VerticesΒΆ
Manage the vertices of the model of blocks of a document.
Add a new vertex of the model of blocks in the document:
vertex_1 = doc.addVertex(x, y, z)
Get the number of all vertices of the document:
sum_a = doc.countVertex()
Get the number of vertices used only by the model of blocks:
sum_u = doc.countUsedVertex()
Get the vertices used by the model of blocks
# -*- coding: latin-1 -*-
# Copyright (C) 2009-2025  CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
used_vertices = []
for i in range( doc.countUsedVertex() ):
    vertex_i = doc.getUsedVertex(i)
    used_vertices.append(vertex_i)
Get a vertex of the document:
vertex_i = doc.getVertex(i)
Get the coordinates of a vertex:
x = vertex_i.getX()
y = vertex_i.getY()
z = vertex_i.getZ()
Set the coordinates of a vertex:
vertex_i.setX(x1)
vertex_i.setY(y1)
vertex_i.setZ(z1)
Find a vertex in the document (with a tolerance):
vertex_f = doc.findVertex(x, y, z)
More operations: Vertex inherits Element.
GUI command: Vertex
