MED fichier
usecases/c/UsesCase_MEDfield_6.c
/* This file is part of MED.
* Field use case 6 : read a field (generic approach) with computing steps
#include <med.h>
#define MESGERR 1
#include <med_utils.h>
#include <string.h>
#include <med.h>
#define MESGERR 1
#include <string.h>
med_idt fid;
med_idt nfield, i, j;
char meshname[MED_NAME_SIZE+1]="";
med_bool localmesh;
char fieldname[MED_NAME_SIZE+1]="";
med_field_type fieldtype;
char *componentname = NULL;
char *componentunit = NULL;
med_float *values = NULL;
med_int nstep, nvalues;
med_int ncomponent;
med_int csit, numit, numdt, meshnumit, meshnumdt, it;
int k;
int ret=-1;
/* open file */
fid = MEDfileOpen("UsesCase_MEDfield_4.med",MED_ACC_RDONLY);
if (fid < 0) {
MESSAGE("ERROR : open file ...");
goto ERROR;
* generic approach : how many fields in the file and identification
* of each field.
if ((nfield = MEDnField(fid)) < 0) {
MESSAGE("ERROR : How many fields in the file ...");
goto ERROR;
* read values for each field
for (i=0; i<nfield; i++) {
if ((ncomponent = MEDfieldnComponent(fid,i+1)) < 0) {
MESSAGE("ERROR : number of field component ...");
goto ERROR;
if ((componentname = (char *) malloc(ncomponent*MED_SNAME_SIZE+1)) == NULL) {
MESSAGE("ERROR : memory allocation ...");
goto ERROR;
if ((componentunit = (char *) malloc(ncomponent*MED_SNAME_SIZE+1)) == NULL) {
goto ERROR;
if (MEDfieldInfo(fid, i+1, fieldname, meshname, &localmesh, &fieldtype,
componentname, componentunit, dtunit, &nstep) < 0) {
MESSAGE("ERROR : Field info ...");
free(componentname);
free(componentunit);
goto ERROR;
* Read field values for each computing step
for (csit=0; csit<nstep; csit++) {
if (MEDfieldComputingStepMeshInfo(fid, fieldname, csit+1, &numdt, &numit, &dt,
&meshnumdt, &meshnumit) < 0) {
MESSAGE("ERROR : Computing step info ...");
goto ERROR;
* ... In our case, we suppose that the field values are only defined on cells ...
for (it=1; it<=MED_N_CELL_FIXED_GEO; it++) {
geotype = geotypes[it];
if ((nvalues = MEDfieldnValue(fid, fieldname, numdt, numit, MED_CELL, geotype)) < 0) {
MESSAGE("ERROR : read number of values ...");
goto ERROR;
if (nvalues) {
if ((values = (med_float *) malloc(sizeof(med_float)*nvalues*ncomponent)) == NULL) {
goto ERROR;
if (MEDfieldValueRd(fid, fieldname, numdt, numit, MED_CELL, geotype,
MED_FULL_INTERLACE, MED_ALL_CONSTITUENT, (unsigned char*) values) < 0) {
MESSAGE("ERROR : read fields values for cells ...");
free(values);
goto ERROR;
free(values);
ret=0;
ERROR:
/* close file */
if (MEDfileClose(fid) < 0) {
ret=-1;
return ret;
MEDC_EXPORT med_err MEDfieldComputingStepMeshInfo(const med_idt fid, const char *const fieldname, const int csit, med_int *const numdt, med_int *const numit, med_float *const dt, med_int *const meshnumdt, med_int *const meshnumit)
Cette fonction permet de lire les informations caractérisant une étape de calcul : numéro de pas de t...
Definition: MEDfieldComputingStepMeshInfo.c:39
main
Definition: 3.0.8/test10.c:50
MED_SNAME_SIZE
#define MED_SNAME_SIZE
Definition: med.h:83
med_field_type
med_field_type
Definition: med.h:168
MED_ACC_RDONLY
Definition: med.h:123
med_idt
hid_t med_idt
Definition: med.h:335
MED_FULL_INTERLACE
Definition: med.h:99
med_float
double med_float
Definition: med.h:340
med_bool
med_bool
Definition: med.h:264
MESSAGE
#define MESSAGE(chaine)
Definition: med_utils.h:324
med_utils.h
MED_CELL
Definition: med.h:146
MEDfieldnComponent
MEDC_EXPORT med_int MEDfieldnComponent(const med_idt fid, const int ind)
Cette fonction lit le nombre de composantes d'un champ.
Definition: MEDfieldnComponent.c:34
med_int
int med_int
Definition: med.h:346
MED_GET_CELL_GEOMETRY_TYPE
med_geometry_type MED_GET_CELL_GEOMETRY_TYPE[MED_N_CELL_FIXED_GEO+2]
Definition: MEDiterators.c:55
MEDfieldInfo
MEDC_EXPORT med_err MEDfieldInfo(const med_idt fid, const int ind, char *const fieldname, char *const meshname, med_bool *const localmesh, med_field_type *const fieldtype, char *const componentname, char *const componentunit, char *const dtunit, med_int *const ncstp)
Cette fonction permet de lire les informations concernant le champ d'indice ind .
Definition: MEDfieldInfo.c:42
MEDfieldnValue
MEDC_EXPORT med_int MEDfieldnValue(const med_idt fid, const char *const fieldname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype)
Cette fonction permet de lire le nombre de valeurs dans un champ pour une étape de calcul,...
Definition: MEDfieldnValue.c:38
MEDnField
MEDC_EXPORT med_int MEDnField(const med_idt fid)
Cette fonction permet de lire le nombre de champs dans un fichier.
Definition: MEDnField.c:35
MEDfileClose
Fermeture d'un fichier MED.
Definition: MEDfileClose.c:30
med.h
MEDfileOpen
Ouverture d'un fichier MED.
Definition: MEDfileOpen.c:42
#define MED_N_CELL_FIXED_GEO
Definition: med.h:243
MED_NAME_SIZE
#define MED_NAME_SIZE
Definition: med.h:82
MED_ALL_CONSTITUENT
#define MED_ALL_CONSTITUENT
Definition: med.h:303
MEDfieldValueRd
MEDC_EXPORT med_err MEDfieldValueRd(const med_idt fid, const char *const fieldname, const med_int numdt, const med_int numit, const med_entity_type entitype, const med_geometry_type geotype, const med_switch_mode switchmode, const med_int componentselect, unsigned char *const value)
Cette fonction permet de lire les valeurs d'un champ définies sur des entités d'un maillage pour une ...
Definition: MEDfieldValueRd.c:44
med_geometry_type
int med_geometry_type
Definition: med.h:198
