EdgesΒΆ
Manage the edges of the document.
Add an edge, defined by two vertices, in the document:
edge_12 = doc.addEdge(vertex_1, vertex_2)
Add an edge, defined by one vertex and one vector, in the document:
edge_12 = doc.addEdgeVector(vertex, vector)
Get the number of all edges in the document:
sum_a = doc.countEdge()
Get the number of edges used only in the model of blocks:
sum_u = doc.countUsedEdge()
Get the edges used by the model of blocks
# -*- coding: latin-1 -*-
# Copyright (C) 2009-2025  CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
used_edges = []
for i in range( doc.countUsedEdge() ):
    edge_i = doc.getUsedEdge(i)
    used_edges.append(edge_i)
Get an edge of the document:
edge_i = doc.getEdge(i)
Get the vertices of an edge:
vertex_a = edge_i.getVertex(0)
vertex_b = edge_i.getVertex(1)
Find an edge in the document:
edge_f = doc.findEdge(vertex_1, vertex_2)
More operations: Edge inherits Element.
GUI command: Edge
