Hemisphere Grid Construction
Sphere
Simple Sphere
To create a Simple Sphere Grid in python mode, you need the following arguments:
  • nbR : number of hexahedra on radial.
  • nbA : number of hexahedra along the perimeter of the sphere.
  • nbH : number of hexahedra along the axis of the sphere.
Use the function makeSphereTop:
elts = doc.makeSphereTop(nbR, nbA, nbH)
GUI command: Simple Sphere and Simple Rind
Uniform Sphere
The following data are required:
  • center: center coordinates of the sphere (a vertex).
  • vx : the base of the sphere (a vector).
  • vz : the axis of the hole (a vector).
  • rtrou : the radius of the hole in the sphere.
  • rext : the radius of the sphere.
  • angle : angle of the sphere around the Z axis.
  • vplan : the vertex along the vertical axis where the rind will be cut.
  • nr : number of hexahedra on radial.
  • na : number of hexahedra along the perimeter of the sphere.
  • nh : number of hexahedra along the axis of the sphere.
Use the function makeSphereUni to make a uniform sphere grid:
elts = doc.makeSphereUni (center, vx, vz, rtrou, rext, angle, vplan, nr, na, nh)
GUI command: Uniform Sphere
Custom Sphere
  • vz : the axis of the sphere (a vector).
  • trad : a list of radiuses in ascendant order.
  • tang : a list of angles in ascendant order.
  • tphi : a list of heights in ascendant order.
Use the function makeSphere to make a custom sphere:
elts = doc.makeSphere(center, vx, vz, trad, tang, tphi)
GUI command: Custom Sphere
Operations on elts: Elements
Example
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
# -*- coding: utf-8 -*-
# Copyright (C) 2009-2025  CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
####### Sphere Grid Test ##########
import hexablock
doc  = hexablock.addDocument ("Sphere Grid Test")
# Simple Sphere -----
nr = 4
na = 8
nh = 12
sphere0 = doc.makeSphereTop(nr, na, nh)
sphere0.saveVtk("makeSphereTop.vtk")
# Uniform Sphere -----
center  = doc.addVertex (0, 0, 0)
vplan = doc.addVertex (0, 0, -0.5)
vx    = doc.addVector (1, 0, 0)
vz    = doc.addVector (0, 0, 1)
rtrou = 1
rext  = 10
angle = 180
sphere1 = doc.makeSphereUni (center, vx, vz, rtrou, rext, angle, vplan, nr, na, nh)
sphere1.saveVtk("makeSphereUni.vtk")
# Custom Sphere -----
dr     = (rext-rtrou)/nr
dtheta = angle/na
dphi   = 180.0/nh
trad = []
tang = []
tphi = []
for nro in range(nr+1):
  trad.append(rtrou + nro*dr)
for nro in range(na+1):
  tang.append(nro*dtheta)
for nro in range(nh+1):
  tphi.append(-90 + nro*dphi)
sphere2 = doc.makeSphere (center, vx, vz, trad, tang, tphi)
sphere2.saveVtk("makeSphere.vtk")
Rind
Simple Rind
To create a Simple Rind Grid in python mode, you need the following arguments:
  • nbA : number of hexahedra along the perimeter of the rind.
  • nbH : number of hexahedra along the axis of the rind.
Use the function makeRindTop:
elts = doc.makeRindTop(nbR, nbA, nbH)
Uniform Rind
  • center: center coordinates of the rind (a vertex).
  • vx : the base of the rind (a vector).
  • rtrou : the radius of the hole in the rind.
  • rint : the internal radius.
  • rext : the radius of the rind.
  • angle : angle of the rind around the Z axis.
  • na : number of hexahedra along the perimeter of the rind.
  • nh : number of hexahedra along the axis of the rind.
Use the function makeRindUni to make a uniform rind grid:
elts = doc.makeRindUni(center, vx, vz, rtrou, rint, rext, angle, vplan, nr, na, nh)
GUI command: Uniform Rind
Custom Rind
  • center: center coordinates of the rind grid (a vertex).
  • vx : the base of the rind grid (a vector).
  • vz : the axis of the rind (a vector).
Use the function makeRind to make a custom rind grid:
elts = doc.makeRind(center, vx, vz, trad, tang, tphi)
GUI command: Custom Rind
Example
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
####### Rind Grid Test ##########
import hexablock
doc  = hexablock.addDocument ("Rind Grid Test")
# Simple Rind -----
nr = 4
na = 8
nh = 12
rind0 = doc.makeRindTop(nr, na, nh)
rind0.saveVtk("makeRindTop.vtk")
# Uniform Rind -----
rtrou = 1
rint  = 8
rext  = 10
angle = 180
rind1 = doc.makeRindUni(center, vx, vz, rtrou, rint, rext, angle, vplan, nr, na, nh)
rind1.saveVtk("makeRindUni.vtk")
# Custom Rind -----
dtheta = angle/na
dphi   = 180.0/nh
trad = []
tang = []
tphi = []
trad.append(rtrou)
  trad.append(rint + nro*dr)
rind2 = doc.makeRind(center, vx, vz, trad, tang, tphi)
rind2.saveVtk("makeRind.vtk")
Concentric (Spherical) Grid
Simple Concentric
To create a Simple Concentric Grid in python mode, you need the following arguments:
  • nbLayers: the number of nested hexahedra.
  • crit : the criteria.
Use the function makeSphericalTop:
elts = doc.makeSphericalTop(nbLayers, crit)
GUI command: Simple Concentric (Spherical)
Uniform Concentric
  • center : center coordinates of the concentric.
  • vx : the base of the concentric (a vector).
  • vz : the axis of the concentric (a vector).
  • rayon : the radius.
Use the function makeSphericalUni to make a uniform concentric:
elts = doc.makeSphericalUni(center, vx, vz, rayon, nbLayers, crit)
GUI command: Uniform Concentric (Spherical)
Custom Concentric
  • tr : a list of radiuses in ascendant order.
Use the function makeSpherical to make a custom concentric grid:
elts = doc.makeSpherical (center, vx, vz, tr, crit)
GUI command: Custom Concentric (Spherical)
Example
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
####### Concentric (Spherical) Grid Test ##########
import hexablock
doc  = hexablock.addDocument ("Spherical Grid Test")
# Simple Spherical Grid -----
nbLayers = 3
crit = 0
grid0 = doc.makeSphericalTop(nbLayers, crit)
grid0.saveVtk("makeSphericalTop.vtk")
# Uniform Spherical Grid -----
center = doc.addVertex (0, 0, 10)
vz     = doc.addVector (0, 1, 1)
rayon  = 1
grid1 = doc.makeSphericalUni(center, vx, vz, rayon, nbLayers, crit);
grid1.saveVtk("makeSphericalUni.vtk")
# Custom Spherical Grid-----
tr = [10, 20, 30, 40] # a list of radiuses (one radius for each layer)
grid2 = doc.makeSpherical (center, vx, vz, tr, crit)
grid2.saveVtk("makeSpherical.vtk")
