Cylinders and Pipes Construction¶
Cylinder¶
Simple Cylinder¶
To make a simple cylinder grid in python mode, the following data are required:
nbR : number of hexahedra on radial.
nbA : number of hexahedra along the perimeter of the cylinder.
nbH : number of hexahedra along the axis of the cylinder.
Use the function makeCyinderTop:
elts = doc.makeCylinderTop(nbR, nbA, nbH)
GUI command: Simple Cylinder
Uniform Cylinder¶
The following data are required:
origin : origin’s coordinates of the cylinder (select a vertex).
vx : the base of the cylinder (select a vector).
vz : the axis of the cylinder (select a vector).
rint : the radius of the hole in the cylinder .
rext : the radius of the cylinder.
angle : angle of the cylinder around the Z axis.
hauteur: the height of the cylinder.
Use the function makeCylinderUni to make a uniform cylinder:
elts = doc.makeCylinderUni(origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
GUI command: Uniform Cylinder
Custom Cylinder¶
tr : a list of radiuses in ascendant order.
ta : a list of angles in ascendant order.
th : a list of heights in ascendant order.
Use the function makeCylinder to make a custom cylinder:
elts = doc.makeCylinder(origin, vx, vz, tr, ta, th)
GUI command: Custom Cylinder
Operations on elts: Elements
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 | # -*- coding: utf-8 -*-
# Copyright (C) 2009-2025 CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
####### Make Cylinder Test ##########
import hexablock
# Simple Cylinder -----
doc = hexablock.addDocument ("Make Cylinder Test")
nbR = 8
nbA = 10
nbH = 8
cylinder0 = doc.makeCylinderTop (nbR, nbA, nbH)
cylinder0.saveVtk ("makeCylinderTop.vtk")
# Uniform Cylinder -----
origin = doc.addVertex (0, 0, 5)
vx = doc.addVector (1, 0, 0)
vz = doc.addVector (0, 0, 1)
rint = 2
rext = 4
angle = 300
hauteur = 1
cylinder1 = doc.makeCylinderUni (origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
cylinder1.saveVtk ("makeCylinderUni.vtk")
# Custom Cylinder
origin = doc.addVertex (5, 0, 0)
tr = [10, 20, 30, 40]
ta = [45, 90, 135, 180, 225]
th = [5, 30, 40, 60]
cylinder2 = doc.makeCylinder(origin, vx, vz, tr, ta, th)
cylinder2.saveVtk("makeCylinder.vtk")
Make Cylinders¶
To make two cylinders in T shape the following data are required for each cylinder:
orig : the origin of the cylinder (select a vertex).
h : the height of the cylinder.
One of the two cylinders must be bigger than the other.
Use the function makeCylinders:
elts = doc.makeCylinders (orig1, vz1, rext1, h1, orig2, vz2, rext2, h2)
GUI command: Cylinders
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 | # -*- coding: utf-8 -*-
####### Make Cylinders Test ##########
import hexablock
import math
doc = hexablock.addDocument ("Make Cylinders Test")
rext1 = 2*math.sqrt (2.0)
rext2 = 3*math.sqrt (2.0)
h1 = 16
h2 = 16
xl1 = -8
orig1 = doc.addVertex ( 0, 0, xl1)
orig2 = doc.addVertex (-8, 0, 0)
vz1 = doc.addVector ( 0, 0, 1)
vz2 = doc.addVector ( 1, 0, 0)
cylinders = doc.makeCylinders (orig1, vz1, rext1, h1, orig2, vz2, rext2, h2)
cylinders.saveVtk("makeCylinders.vtk")
Pipe¶
Simple Pipe¶
To make a simple pipe grid in python mode, the following data are required:
nbA : number of hexahedra along the perimeter of the pipe.
nbH : number of hexahedra along the axis of the pipe.
Use the function makePipeTop:
elts = doc.makePipeTop(nbR, nbA, nbH)
GUI command: Simple Pipe
Uniform Pipe¶
origin : the origin’s coordinates of the pipe (select a vertex).
vx : the base of the pipe (select a vector).
vz : the axis of the pipe (select a vector).
rint : the radius of the hole in the pipe .
rext : the radius of the pipe.
angle : angle of the pipe around the Z axis.
hauteur: the height of the pipe.
Use the function makePipeUni to make a uniform pipe:
elts = doc.makePipeUni(origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
GUI command: Uniform Pipe
Custom Pipe¶
origin : origin’s coordinates of the pipe (select a vertex).
Use the function makePipe to make a custom pipe:
elts = doc.makePipe(origin, vx, vz, tr, ta, th)
GUI command: Custom Pipe
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 | # -*- coding: utf-8 -*-
####### Make Pipe Test ##########
import hexablock
doc = hexablock.addDocument ("Make Pipe Test")
# Simple Pipe -----
nbR = 8
nbA = 10
nbH = 8
pipe0 = doc.makePipeTop (nbR, nbA, nbH)
pipe0.saveVtk ("makePipeTop.vtk")
# Uniform Pipe -----
orig = doc.addVertex (0, 0, 0)
rint = 1
rext = 3
angle = 360
hauteur = 2
pipe1 = doc.makePipeUni (orig, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
pipe1.saveVtk ("makePipeUni.vtk");
# Custom Pipe -----
origin = doc.addVertex (0, 5, 0)
pipe2 = doc.makePipe(origin, vx, vz, tr, ta, th)
pipe2.saveVtk("makePipe.vtk")
Make Pipes¶
To make two pipes in T shape the following data are required for each pipe:
orig : the origin of the pipe (select a vertex).
rint : the internal radius of the pipe.
h : the height of the pipe.
One of the two pipes must be bigger than the other.
Use the function makepipes:
elts = doc.makePipes(orig1, vz1, rint1, rext1, h1, orig2, vz2, rint2, rext2, h2)
GUI command: Pipes
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 | # -*- coding: utf-8 -*-
####### Make Pipes Test ##########
import hexablock
import math
doc = hexablock.addDocument ("Make Pipes Test")
rint1 = rext1/2
rint2 = rext1
h1 = 16
h2 = 16
xl1 = -8
pipes = doc.makePipes (orig1, vz1, rint1, rext1, h1, orig2, vz2, rint2, rext2, h2);
pipes.saveVtk("makePipes.vtk")
