#define MESGERR 1
#include <string.h>
int main (
int argc,
char **argv) {
int i;
int ret = -1;
if (fid < 0) {
MESSAGE(
"ERROR : open file in READ ONLY ACCESS mode ...");
goto ERROR;
if (
MEDmeshInfoByName(fid, meshname, &spacedim, &meshdim, &meshtype, meshdescription,
dtunit, &sortingtype, &nstep, &axistype, axisname, unitname) < 0) {
goto ERROR;
&geotransformation)) < 0) {
MESSAGE(
"ERROR : number of nodes ...");
goto ERROR;
MESSAGE(
"ERROR : number of MED_TRIA3 ...");
goto ERROR;
MESSAGE(
"ERROR : number of MED_QUAD4 ...");
goto ERROR;
MESSAGE(
"ERROR : memory allocation ...");
goto ERROR;
coordinates) < 0) {
MESSAGE(
"ERROR : nodes coordinates ...");
goto ERROR;
if ((triaconnectivity = (
med_int *) malloc(
sizeof(
med_int)*ntria3*3)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : MED_TRIA3 connectivity ...");
goto ERROR;
if ((quadconnectivity = (
med_int *) malloc(
sizeof(
med_int)*nquad4*4)) == NULL) {
MESSAGE(
goto ERROR;
MESSAGE(
"ERROR : MED_QUAD4 connectivity ...");
goto ERROR;
ret = 0;
ERROR :
if (coordinates)
free(coordinates);
if (triaconnectivity)
free(triaconnectivity);
if (quadconnectivity)
free(quadconnectivity);
ret = -1;
return ret;
MEDC_EXPORT med_err MEDmeshInfoByName(const med_idt fid, const char *const meshname, med_int *const spacedim, med_int *const meshdim, med_mesh_type *const meshtype, char *const description, char *const dtunit, med_sorting_type *const sortingtype, med_int *const nstep, med_axis_type *const axistype, char *const axisname, char *const axisunit)
Cette routine permet de lire les informations relatives à un maillage en précisant son nom.
MEDC_EXPORT med_err MEDmeshNodeCoordinateRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_switch_mode switchmode, med_float *const coordinates)
Cette routine permet de lire dans un maillage le tableau des coordonnées des noeuds,...
MEDC_EXPORT med_err MEDmeshElementConnectivityRd(const med_idt fid, const char *const meshname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_connectivity_mode cmode, const med_switch_mode switchmode, med_int *const connectivity)
Cette routine permet de lire dans un maillage le tableau des connectivités pour un type géométrique d...
Fermeture d'un fichier MED.
Ouverture d'un fichier MED.
