfo(fid, elementname, j+1,
attname, &atttype, &nattcomp, &attentitype,
profilename, &profilesize) < 0) {
MESSAGE("ERROR : const attribute information ...");
goto ERROR;
/* if there is a profile => read the profile, see UsesCase_MEDprofile_2 */
/* memory allocation */
if (profilesize != 0)
size = profilesize*nattcomp*MEDstructElementAttSizeof(atttype);
else
if (attentitype== MED_NODE)
size = nnode*nattcomp*MEDstructElementAttSizeof(atttype);
else
size = ncell*nattcomp*MEDstructElementAttSizeof(atttype);
if ( atttype == MED_ATT_NAME) ++size;
ISCRUTE(size);
value = (med_float *) malloc(size);
/* read attribute(s) value(s) */
if ( MEDstructElementConstAttRd(fid, elementname, attname, (unsigned char *)value ) < 0 ) {
MESSAGE("ERROR : const attribute value ...");
free(value);
goto ERROR;
/* memory deallocation */
free(value);
/* read variable attribute(s) */
for (j=0; j<*(nvaratt+i); j++) {
/* read informations about the attribute */
if ( MEDstructElementVarAttInfo(fid, elementname, j+1,
attname, &atttype, &nattcomp) < 0) {
MESSAGE("ERROR : var attribute information ...");
goto ERROR;
size = nentities*nattcomp*MEDstructElementAttSizeof(atttype);
ISCRUTE(size);
value = (med_float *) malloc((size)*sizeof(char));
/* read attribute values */
*(geotype+i), attname, value ) < 0) {
MESSAGE("ERROR : read variable attributes values ...");
free(value);
goto ERROR;
/* free memory */
free(value);
ret=0;
ERROR:
/* free memory */
free(geotype);
free(nvaratt);
/* close file */
if (MEDfileClose(fid) < 0) {
MESSAGE("ERROR : file closing ...");
ret=-1;
return ret;
MED_ATT_NAME
Definition: med.h:178
MEDC_EXPORT int MEDstructElementAttSizeof(const med_attribute_type atttype)
Cette routine renvoie la taille en octets du type élémentaire atttype.
Definition: MEDstructElementAttSizeof.c:36
MEDC_EXPORT med_err MEDsupportMeshInfoByName(const med_idt fid, const char *const supportmeshname, med_int *const spacedim, med_int *const meshdim, char *const description, med_axis_type *const axistype, char *const axisname, char *const axisunit)
Cette routine permet de lire les informations relatives à un maillage support en précisant son nom.
Definition: MEDsupportMeshInfoByName.c:39
MED_NODAL
Definition: med.h:259
main
Definition: 3.0.8/test10.c:50
MEDC_EXPORT med_err MEDstructElementConstAttRd(const med_idt fid, const char *const modelname, const char *const constattname, void *const value)
Cette routine lit la valeur d'un attribut caractéristique constant d'un modèle d'éléments de structur...
Definition: MEDstructElementConstAttRd.c:42
MEDmeshStructElementVarAttRd
MEDC_EXPORT med_err MEDmeshStructElementVarAttRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_geometry_type mgeotype, const char *const varattname, void *const value)
Cette routine lit les valeurs d'un attribut caractéristique variable sur les éléments de structure d'...
Definition: MEDmeshStructElementVarAttRd.c:43
MEDC_EXPORT med_err MEDstructElementConstAttInfo(const med_idt fid, const char *const modelname, const int attit, char *const constattname, med_attribute_type *const constatttype, med_int *const ncomponent, med_entity_type *const sentitytype, char *const profilename, med_int *const profilesize)
Cette routine décrit les caractéristiques d'un attribut constant de modèle d'élément de structure par...
Definition: MEDstructElementConstAttInfo.c:45
MEDmeshEntityInfo
MEDC_EXPORT med_err MEDmeshEntityInfo(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const int geotypeit, char *const geotypename, med_geometry_type *const geotype)
Cette routine indique de façon itérative les types géométriques disponibles dans un maillage.
Definition: MEDmeshEntityInfo.c:41
description
const char *const description
Definition: medfile.h:65
MED_COMMENT_SIZE
#define MED_COMMENT_SIZE
Definition: med.h:80
med_sorting_type
med_sorting_type
Definition: med.h:313
MEDmeshnEntity
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_entity_type
med_entity_type
Definition: med.h:146
MED_ACC_RDONLY
Definition: med.h:123
med_idt
hid_t med_idt
Definition: med.h:335
MEDmeshInfoByName
MEDC_EXPORT med_err MEDmeshInfoByName(const med_idt fid, const char *const meshname, med_int *const spacedim, med_int *const meshdim, med_mesh_type *const meshtype, char *const description, char *const dtunit, med_sorting_type *const sortingtype, med_int *const nstep, med_axis_type *const axistype, char *const axisname, char *const axisunit)
Cette routine permet de lire les informations relatives à un maillage en précisant son nom.
Definition: MEDmeshInfoByName.c:42
med_attribute_type
med_attribute_type
Definition: med.h:176
MED_FULL_INTERLACE
Definition: med.h:99
ISCRUTE
#define ISCRUTE(entier)
Definition: med_utils.h:313
med_float
double med_float
Definition: med.h:340
med_bool
med_bool
Definition: med.h:264
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
MED_GEO_ALL
#define MED_GEO_ALL
Definition: med.h:240
med_utils.h
MED_CELL
med_int
int med_int
Definition: med.h:346
MED_NODE
med_mesh_type
med_mesh_type
Definition: med.h:134
MEDmeshNodeCoordinateRd
MEDC_EXPORT med_err MEDmeshNodeCoordinateRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_switch_mode switchmode, med_float *const coordinates)
Cette routine permet de lire dans un maillage le tableau des coordonnées des noeuds,...
Definition: MEDmeshNodeCoordinateRd.c:37
MEDmeshElementConnectivityRd
MEDC_EXPORT med_err MEDmeshElementConnectivityRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_connectivity_mode cmode, const med_switch_mode switchmode, med_int *const connectivity)
Cette routine permet de lire dans un maillage le tableau des connectivités pour un type géométrique d...
Definition: MEDmeshElementConnectivityRd.c:40
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
MED_NONE
#define MED_NONE
Definition: med.h:235
MED_CONNECTIVITY
Definition: med.h:152
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
med_axis_type
med_axis_type
Definition: med.h:262
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_UNDEF_DATATYPE
Definition: med.h:155
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_COORDINATE
MEDC_EXPORT med_err MEDstructElementInfoByName(const med_idt fid, const char *const modelname, med_geometry_type *const mgeotype, med_int *const modeldim, char *const supportmeshname, med_entity_type *const sentitytype, med_int *const snnode, med_int *const sncell, med_geometry_type *const sgeotype, med_int *const nconstantatribute, med_bool *const anyprofile, med_int *const nvariableattribute)
Cette routine décrit les caractéristiques d'un modèle d'élément de structure à partir de son nom.
Definition: MEDstructElementInfoByName.c:49
MEDC_EXPORT med_err MEDstructElementVarAttInfo(const med_idt fid, const char *const modelname, const int attit, char *const varattname, med_attribute_type *const varatttype, med_int *const ncomponent)
Cette routine décrit les caractéristiques d'un attribut variable de modèle d'élément de structure par...
Definition: MEDstructElementVarAttInfo.c:41
MED_STRUCT_ELEMENT
Definition: med.h:147
MED_NO_CMODE
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
med_geometry_type
int med_geometry_type
Definition: med.h:198
