MED fichier
usecases/c/UsesCase_MEDmesh_9.c
/* This file is part of MED.
* How to create an unstructured mesh
* Use case 9 : a 2D unstructured mesh with moving grid
* transformation
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
med_idt fid;
const med_int spacedim = 2;
const med_int meshdim = 2;
const char axisname[2*MED_SNAME_SIZE+1] = "x y ";
const char unitname[2*MED_SNAME_SIZE+1] = "cm cm ";
const med_float initial_coordinates[30] = { 2.,1., 7.,1., 12.,1., 17.,1., 22.,1.,
2.,6., 7.,6., 12.,6., 17.,6., 22.,6.,
2.,11., 7.,11., 12.,11., 17.,11., 22.,11.};
const med_int nnodes = 15;
const med_int triaconnectivity[24] = { 1,7,6, 2,7,1, 3,7,2, 8,7,3,
13,7,8, 12,7,13, 11,7,12, 6,7,11 };
const med_int ntria3 = 8;
const med_int quadconnectivity[16] = {3,4,9,8, 4,5,10,9,
15,14,9,10, 13,8,9,14};
const med_int nquad4 = 4;
/* matrix transformation (step 1) : rotation about the Y-axis : 45 degrees */
const med_float tansfMatrix_step1 [7] = { 0.0, 0.0, 0.0, 0.92388, 0.0, 0.38268, 0.0 };
/* matrix transformation (step 2) : rotation about the Y-axis : 90 degrees */
const med_float tansfMatrix_step2 [7] = { 0.0, 0.0, 0.0, 0.707, 0.0, 0.707, 0.0 };
int ret=-1;
/* open MED file */
fid = MEDfileOpen("UsesCase_MEDmesh_9.med",MED_ACC_CREAT);
if (fid < 0) {
goto ERROR;
/* write a comment in the file */
if (MEDfileCommentWr(fid,"A 2D unstructured mesh : 15 nodes, 12 cells") < 0) {
MESSAGE("ERROR : write file description ...");
goto ERROR;
/* mesh creation : a 2D unstructured mesh */
if (MEDmeshCr(fid, meshname, spacedim, meshdim, MED_UNSTRUCTURED_MESH,
"A 2D structured mesh","",MED_SORT_DTIT,MED_CARTESIAN, axisname, unitname) < 0) {
MESSAGE("ERROR : mesh creation ...");
goto ERROR;
/* nodes coordinates in a cartesian axis in full interlace mode
(X1,Y1, X2,Y2, X3,Y3, ...) with no iteration and computation step
nnodes, initial_coordinates) < 0) {
MESSAGE("ERROR : nodes coordinates ...");
goto ERROR;
/* cells connectiviy is defined in nodal mode */
ntria3, triaconnectivity) < 0) {
MESSAGE("ERROR : triangular cells connectivity ...");
goto ERROR;
nquad4, quadconnectivity) < 0) {
MESSAGE("ERROR : quadrangular cells connectivity ...");
goto ERROR;
* Mesh deformation (nodes coordinates) in 2 steps
* A rotation by step for each node
/* STEP 1 : dt1 = 5.5, it = 1*/
if ( MEDmeshNodeCoordinateTrsfWr(fid, meshname, 1, 1, 5.5, tansfMatrix_step1) < 0) {
MESSAGE("Erreur a l'ecriture de la transformation géométrique n°1");
goto ERROR;
/* STEP 2 : dt2 = 8.9, it = 1*/
if ( MEDmeshNodeCoordinateTrsfWr(fid, meshname, 2, 2, 8.9, tansfMatrix_step2 ) < 0) {
MESSAGE("Erreur a l'ecriture de la transformation géométrique n°2");
goto ERROR;
/* create family 0 : by default, all mesh entities family number is 0 */
if (MEDfamilyCr(fid, meshname,MED_NO_NAME, 0, 0, MED_NO_GROUP) < 0) {
MESSAGE("ERROR : create family ...");
goto ERROR;
ret=0;
ERROR:
/* close MED file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
MEDfamilyCr
MEDC_EXPORT med_err MEDfamilyCr(const med_idt fid, const char *const meshname, const char *const familyname, const med_int familynumber, const med_int ngroup, const char *const groupname)
Cette routine permet la création d'une famille portant sur les entités d'un maillage.
Definition: MEDfamilyCr.c:40
MED_NODAL
Definition: med.h:259
main
Definition: 3.0.8/test10.c:50
MED_NO_NAME
#define MED_NO_NAME
Definition: med.h:272
MED_QUAD4
#define MED_QUAD4
Definition: med.h:208
MED_TRIA3
#define MED_TRIA3
Definition: med.h:207
MED_COMPACT_STMODE
Definition: med.h:113
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_idt
hid_t med_idt
Definition: med.h:335
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
med_int
int med_int
Definition: med.h:346
MEDfileCommentWr
med_err MEDfileCommentWr(const med_idt fid, const char *const description)
\MEDfileCommentWrBrief
Definition: MEDfileCommentWr.c:37
MEDmeshNodeCoordinateWithProfileWr
MEDC_EXPORT med_err MEDmeshNodeCoordinateWithProfileWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_storage_mode storagemode, const char *const profilename, const med_switch_mode switchmode, const med_int dimselect, const med_int nentity, const med_float *const coordinates)
Definition: MEDmeshNodeCoordinateWithProfileWr.c:46
MED_NO_DT
#define MED_NO_DT
Definition: med.h:324
Definition: med.h:134
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
MED_ACC_CREAT
Definition: med.h:126
MEDC_EXPORT med_err MEDmeshNodeCoordinateTrsfWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_float *const coordinatetrsf)
Cette routine définit les paramètres de translation rotation à appliquer aux noeuds de l'étape de cal...
Definition: MEDmeshNodeCoordinateTrsfWr.c:41
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MEDmeshElementConnectivityWithProfileWr
MEDC_EXPORT med_err MEDmeshElementConnectivityWithProfileWr(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_float dt, const med_entity_type entitype, const med_geometry_type geotype, const med_connectivity_mode cmode, const med_storage_mode storagemode, const char *const profilename, const med_switch_mode switchmode, const med_int dimselect, const med_int nentity, const med_int *const connectivity)
Cette routine permet d'écrire dans un maillage le tableau des connectivités pour un type géométrique ...
Definition: MEDmeshElementConnectivityWithProfileWr.c:45
MED_ALL_CONSTITUENT
#define MED_ALL_CONSTITUENT
Definition: med.h:303
MEDmeshCr
Definition: MEDmeshCr.c:45
MED_NO_PROFILE
#define MED_NO_PROFILE
Definition: med.h:285
MED_NO_GROUP
#define MED_NO_GROUP
Definition: med.h:293
MED_CARTESIAN
Definition: med.h:262
MED_NO_IT
#define MED_NO_IT
Definition: med.h:325
MED_SORT_DTIT
Definition: med.h:313
