| _sub_edges | INTERP_KERNEL::ComposedEdge | protected |
| applyGlobalSimilarity(double xBary, double yBary, double dimChar) | INTERP_KERNEL::ComposedEdge | |
| applyGlobalSimilarity2(ComposedEdge *other, double xBary, double yBary, double dimChar) | INTERP_KERNEL::ComposedEdge | |
| applySimilarity(double xBary, double yBary, double dimChar) | INTERP_KERNEL::ComposedEdge | |
| applySimilarityOnMyEdges(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| applySimilarityOnMyEdgesIfNotAlreadyHit(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| applySimilarityOnMyNodes(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| applySimilarityOnMyNodesIfNotAlreadyHit(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| back() const | INTERP_KERNEL::ComposedEdge | |
| changeEndNodeWith(Node *node) const | INTERP_KERNEL::ComposedEdge | |
| changeStartNodeWith(Node *node) const | INTERP_KERNEL::ComposedEdge | |
| clear() | INTERP_KERNEL::ComposedEdge | |
| clone() const | INTERP_KERNEL::ComposedEdge | |
| completed() const | INTERP_KERNEL::ComposedEdge | |
| ComposedEdge() | INTERP_KERNEL::ComposedEdge | |
| ComposedEdge(const ComposedEdge &other) | INTERP_KERNEL::ComposedEdge | |
| ComposedEdge(int sz) | INTERP_KERNEL::ComposedEdge | |
| Delete(ComposedEdge *pt) | INTERP_KERNEL::ComposedEdge | static |
| dispatchPerimeter(double &partConsidered) const | INTERP_KERNEL::ComposedEdge | |
| dispatchPerimeterAdv(const ComposedEdge &father, std::vector< double > &result) const | INTERP_KERNEL::ComposedEdge | |
| dispatchPerimeterExcl(double &partConsidered, double &commonPart) const | INTERP_KERNEL::ComposedEdge | |
| dumpInXfigFile(std::ostream &stream, int resolution, const Bounds &box) const | INTERP_KERNEL::ComposedEdge | |
| dumpToCout(const std::map< INTERP_KERNEL::Node *, int > &mapp) const | INTERP_KERNEL::ComposedEdge | |
| empty() const | INTERP_KERNEL::ComposedEdge | |
| fillBounds(Bounds &output) const | INTERP_KERNEL::ComposedEdge | |
| front() const | INTERP_KERNEL::ComposedEdge | |
| getAllNodes(std::set< Node * > &output) const | INTERP_KERNEL::ComposedEdge | |
| getArea() const | INTERP_KERNEL::ComposedEdge | |
| getBarycenter(double *bary) const | INTERP_KERNEL::ComposedEdge | |
| getBarycenter(double *bary, double &weigh) const | INTERP_KERNEL::ComposedEdge | |
| getBarycenterGeneral(double *bary) const | INTERP_KERNEL::ComposedEdge | |
| getCommonLengthWith(const ComposedEdge &other) const | INTERP_KERNEL::ComposedEdge | |
| getDirection() const | INTERP_KERNEL::ComposedEdge | |
| getEndNode() const | INTERP_KERNEL::ComposedEdge | |
| getHydraulicDiameter() const | INTERP_KERNEL::ComposedEdge | |
| getPerimeter() const | INTERP_KERNEL::ComposedEdge | |
| getStartNode() const | INTERP_KERNEL::ComposedEdge | |
| initEdgeHitStatus() const | INTERP_KERNEL::ComposedEdge | |
| initLocations() const | INTERP_KERNEL::ComposedEdge | |
| InitLocationsWithOther(const ComposedEdge &first, const ComposedEdge &other) | INTERP_KERNEL::ComposedEdge | static |
| initNodeHitStatus() const | INTERP_KERNEL::ComposedEdge | |
| intresincEqCoarse(const Edge *other) const | INTERP_KERNEL::ComposedEdge | |
| isInOrOut(Node *nodeToTest) const | INTERP_KERNEL::ComposedEdge | |
| isInOrOut2(Node *nodeToTest) const | INTERP_KERNEL::ComposedEdge | |
| isNodeIn(Node *n) const | INTERP_KERNEL::ComposedEdge | |
| IteratorOnComposedEdge | INTERP_KERNEL::ComposedEdge | friend |
| normalize(ComposedEdge *other, double &xBary, double &yBary) | INTERP_KERNEL::ComposedEdge | |
| normalizeExt(ComposedEdge *other, double &xBary, double &yBary) | INTERP_KERNEL::ComposedEdge | |
| normalizeMe(double &xBary, double &yBary) | INTERP_KERNEL::ComposedEdge | |
| operator[](int i) const | INTERP_KERNEL::ComposedEdge | |
| presenceOfOn() const | INTERP_KERNEL::ComposedEdge | |
| presenceOfQuadraticEdge() const | INTERP_KERNEL::ComposedEdge | |
| pushBack(Edge *edge, bool direction=true) | INTERP_KERNEL::ComposedEdge | |
| pushBack(ElementaryEdge *elem) | INTERP_KERNEL::ComposedEdge | |
| pushBack(ComposedEdge *elem) | INTERP_KERNEL::ComposedEdge | |
| recursiveSize() const | INTERP_KERNEL::ComposedEdge | |
| resize(int i) | INTERP_KERNEL::ComposedEdge | |
| reverse() | INTERP_KERNEL::ComposedEdge | |
| setValueAt(int i, Edge *e, bool direction=true) | INTERP_KERNEL::ComposedEdge | |
| size() const | INTERP_KERNEL::ComposedEdge | |
| SoftDelete(ComposedEdge *pt) | INTERP_KERNEL::ComposedEdge | static |
| unApplyGlobalSimilarityExt(ComposedEdge &other, double xBary, double yBary, double fact) | INTERP_KERNEL::ComposedEdge | |
| unApplySimilarityOnMyEdges(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| unApplySimilarityOnMyEdgesIfNotAlreadyHit(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| unApplySimilarityOnMyNodes(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| unApplySimilarityOnMyNodesIfNotAlreadyHit(double xBary, double yBary, double dimChar) const | INTERP_KERNEL::ComposedEdge | |
| ~ComposedEdge() | INTERP_KERNEL::ComposedEdge | protected |
