Make cartesian grids¶
Simple Cartesian Grid¶
To add a simple cartesian grid to the model, the following data are required:
nb X: The number of hexahedra along the X axis
nb Y: The number of hexahedra along the Y axis
nb Z: The number of hexahedra along the Z axis
Make a Simple Cartesian Grid:
elts = doc.makeCartesianTop(nbX, nbY, nbZ)
GUI command: Simple cartesian grid
Uniform Cartesian Grid¶
To add a uniform cartesian grid to the model, the following data are required:
origin: The vertex of the origin
vec X : The X vector
vec Y : The Y vector
vec Z : The Z vector
len X : The length of an hexahedra on the X axis
len Y : The length of an hexahedra on the Y axis
len Z : The length of an hexahedra on the Z axis
nb X : The number of hexahedra on the X axis
nb Y : The number of hexahedra on the Y axis
nb Z : The number of hexahedra on the Z axis
Make a Uniform Cartesian Grid:
elts = doc.makeCartesianUni(orig, vecX, vecY, vecZ, lenX, lenY, lenZ, nbX, nbY, nbZ)
GUI command: Uniform cartesian grid
Custom Cartesian Grid¶
To add a custom cartesian grid to the model, the following data are required:
tx : A list of x coordinates in ascendant order
ty : A list of y coordinates in ascendant order
tz : A list of z coordinates in ascendant order
Make a Custom Cartesian Grid:
elts = doc.makeCartesian(orig, vecX, vecY, vecZ, tx, ty, tz)
GUI command: Custom cartesian grid
Operations on elts: Elements
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 | # -*- coding: utf-8 -*-
# Copyright (C) 2009-2025 CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
####### Test Cartesian Grid #################
import hexablock
doc = hexablock.addDocument ("Cartesian Grid Test")
# Simple Cartesian Grid
nbX = 3
nbY = 4
nbZ = 5
grid0 = doc.makeCartesianTop(nbX, nbY, nbZ)
grid0.saveVtk("makeCartesianTop.vtk")
# Uniform Cartesian Grid
orig1 = doc.addVertex(10, 0, 0)
vecX = doc.addVector(1, 0, 0)
vecY = doc.addVector(0, 1, 0)
vecZ = doc.addVector(0, 0, 1)
lenX = 5
lenY = 3.5
lenZ = 2
grid1 = doc.makeCartesianUni(orig1, vecX, vecY, vecZ, lenX, lenY, lenZ, nbX, nbY, nbZ)
grid1.saveVtk("makeCartesianUni.vtk")
# Custom Cartesian Grid
orig2 = doc.addVertex(20, 0, 0)
tx = [] # a list of x coordinates
ty = [] # a list of y coordinates
tz = [] # a list of z coordinates
for i in range(6):
tx.append(i+1)
ty.append(i+1)
tz.append(i+1)
# tx=ty=tz=[1,2,3,4,5,6]
grid2 = doc.makeCartesian(orig2, vecX, vecY, vecZ, tx, ty, tz)
grid2.saveVtk("makeCartesian.vtk")
